Arduino Forum Is it possible to transmit and receive smell?
  • Replies 48 replies
  • Subscribers 428 subscribers
  • Views 6186 views
  • smell-o-vision
  • electronic_smell_sensor
  • odor
  • mission odor electronics
  • smell
dixonselvan
dixonselvan over 10 years ago
Odor electronics a possible extension to the current electronics world that would revolutionize the entertainment & safety domains. The integration of odor into the electronic world has only attempts with some success. Also there has been some products in the market.
Help me in the progress by your valuable comments below. Share me your experience if you have any image
I was able to collect and machine learn smell information and replicating the same in my bachelor's degree project, which I will be posting here soon.
I couldn't find time to recover my bachelor's degree project where I had used MATLAB's machine learning package. But I was able to remodel the whole system and using AWS Machine Learning service and Arduino MKR1000, I have developed a much similar project. The details of the same are posted here - Cue System for Anosmia and Smart WheelChair #11 - Machine Learning and Demo [Completed] and here - Cue System for Anosmia and Smart WheelChair #10 - Gas Sensors and Machine Learning in the 'Design for a Cause' design challenge space.
Message was edited by: Dixon Selvan
  • johnbeetem
    johnbeetem over 10 years ago in reply to dixonselvan +7
    Dixon Selvan wrote: Paul Ellison wrote: I've been known to build devices that transmit a burning smell... Could you be more elaborate like what does your burning smell refer to I think…
  • COMPACT
    COMPACT over 10 years ago +5
    Another alternative is to hook up a variety of capacitors, resistors and ICs at the transmitter end and have a matched pair at the receiving end. For the resistors you can pump in enough power for them…
    dougw over 10 years ago in reply to dixonselvan +5
    Esters with low molecular weight often have fragrant odours and are commonly used as fragrances, perfumes, essential oils, food flavourings, cosmetics, etc. Usually, esters are derived from a carboxylic…
    Usually, esters are derived from a carboxylic acid and an alcohol such as glycerol.
    The first ester I ever made in a chemistry lab smelled exactly like maraschino cherries.
    Here is small table of possible combinations I found on the net:
    Doug
    • Vote Up +5 Vote Down
  • dixonselvan
    dixonselvan over 10 years ago in reply to dougw
    Thank you so much Doug for your help image
  • D_Hersey
    D_Hersey over 10 years ago
    The Harvard Professor Who Is Digitizing Scent | Co.Design | business + design
  • COMPACT
    You can produce a stinky and poisonous smell (Hydrogen Sulphide) from lead acid batteries by the transmission of electrical power.
    e14 Contributor over 8 years ago
    I remember seeing seeing a smellyvision project about 15 years ago where smell data would potentially be transmitted along with image and sound data to television sets. Compatible sets would have 3 bottles of gas which would be mixed and aerated in different quantities to produce a wide range of smells. There was a working prototype but I don't think it made it into the market, one of the main drawbacks would be consumers having to regularly replenish the gas bottles.
    Its not the first time this has been tried with television either, there were attempts first made during the 1950's but they never seemed to take off.
    dougw over 8 years ago in reply to dixonselvan
    One of the best technologies for detecting and analyzing different "smells" is ion mobility spectroscopy (IMS). A single sensor can identify a wide range of airborne materials.
  • tonygo
    tonygo over 8 years ago
    I remember a piece about Epson giving it a trial but it never came to anything. This gives some ideas https://www.newscientist.com/article/mg20827834-500-with-this-printer-what-you-see-is-what-you-smell/
  • neuromodulator
    neuromodulator over 8 years ago
    Smell is the perception of odorants, or airborne chemicals that an olfactory system can detect. There are many difficulties when it comes to representing all possible combinations we can detect. Different humans express different kind of olfactory receptors (olfactory transducers), each human has different olfactory capabilities (put differently, some smells may not be detected the same way (or detected at all) between different humans).  There are hundreds of ORs (olfactory receptors) that a human can express (produce),  each OR gets activated by multiple chemicals. Each ORN (olfactory receptor neuron) expresses a single OR and a single chemical is encoded as a linear combination of ORN activity. Ideally one would want to be able to activate each OR individually, then with a bank of hundreds of chemicals one would be able to simulate each odour, but that's not possible because chemicals activate combinations of ORs. A more practical approach may take fewer odorants which could be combined together to generate a much wider amount of odors, but I'm not sure how many "common" odors could be generated or approximated in this way.
