Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 4203 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
  • rsc
    rsc over 1 year ago
    Kinda probably works like this one I built a while ago.  I added some switched attenuation resistors for fox hunting.
    Scott
  • rsc
    rsc over 1 year ago
    Scott
  • kmikemoo
    kmikemoo over 1 year ago in reply to rsc
    rsc  NICE!!  I've got a few toys to help hunt, but a loop is not one of them.  But you could solve that deficiency by sharing your build plan. Relaxed
  • rsc
    rsc over 1 year ago in reply to kmikemoo
    Build plan?  That's funny.  I just looked online at a few designs and started experimenting.  I just used a 1m loop of copper tubing and tuned it up using the same antenna analyzer you've got.  Some designs have a tuning cap on the large loop, mine doesn't.
