Documents elf14 presents - Circuit Assembly Tools Giveaway
  • Author Author: cstanton
  • Date Created: 18 Nov 2020 3:44 PM Date Created
  • Last Updated Last Updated: 15 Jan 2021 11:21 AM
  • Views 9342 views
  • Likes 20 likes
  • Comments 140 comments
The Circuit Assembly Tools Giveaway!
Engineer and Maker Wishlist | Circuit Assembly Tools Giveaway! | Test and Measurement Giveaway! | Ultimate Raspberry Pi Giveaway! | Project14 Holiday Special
Unsupported video URL format.
Welcome to the elf14 element14 Community!
It's the season of gift-giving, so the element14 Community has prepared the Best Circuit Assembly Tools Bundle to giveaway!
The below kit will be awarded to the element14 members that add a comment and let us know:
What was your best electronics fix or repair?
What 'thing' did you figure out in a project or design, or repair that saved the day?
Tell us your good stories, or if you really don't have any, your best recovered disasters!
Contest Opens: 27th November 2020
Contest Closes: 30th December 2020
Winners Announced: After 11th January 2021
Register to Enter Now!
What We Gave Away!
Product NameManufacturerQuantityBuy KitBuy Kit
Wire Kit, Jumper, Male to Male, Solderless, 100 mm - 250 mm, 75 PieceMCM1Buy NowBuy Now
Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 PieceMCM1Buy NowBuy Now
Anti Static Wrist Strap, Adjustable, 6ft Cord, Blue, Alligator ClipMulticomp1Buy NowBuy Now
Single Channel Soldering Rework Station, 230V, 150WMulticomp Pro1Buy NowBuy Now
Solder Paste Squeege, Synthetic No Clean, PVCChip Quik1Buy NowBuy Now
Solder Paste, Synthetic No Clean, 183 °C, 63, 37 Sn, Pb, 15GChip Quik1Buy NowBuy Now
Solder Flux, Rosin, Soldering, Pen Applicator, 10 ml, 9.3 gMulticomp1Buy NowBuy Now
element14 presents Prototyping BreadBoardn/a1
Congratulations to the Winner!
davegsm82 has been chosen, and they have 7 days to respond to the message sent to them!
If you do not respond within 7 days, I will have to choose another winner!
Terms and Conditions apply.
  • elf14 presents
  • circuit assembly tools
  • circuit assembly tools giveaway
  • holiday season 2020
  • holiday season
  • elf14presents_wishlist
  • magikben
    magikben over 5 years ago +11
    When I was an engineering co-op in college I had a job working with the standby power group of a Cummins distributor. We had a big job putting a 1MW genset in a data center. Awesome unit with a quad turbo…
  • koudelad
    koudelad over 5 years ago +10
    My best electronics repair was a CNG boiler. Long story short: just before the freezing winter, my friend had a control board of a CNG boiler failure. It heated water and all the rooms. He was offered…
  • davegsm82
    davegsm82 over 5 years ago +10
    Just wanted to put this up and say thanks to the folks at element14, I received the prize from the competition and just wanted to put up this pic. The soldering station is amazing, and by happy coincidence…
  • davegsm82
    About 7 years ago I got a panicked phone call from my wife who told me the tall freezer in the kitchen was making a beeping noise and it was quickly defrosting inside.
    I had to come home from work to try and save the hundreds of pounds of food going bad, when I got back home I found that there was no life in the freezer other than the beeping noise and a warning LED on the top panel inside the front door.
    I disassembled the controller on the back of the freezer, it's a large PCB originally intended for washing machines etc and repurposed for use on other appliances, the control panel at the top of the freezer communicates with it via I2C. Unfortunately the big PCB at the bottom was dead, only the power supply was working but the 'receiver' part (just another micro) was dead. Scoping the crystal showed there was clock activity but no response on the inputs or outputs.
    As a temporary measure I connected the compressor and circulation fan directly to the mains and plugged the freezer into a 24H timer, so it ran 45 minutes off, 15 minutes on. This worked for a few days but wasn't apropriate for long term as it wasn't temperature controlled and also the freezer is a frost free unit so the condenser unit fills up with ice eventually and an electric heater has to be turned on in order to melt the ice and restore efficient operation.
    My eventual solution was what can be seen in the pictures, stuck to the side of the freezer cabinet. It was only meant to be temporary but here we are 7 years later!
    The solution consists of cheap 12v relay modules which interface to the compressor, Fan and heater. powered by a nice reliable 12V linear mains transformer, and controlled by a PIC18F2520. It takes the inputs from the existing 10K NTC thermistors in side the cabinet and a potentiometer. It has an 4 x 20 LCD display for status information and also has a bluetooth module for communication, which I can use custom AT+ commands to check the status, log data and command the unit to run defrost or override the temperature contol input etc etc.
    • Vote Up +8 Vote Down
  • 14rhb
    14rhb over 5 years ago in reply to davegsm82
    I take my hat off to you for this 'temporary' fix image. If only manufacturer's adopted your design philosophy (with accessibility to the controller, relays and wiring) we'd all be in a much better place when it comes to repairing stuff. A big start would be running the appliance controller off a standard DC PSU along with an auxiliary feed input. IMO currently the board only costs a few percent of the overall retail price.
  • 14rhb
