Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3976 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
  • kmikemoo
    kmikemoo over 1 year ago
    Here is a picture of the antenna in use today.
    For those that enjoy a challenge, here is a picture with a bit less zoom.  Can you find it?
    Even once you see it, it's hard to see it. Relaxed
  • kmikemoo
  • robogary
    robogary over 1 year ago in reply to kmikemoo
    How close do you need to be to call this fox found ?
  • kmikemoo
    kmikemoo over 1 year ago in reply to robogary
    robogary Interesting question.  If someone says they found it, I take that to mean that they actually saw the antenna and transmitter bag.  Sometimes folks will text me or Facebook Messenger me pictures.  There are no prizes so folks compete for bragging rights.  Each one of them gets praised.  "Great job!  You're the first!"  "That's fantastic!  Thanks for hunting.  Knowing that you did makes getting up early on a Saturday worth it. Thumbsup"
    I also get messages of "I was close but I just couldn't find it.", so I'll tell them where it was and what it looked like.  "Ah!  So close!  Great job!  You'll get it next month."
    My club members all have access to my cell phone number and I try to monitor our Facebook page as best I can.  The hunt starts at 0730 and ends at 1630 (sometimes later).  Part of the Rules of Engagement are not sharing the location until after noon.  Hints should guide but not ruin the hunt.  After lunch... less subtle.  Mid afternoon... blatant.  I WANT people to find the fox, but not so quickly that it isn't challenging and fun.  If folks are hunting when I show up to recover the fox, I'll coach them - or tell them - depending on where they are psychologically.  If they'll give it another go next month... we're winning.
    I guess all those Anger Management classes I had to take are finally bearing fruit - at least outside of work. LaughingThumbsup
    Not sure about the fox but I think we do have a tree climbing monkey in the vicinity
  • kmikemoo
    beacon_dave Great job!  On the first hunt I hosted, I did climb a tree.  My wife was not thrilled.  She made me bring a ladder on the next one.  I did that for a couple more, but those collapsible ladders aren't exactly light.  That's when I broke down and bought a telescoping painters pole.  After about 2 years of supervising me hiding the fox - and promising not to climb any more trees, she has finally allowed me to go out on my own.
