Arduino Forum I want to design a low cost Data acquisition system for the Piezoelectric accelerometer.
  • Subscribers 413 subscribers
  • Views 2501 views
  • acquisition
  • accelerometer
  • daq
  • microcontroller
  • teensy
  • adc
  • sensor
rahuliitr
rahuliitr over 3 years ago
I want to design a low cost Data acquisition system for the Piezoelectric accelerometer. I am new in it. I have some idea that we can make a DAQ by using ADC and teensy microcontroller board and ADC should have high sampling rate (>1Msps). but i have no idea which ADC should I purchase and how to design it. If someone help me regarding this I will be thankful to you.
    michaelkellett over 3 years ago +1
    It would be better if you explained what you want to achieve rather than suggesting some parts. Thing you need to consider are: frequency range dynamic range maximum recording time operating…
    frequency range
    dynamic range
    operating temperature range
    If you know the type of accelerometer you will use and describe the application a bit it will help.
    Typical commercial systems for accelerometers use 24 bit sigma delta ADCs with sampling rates at approx 250ks/s for 100kHz bandwidth.
    Faster systems exist but are very unusual.
    Do you want to make your own to save money or for performance reasons ?
    There was a recent review on E14 of a Pi Hat which did a reasonable job in this area.
    Jan Cumps over 3 years ago in reply to michaelkellett
    /products/roadtest/rt/roadtests/564/digilent_mcc_172_iep#pifragment-4106=9&pifragment-4100=4
  • rahuliitr
    rahuliitr over 3 years ago in reply to michaelkellett
    Thank you for your reply.. Actually I have piezoelectric accelerometer. I need to characterize this accelerometer and acquire the data. I have signal conditioning circuit also. Only I need to design my own low cost DAQ. By which I can sample the signal upto 15khz and acquire the data and process the data.
  • charlieo21
    charlieo21 over 3 years ago
    I think it's going to be hard to achieve a low cost DAQ and also achieving 1MSPS sampling rate.
    michaelkellett over 3 years ago in reply to rahuliitr
    How are you planning to characterise the accelerometer ?
    Is this a one off application, a hobby project, a study project or a plan for a product.
    Unless you give us a good deal more detail about the problem it isn't possible to make sensible recommendations.
    Some more blogs about the piezo disk topic
    With Michael's front end:
     Piezo disk as Vibration Sensor: input buffer and filter
    With an iffy protection circuit:
     The Predictive Maintenance Tale
     RE: The Predictive Maintenance Tale - piezo element voltages
