Arduino Tutorials
  • Arduino Tutorials
Arduino Tutorials
Forum weighting scale sync/connected to Android Application
Join Arduino Tutorials to participate - click to join for free!
  • Subscribers 26 subscribers
  • Views 2904 views
  • android and iot developer
deliotablang
deliotablang over 5 years ago
Hello im new here, do you have idea or what things are needed to connect a Android Application(mobile software) to weighting scale. what hardware/stuff are needed. thanks in advance
  • milosrasic98
    milosrasic98 over 5 years ago +4 suggested
    Hi, On the hardware side, you will need something like an Arduino with WiFi (some of MKR or Nano33 series for example), or ESP8266,or Raspberry, or something other that can connect to the internet. You…
  • deliotablang
    deliotablang over 5 years ago in reply to milosrasic98 +1
    im little bit unfamiliar with some stuff tho, but this is so informative and helpful, and i actually check your blogs/ projects you got a cool stuff out there thanks lot..
  • milosrasic98
    0 milosrasic98 over 5 years ago
    On the hardware side, you will need something like an Arduino with WiFi (some of MKR or Nano33 series for example), or ESP8266,or  Raspberry, or something other that can connect to the internet. You can also go the route of using a Bluetooth module like a HC05. These are only some of the options, there are much more of course. For the sensor itself, you can find scale sensors with a HX711 amplifier circuit.
    On the software side, you can go with Blynk from the playstore or some app that focuses on reading data from Thingspeak. Or you can make your own easily using MIT App Inventor II.
    I did a project where I uploaded scale weight data to an app I made, I went step by step for everything in this blog: S.H.E.L.F. V2 .
    I think you will find everything you need there, but, if you just want to read scale data, you can also use Blynk, which is an easy way of getting something like an Arduino to talk to an app in which you have drag n drop elements. You can find a lot of tutorials on that on YouTube, I played a bit with that, you might find it useful: Ski Lamp
    Hope this helps!
    Milos
  • deliotablang
    0 deliotablang over 5 years ago in reply to milosrasic98
  • milosrasic98
    0 milosrasic98 over 5 years ago in reply to deliotablang
    Thanks! If you're unfamiliar with something or have any questions, feel free to reach out, in the comment above are just a lot of stuff put into a short form factor, the blog should be a bit more thorough.
    Milos
  • bizzlance
    0 bizzlance over 5 years ago
    For weighing scale sensor to adapt and sync with Android or iOS app, u need sensor, sensor data filter, controller card, bluetooth sensor signal feeder/receptor, Android app in programming.... That's all...keep me posted
