Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3987 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
  • robogary
    robogary over 1 year ago
    Wow - a foxhunt antenna ?  It looks like the triangle is connected to the shield side of the coax, and the center conductor is also connected to the triangle at a specified distance with a half moon loop ? How does this antenna work ? Is it directional ?
  • kmikemoo
    kmikemoo over 1 year ago in reply to robogary
     robogary Yes, sir.  It is a fox hunting antenna.  And in keeping with my last minute tradition, it has been deployed today for our first hunt of the season.
    As for the construction, I would call it a delta loop with a gamma match.  The half moon loop is the gamma match part and the semi-circle shape gave me a better SWR than an oblong-ish shape.  I haven't done any modelling of it, but my expectation based on other models is that it is vertically polarized since I hang it from the point opposite the feed point.  It should radiate like a dipole with opposite primary lobes and corresponding nulls but it's only about 4 meters above the ground.  At that height, it's fairly omni-directional.  This is also what I experience when I check to make sure that it is getting out.  With 50mW, the range is at least 2 miles.  That's not bad given that it's through trees, etc.
    I hope I remember to snap a picture of it when I go to take it down. Laughing
    Perhaps work it into a pirate's tricorn hat  - than you can have 'pirate radio' Slight smile
