Documents elf14 presents - The Test and Measurement Tool Bundle Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 26 Jan 2021 9:28 AM
  • Views 10471 views
  • Likes 20 likes
  • Comments 194 comments
The Test and Measurement Tool Bundle Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Test and Measurement Tool Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your first test or measurement tool?
Why that tool? How did it help you, what project did you use it on? Do you still have it in your collection or on your bench, or has it since been replaced?
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld Digital OscilloscopeMulticomp Pro1Buy NowBuy Now
Handheld Digital MultimeterMulticomp Pro1Buy NowBuy Now
Humidity MeterMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, 4mm Banana Plug, Stackable, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Black, 304.8 mmMulticomp Pro1Buy NowBuy Now
Test Lead, Alligator Clip, Alligator Clip, 60 VDC, 10 A, Red, 304.8 mmMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 12 PIECEMulticomp Pro1Buy NowBuy Now
TEST LEAD KIT, 10 PIECEMulticomp Pro1Buy NowBuy Now
Congratulations to the Winner!
nathandumont has been chosen, and they have managed to get in touch!
It would have been unfair to deny the prize due to technical problems, thank you to everyone for entering!
Terms and Conditions apply.
  • elf14 presents
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • giveaway
  • test and measurement tool bundle giveaway
  • ralphjy
    ralphjy over 5 years ago +12
    I remember when I was just starting in college I decided that I was building enough electronics that I needed a Volt-Ohm-Milliammeter (VOM) of my own and I bought a Knight Kit from Allied Electronics and…
    dubbie over 5 years ago +10
    When I started with electronics I was probably only 16 or 17 and managed for several years without any test equipment at all. Obviously, not much of my stuff worked as I had no method of finding faults…
    genebren over 5 years ago +10
    I was always in a hurry to grow up and get a 'real job'. I completed High School in three years and college in three years. While in High School, I spent nearly half of my time in the Electronics Lab …
  • proscriptus
    proscriptus over 5 years ago
    I mean, my first measurement tool was probably a little wooden ruler when I was a kid...
  • wolmop
    wolmop over 5 years ago
    Hi all. My first measurement tool was a Radio Shack TRMS multi-meter along with extra leads that I bought because it seemed pretty inexpensive and complete. Unfortunately I no longer have it. I used it in a field service job at which I had to supply many of my own tools and equipment, many years ago and it got either misplaced or stolen. Later I got to use Fluke 87 and 187 meters, Tektronix and Agilent ‘scopes, spectrum analyzers, wave meters, Melles Griot Power meters and things like that at other jobs, but they weren’t mine.
    Jon
  • raff-azsphere
    raff-azsphere over 5 years ago
    I'm a software developer, so I know how mach is important to testing and debugging.
    I'm new to electronics and, until now, I didn't even know that's possble to test and debug electronic circuits, so I'm very intereste in a test and measurement tool.
    I'm planning to use it on a Raspberry Pi project with an application connected to a smartphone.
  • players
    players over 5 years ago
    back in the early 90's I bought an old analog volt and amp multimeter to test a car (min cooper) wiring loom. I still have it but currently moved house so its in one of these many boxes that still need sorting out.
  • nathandumont
    nathandumont over 5 years ago
    This was my first piece of test equipment; a multimeter.  Not sure when I got it exactly, late '90s some time I guess.  Almost certainly bought by my dad from the big blue Farnell catalogue over the phone.  When I was looking it up the datasheet is still available from Farnell UK (http://www.farnell.com/datasheets/301738.pdf ).  I think it arrived in time to help out with the last iterations of my Lego city where I was using LEDs and torch bulbs to illuminate my buildings.  Then I got into building amateur Robot Wars machines for competitions with school friends.  I've still got it, there's a better one at the top of my toolbox now but this one's still very reliable and is often pulled out if I want to measure current and voltage at the same time.  It's had a few new batteries a couple of fuses and a new set of test probes but I can't think of another electronic gadget I've used so consistently for over 20 years.  As a first piece of test equipment a multi meter is hard to beat!
  • ipv1
    ipv1 over 5 years ago
    My First Test tool was a DIY continuity tester. I was around 8 at the time and was starting electronics by reading books.(Yes I was born a nerd). I could not afford a multimeter so I used a two AA cells with a 3V lamp. I could not solder so I used electric tape to hold things together. I had a small briefcase that I used to put everything in and I am told, I was responsible for taking apart a few fans in the neighbourhood.
    Those have since been replaces three decades ago and my hobby of repairing flashlights and radios has become much more complicated since. image
    • Vote Up +5 Vote Down
  • ritvi
    ritvi over 5 years ago
    My first ever measurement tool and a measurement goto tool is my steel ruler! From my pcb designs, glass mosaics, clay sculptures, even while soldering. that ruler always comes through. When it comes to testing, my favriote tool is the DSO, I dont have one, so I use the one at my college and at my place of work, but working and debugging with a DSO, that to a 4 channel one is an absolute treat.
    I have been using that steel ruler forever, I can't imagine my workspace without it. I have been looking at different options of DSOs available to add to my collection and workspace but for now I am okay with using the one available at my institute.
  • ganderson12
    ganderson12 over 5 years ago
    My first test instrument was a borrowed Simpson bench meter. I didn’t many projects and repairs in my dads shop with it
  • jeffrysharon
    jeffrysharon over 5 years ago
    Hi elf14 team,
    I am thankful for this opportunity to share my first test experience which happened when I was a high school student not much know how to use a multi meter.
    I saw many times my brother, an motor mechanic & electrician who used multi meter for checking and repairing.
    One day while my bro is not in home, I was motivated to know how does that stuff works. I wanted to check what is the exact volts my home current uses. So I switch the multi meter volt function(not correct)  and plug the two terminal into wall socket (pluged wrongly due to lack of knowledge) and switch ON.
    Suddenly, with a spark and sound the socket fired and multi meter went down.(later I was beaten by my brother)
    After that I have passion to learn and gain knowledge in electronics and electrical, also make it as my career.
    Now I share my knowledge with neighbourhood, students and make them skilled in testing and electronics.
    It would be very much helpful, If I get this test and measurement tool bundle from Element14.
    Jeffry Sharon
    India
  • levers101
    levers101 over 5 years ago
    One of these Amprobe A/C current testers (picture from Amprobe) was my first testing tool. I learned (and subsequently forgot) how to diagnose water well submersible pump failures with one of these working with my dad. He was the last of the families 3-generation water well installation and service business. I'm sure he still has one, but is now retired and sold his pump truck.
    Now I'm a scientist and research groundwater contamination. The apple often doesn't fall far from the tree.
    • Vote Up +8 Vote Down
