Legacy Personal Blogs Extending Printrbot Simple's build platform...
  • Author Author: bradnorwood
  • Date Created: 12 Nov 2014 6:48 PM Date Created
  • Views 2479 views
  • Comments 23 comments
bradnorwood
bradnorwood
12 Nov 2014
This has been tricky, simple for the z extension. I replaced the rods and screw shaft with larger ones. It extended my z from 100mm to 250mm. But I had to go into G-code and change the maximums there to get it to recognize the extra size. Now I'm printing larger shaft holders for the x increase. I will replace the bed once the dimensions. Then with an increased z and x I will start the y.
  • bradnorwood
    bradnorwood over 11 years ago +2
    Printrboard box top completed 3 hours and 3 minutes.
  • bradnorwood
    bradnorwood over 11 years ago in reply to DAB +1
    DAB hope you you like this one hahaha
    DAB over 11 years ago in reply to bradnorwood +1
    Indeed I do. Great post. DAB
  • bradnorwood
    130mm x increase, I can make it bigger, I have to reprint the legs that connect it to the rods to get them further away from the bed for better clearance...
  • bradnorwood
  • bradnorwood
    bradnorwood over 11 years ago in reply to bradnorwood
