Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3972 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
  • kmikemoo
    beacon_dave  That is the one. Thumbsup
    Isn't the size of the top of the triangle important, as that presumably is acting as the plates of a capacitor ?
    image image
    Can't exactly say that you didn't have a ruler to hand Slight smile
  • kmikemoo
    beacon_dave The width of the gap absolutely determines the resonant frequency.  The smaller the gap, the lower the resonant frequency.  My challenge was raising the frequency 10MHz.  It's a bit like my eyesight.  It's fine.  My arms just aren't long enough.  Neither was my plastic bolt.
    I tried to logic through how increasing the capacitance made the antenna appear longer.  Okay... it offsets the inductance of the yardstick that isn't a full half wave... plus the optical range of a field mouse divided by the mass of a dill pickle - I don't know!  We cut dipoles shorter to raise their resonant frequency.  I'm making the loop shorter.  Some day.
    Credit to you.  When I do this again, I will probably experiment with the size of the capacitor plates.  I totally missed or forgot that measurement.  Eventually there is a horizontally polarized 144.05MHz version of this that I will want to build.
    * As to the "ruler on hand"... there were definitely times that I deeply regretted painting that yardstick. Laughing
  • kmikemoo
    Also perhaps keep in mind the width of your yardstick, as the one from Ace Hardware used in the article was 1-1/8” wide
    so that 1-1/8" width in conjunction with the 1/2" length shown, gives your effective area of the capacitor plate.
