Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3985 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
  • scottiebabe
    scottiebabe over 1 year ago
    Wonderful project. Hopefully the weather satellites don't get fully turned off anytime soon, just not recommended for use.
    www.scientificamerican.com/.../
  • scottiebabe
  • kmikemoo
    kmikemoo over 1 year ago in reply to scottiebabe
    scottiebabe Cold sweat Wow.  Than really stinks.  One of the things I recently learned was that the weather satellites feed (or fed) info to the spy satellites about cloud coverage.  There's no sense in taking high resolution pictures of the tops of clouds.
    This also leans on that very frayed nerve of people that don't understand the value of routine maintenance.  The Death Spiral is quick on vintage equipment - and then you have nothing. Frowning2
