Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10466 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • zst123
    zst123 over 5 years ago
    Like many people indeed my first tool was a digital multimeter. Not much of a story there… I grew up in the 21st century so I didn't get to see those vintage analog multimeters like some of the others have shown off here.
    I guess what is more interesting is my first oscilloscope. Not too long ago I had just been looking around the second-hand market and scored a great deal for an oscilloscope and function generator.
    It is a Yokogawa DL1520 and it was ahead of its time. It has many features present in today's entry level scopes like cursor and auto-measure, FFT, math and so on. The only caveat is that the screenshots save to a floppy disk but I read that I can do it through the RS232 interface too.
    In this picture I do not have any probes because the original cables have frayed and I threw it out as it was getting nasty. I ordered some cheap passive probes online. I doubt I will be doing any high speed measurements (for now) so that should suffice.
    • Vote Up +8 Vote Down
  • jmcrook
    jmcrook over 5 years ago
    A diy multimeter kit bought from a little electronics shop in adelaide. I was wiring my first car stereo and needed one and wanted to make it myself. Shockingly no pun intended it worked and it still resides in my garage though I've graduated to much better tooling since.
  • anybee
    anybee over 5 years ago
    This was my first piece of testequipment.
    Russian Standard image
    Good old Brick
    • Vote Up +5 Vote Down
  • chris_randon
    chris_randon over 5 years ago
    Fluke 8060a Multimeter intially for working on the car, then fixing power supplies and computers and then later at college.  Replaced with budget multimeters after the screen died.  The basic multimeter is still one of the most used and useful bits of equipment I have
    e14 Contributor over 5 years ago
    MY ULTIMATE TOOL KIT.
    The tool kit I am using currently consists of;
    DIGITAL MULTIMETER
    WIRE CUTTER
    WIRE RIPPER
    MARKER
    BREAD BOARD
    SCREW DRIVERS
    SCREW DRIVER KIT
    BATTERRIES
    TWEESERS (FORECEPS)
    SOLDERING IRON
    SOLDERING WIRE
    SOLDRING FLUX
    DESOLDERING PUMP
    DESOLDERING WHIP
    SOLDERING BOARD.
  • jkittle99
    jkittle99 over 5 years ago
    As a kid, I was constantly tearing things apart. Toys, household appliances, you name it. I didn't have any test and measurement equipment, but for my 13th birthday, my older sister went to radio shack and bought me a multimeter. That was the beginning of a long journey of learning about electronics for me.  For the first time, I was able to measure things - volts, ohms, you get the picture.  I used it on so many projects, I can't even describe them all.  Sadly, it did die years ago, but I would be using it today if I still had it.
  • messanger_05
    messanger_05 over 5 years ago
    The first measurement tool I ever used is fittingly the DMM, the workhorse of Electrical Engineering. I got it when I was about 13 or 14 and have used it ever since. It’s gotten me through my BSEE, MSEE, and is still the keystone of my home lab.
    It was actually part of a toolkit I received as a gift along with a soldering iron and a few DIY electronic kits (like a wireless microphone playable on our home stereo system). The kits had all the parts and instructions, the soldering iron let me put them together, and the DMM was the linchpin that let me get them working by finding my many mistakes. Though I first received it two decades ago, it’s still going strong (with a few 9V battery replacements).
    After its initial use of finding all the bad solder joints on my first electronics kits, the DMM settled in as a security blanket during my Bachelors degree. Most of the projects I worked on at that time were group projects done in the electronics lab. But then it came roaring back into my life as a prized possession when my company paid for me to go back to school for my Masters degree. They paid tuition but didn’t give time off so it was a struggle to find time to go to campus. My home became my lab and my trusty DMM was right there waiting for me!
    Due to life events, I took the maximum amount of time I was allowed to complete the graduate degree (7 years!). The last year was a mad dash to complete the Thesis project without overshooting the allowed timetable. I was burning the candle at both ends, working my job all day and the project all night. Thankfully, my co-workers were understanding and cut me some slack during this trying time. Also thankfully, I still had my soldering iron and DMM from so long ago, so I was able to work nights/mornings/weekends without making the commute to the campus and lab there. Without that benefit, I never would have finished the project, or my degree.
    Working on that project at home had the benefit of showing me what I’m capable of with a home lab. If I could do University quality research then, I can still do it now! Currently, I’m in the process of fleshing out my bench with more standard equipment that I need. The next two main items I’m looking at are an adjustable power supply and O-scope.
    Sadly, the soldering iron gave up the smoke two days before I finished. I had to go on a Sears run 10 minutes before they closed on a Sunday to replace it and continue working. The steadfast DMM stayed with me throughout though! It still sits on my desk in pride of place as I continue to slowly build up my bench.
  • digitalbeans
    digitalbeans over 5 years ago
    A multimeter
  • olympusmons
    olympusmons over 5 years ago
    My first trace rot repair on an original Xbox was a big moment for me being new to repair . I had been told by fellow Xbox enthusiasts that this was the probable cause of my issue which was random switching off and powering on with eject . I proved lack of continuity along two traces on the board and the rot was also visible as tiny black dots . The rot was repaired by simply jumping the traces with thin wire and voilà the Xbox sprang back in to life , the sence of satisfaction was hard to describe but suffice to say I am now hooked on repair .
  • johnjjohn
    johnjjohn over 5 years ago
    My first measurement tools weren't mine, but the marine schools I was training at to be an Electro-technical officer. I absolutely love oscilloscopes (especially the old type with fluorescent green waveforms). I even made one out of an old crt tv from a cctv room on a cruise ship!
    My first meter was actually a mini fluke from Korea, not exciting but the only thing I could afford.
