Member and Staff Blogs Year of the Monkey Badge: Hao Xie Nian!
  • Author Author: spannerspencer
  • Date Created: 29 Jan 2016 10:35 AM Date Created
  • Views 7407 views
  • Likes 8 likes
  • Comments 64 comments
  • helpful_hints
  • tips_and_tricks
  • chinese_new_year
  • year_of_the_monkey
spannerspencer
spannerspencer
29 Jan 2016
Year of the MonkeyCelebrate Chinese New Year with element14!
Day Eight: Happy New Year!
Hao xie nian! The holidays are upon us, which is wonderful news, albeit the end of our element14 celebrations. And here we are, welcoming in the Year of the Monkey, and a brand new badge to usher it in.
Now that it's the Year of the Monkey, all you need to do to win our time-limited badge is stop by to read and comment on each of our New Year blogs. The badge will only be available to earn until February 23, after which you'll have to wait 12 years before it comes up again (given the cycle of the Chinese zodiac).
Monkey Business
The monkey signifies a year of creativity, innovation, and also of mischief. Which seems quite fitting for the element14 Community!image
So in honour of the cheeky monkey that'll be looking over our celestial shoulders this year, we want you to give all your top tips, cheats, hints and tricks that you regularly employ while working on your electronics projects.
Thanks for joining in with our Chinese New Year celebrations, and may you have a splendid year swinging from the trees and causing all manner of mischief!
  • ipv1
    ipv1 over 10 years ago +9
    Here's a tip for some the newbies..
  • clem57
    clem57 over 10 years ago +4
    When soldering headers, do one end pin first and do other end next. Check alignment carefully before finishing row. Clem
  • spannerspencer
    spannerspencer over 10 years ago +4
    My top tip: When you get up to the 30th floor and realise you've forgotten to bring a fuse with you to get a PSU working again, you can always rob the one out of your multimeter Guess how I figured that…
  • grahamwebberjhb
    grahamwebberjhb over 10 years ago +4
    When building a prototype PCB use 0 ohm resistors on the supply to major circuit blocks this allows you to easily remove parts of the circuit to find the culprit, if things do not work first time.
  • bwelsby
    bwelsby over 10 years ago +4
    When working on a new project document everything. Divide large complicated projects into smaller easy to manage chunks. Work out a testing strategy Read datasheets at least twice. When you have a problem…
    dougw over 10 years ago +3
    If it looks like your soldering is getting dangerously messy, or has unwanted solder bridges, clean the tip of your iron and use more flux. Probably the most useful diagnostic instrument is your eyes …
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago +3
    A really great tip you will thank me for at some point (I learned this the hard way) Try to train yourself to NOT grab your soldering iron if you drop it or if it falls I did this in my late teens, it…
    Robert Peter Oakes over 10 years ago in reply to Robert Peter Oakes +3
    Oh and in the spirit of the year of the Monkey Put enough monkeys in a room with enough equipment and time and they will create Ultron and take over the world, or atleast create some awsome AI Gung He…
    Well a few of us are there
  • COMPACT
    COMPACT over 10 years ago in reply to shabaz +3
    Hi Shabaz, Most persons thought the universe was earth centric or flat and that's the case with soldering temperatures as well. The drop in temperature of the energy source when soldering is the reason…
  • jkutzsch
    jkutzsch over 10 years ago
    Some pretty cool tips!
    One thing as a newbie I have to keep reminding myself is that for us US side people, change your keyboard layout for Raspberry Pi when loading a clean OS.  :-)
    You can use sudo raspi-config or edit the etc/default/keyboard file to XKBLAYOUT="us"
  • jkutzsch
