Arduino Projects
Arduino Projects
Blog Simple thermometer using Arduino Micro and OLED display
  • Author Author: fvan
  • Date Created: 4 Jul 2015 11:27 AM Date Created
  • Views 3825 views
  • Likes 9 likes
  • Comments 14 comments
  • oled
  • micro
  • tmp36
  • adafruit
fvan
fvan
4 Jul 2015
A colleague recently made an Arduino-based thermometer to measure how hot it gets in the office. I thought I'd recreate and document the project with the components I have at hand image
Circuit
The circuit is based around the TMP36 temperature sensor. It's cheap, easy to use and doesn't require any external calibration. The voltage output is linearly proportional to temperature in degrees Celsius, making the conversion easy to calculate.
Any Arduino or microcontroller having at least one analog input pin can be used to make the reading. Finally, some form of display is required. This could be a 7-segment display, a character LCD or even an OLED display.
I'll be using an Arduino Micro combined with a small OLED display.
The resulting circuit is the following:
Code
The temperature sensor can be used without any additional libraries, the analogRead() function and some math will do the trick.
The OLED display however, requires two libraries:
  • Adafruit GFX: core graphics library
  • Adafruit SSD1306: library for monochrome OLED displays based on SSD1306 drivers
The completed code looks as follows (comments in the code for explanation):
Result
Now I finally know how hot it is in my room ... Outside temperature is not bad either image
Extra
As requested in the comments, I have made an updated version of the above project. It includes a button to toggle between degrees C, F and K.
All temperatures are calculated, and a button connected to an interrupt pin is used to toggle the displayed value.
The updated code:
Some pics:
  • fvan
    fvan over 11 years ago +3
    Added a button linked to an interrupt to toggle the displayed value between degrees C, F and K. Updated the post above
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +2
    Its all in the software so you can have it show in any unuit you prefer, Kelvin anyone
    Jan Cumps over 11 years ago in reply to clem57 +2
    ... and for doing that in these harsh hot conditions!
    Its all in the software so you can have it show in any unuit you prefer, Kelvin anyone image
    balearicdynamics over 11 years ago in reply to clem57
    Maybe only a question of visualisation conversion Clem, I think.
    Enrico
  • clem57
    clem57 over 11 years ago
    Can this show F degrees? Maybe a button for other countries like US.
    Clem
    DAB over 11 years ago
    Outside is too hot for me.
    I prefer your room temperature, which is at least comfortable.
