Legacy Personal Blogs Extending Printrbot Simple's build platform...
  • Author Author: bradnorwood
  • Date Created: 12 Nov 2014 6:48 PM Date Created
  • Views 2448 views
  • Comments 23 comments
bradnorwood
bradnorwood
12 Nov 2014
This has been tricky, simple for the z extension. I replaced the rods and screw shaft with larger ones. It extended my z from 100mm to 250mm. But I had to go into G-code and change the maximums there to get it to recognize the extra size. Now I'm printing larger shaft holders for the x increase. I will replace the bed once the dimensions. Then with an increased z and x I will start the y.
  • bradnorwood
    bradnorwood over 11 years ago +2
    Printrboard box top completed 3 hours and 3 minutes.
  • bradnorwood
    bradnorwood over 11 years ago in reply to DAB +1
    DAB hope you you like this one hahaha
    DAB over 11 years ago in reply to bradnorwood +1
    Indeed I do. Great post. DAB
    Brad, could you provide some pictures?
  • bradnorwood
    Not easy! Plus I ran into my sensor not working due to being a metal detecting sensor, so I have to add metal tape lol
    If I need a larger make base I might do this as well.
    For now I will just try things with what I have.
    I do like you idea though.  There is no reason why you cannot adapt your 3D printer into different ways to customize it to your needs.
    Great idea.
  • bradnorwood
    Yeah, getting the sensor to pick up was a choir, I had to put down metal tape and then my blue tape to get it to stick, but the plus side is my plate cost $3 and some time instead of $60-100 for a solid aluminum one this size is 12" x 8" and next i will work on the z and y to get it to 12 x 12 x 12
  • bradnorwood
    bradnorwood over 11 years ago in reply to bradnorwood
  • bradnorwood
    Old print size with new size, the z was the easyiest to up grade, I actually printed the pipe up right, new size is 90mm x 115mm x 300mm and wow hahaha
  • bradnorwood
  • bradnorwood
    Indeed I do.
    Great post.
  • bradnorwood
    With the increased x the back side needs more support
  • bradnorwood
    A belt guide was added and the x right stabilizer
  • bradnorwood
    I'm relocating the Printrbot board also.
    You are a braver man than I.
