Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3968 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
    The question is, can you now make one based upon a pocket steel tape measure ?   Slight smile
  • kmikemoo
    beacon_dave  Laughing  Working with that stuff is a bit like trying to train a cat.  You know what you would like it to do.  It does what it wants to do.
    I have built two tape measure Yagi-Uda antennas.  Two because I had to add reinforcing PVC to one of them so I could use it when there is even the slightest wind.  Anyone that has one knows exactly what I'm talking about.  I also tried using tape measure antennas for a TDOA direction finding antenna.  Oye!  If you thought the Yagi flopped around...
    AND... because I'm an exceptionally slow learner... Slinkys are on the build plan - just not for 2 meters.
