Arduino
Arduino
Documents Arduino Accessories Wishlist and Giveaway
  • Author Author: dychen
  • Date Created: 28 Apr 2022 3:45 PM Date Created
  • Last Updated Last Updated: 23 Mar 2023 3:22 PM
  • Views 65040 views
  • Likes 9 likes
  • Comments 38 comments
Arduinos are some of the most popular microcontrollers around. With the availability of different kinds of Shields (circuit boards that plug into the Arduino to give it more functionality), an Arduino can be made to do pretty much anything. In this wishlist, we cover some of accessories you need to get started with Arduino, and some of the ones we think are just plain cool!
Arduino Wishlist Giveaway
5 winners will win an Arduino UNO R3. In order to win, answer these questions in the comments section below:
- What are some of the coolest things you've built with Arduino? Bonus points for pics!
- Tell us what we missed!  What are some of the things you'd recommend for working with Arduino?
Terms:
Post your answers as a comment below between May 2, 2022 and June 13, 2022.
Our favorite answers will be chosen by the element14 community team, and you will be shipped your prize (or local equivalent) free of charge.
Arduino UNO R3
There are several models of Arduino in different sizes and functionality, including the Portenta and Nano models, which feature modern connectivity options.  In this wishlist, however, we're taking a look at R3 compatible accessories. R3 is the 3rd revision of the Arduino UNO, which added a few new pins along with various other changes.
Arduino UNO
Buy Now
Accessories
LEDs are useful for any Arduino projects, whether they're used for testing or part of the final design.
Bi-color LED
Buy Now
A breadboard eliminates the need for soldering, making it easy to wire things up.
Breadboard
Buy Now
A small breadboard comes in handy for projects that require portability, such has portable devices or wearables.
Small breadboard
Buy Now
With Arduinos, the fun starts when you start stacking shields. This stackable header kit gives you more space for stacking.
Stacking Headers
Buy Now
Shields and Modules
PowerBoost 1000
This battery add-on provides power for portable projects and works not only for Arduino, but also SBCs like Raspberry Pi and Beaglebone. It can even keep the project running while recharging.
Powerboost shield
 Buy Now
Wi-Fi Bundle
This bundle includes a Wi-Fi shield so you can connect your project to the Internet, as well as capacitive touch slider display, accelerometer, and flexible powering options.
WiFi shield bundle
 Buy Now
Ethernet Shield
Connect your Arduino application to the Internet with an Ethernet Shield.
Ethernet Shield
Buy Now
Ethernet and PoE Shield
A shield providing Power over Ethernet (PoE) is also available.
Ethernet Shield with PoE
Buy Now
IoT Module
An IoT module lets Arduino developers quickly build IoT applications and connect to the cloud without the steep learning curve.
IoT Module
Buy Now
NFC/RFID Shield
Add NFC (nearfield communication) and RFID capabilities to your Arduino project with this shield from adafruit.
NFC RFID Shield
 Buy Now
Secure IoT Shield
With so many modern devices making wireless connections and passing data back and forth, security becomes an important consideration. This  shield provides a plug and play solution for secure connectivity with proven hardware-based security algorithms.
Secure IoT Shield
Buy Now
LCD Shield
LCD screens are great for simple texting, such as outputting text messages and simple animations.
LCD Shield
Buy Now
3D Tracking and Gesture Sensor
This gesture sensor detects everything from taps and swipes to drawing in the air, creating new possibilities for different things you can do.
Buy Now
Voice Recorder Module
This Voice Recorder Module gives an Arduino record capability. It supports 40 minutes of voice recording and can even work without a controller; just use the on-board record and play buttons.
 Buy Now
9 Axes Motion Shield
Applications involving health and fitness, as well as automotive or industrial, require motion analysis. A motion shield provides an accelerometer, gyroscope, and magnetometer, covering pretty much every movement.
Buy Now
Ultrasonic Ranging Sensor
This sensor uses ultrasonic waves to determine how far away an object is (up to 4 meters).
Ultrasonic Sensor
Buy Now
Wurth Sensor Shield
This shield offers plug and play compatibility with Wurth's sensor EVAL boards, as well as any sensor with an I2C or SPI interface.
Sensor Shield
Buy Now
Weather Shield
With its integrated pressure, humidity, and temperature sensors, this shield gives Arduino weather and environmental detection capabilities.
Weather Shield
Buy Now
Arduino Sensor Kit
This sensor kit from Arduino includes a base board and a variety of sensors (light, sound, air pressure, temperature, and accelerometer). It also includes an OLED screen, as well as guided lessons introducing users to Arduino development. For someone just getting started with Arduino, this kit contains all the basics.  Just add an UNO and jump in!
Sensor Kit
Buy Now
Motor Control Shield
A motor control shield enables Arduino to control motors. This shield lets you drive two DC motors, controlling the speed and direction of each one independently, with each channel supplying 2A.
Motor Shield
Buy Now
If you need larger motors, this shield lets you control one bi-directional DC motor or two uni-direction DC motors at a typical nominal current of 7A.
Motor Shield
Buy Now
I/O Shield For Arduino
This versatile board adds 6 analog I/Os, 6 digital I/Os, and 6 relay outputs to Arduino.
IO Shield
Buy Now
ChronoDot Real Time Clock (RTC) Module
This highly accurate clock module drifts less than a minute a year, and works great for time critical projects that can't be synchronized to an external clock.
Clock Shield
Buy Now
  • shield
  • accessories
  • wish list
  • Workshopshed
    Workshopshed over 4 years ago +3
    I've built a few different things with Arduino tech. A binary USB keyboard A Topsy Turvy Clock A Knife Switch (with a remote control switch designed for a Pi) A Jumbo Servo My ideal accessory…
  • colporteur
    colporteur over 4 years ago +2
    That is a pretty comprehensive list of items to support an Arduino. I find a MOSFET module to interface the low voltage of the Arduino to a higher voltage a very useful kit. My Arduino project…
  • rsc
    rsc over 4 years ago +2
    Screw terminals are useful sometimes. https://vetco.net/products/screw-terminal-shield-for-arduino-d30
  • skruglewicz
    skruglewicz over 4 years ago in reply to skruglewicz
    All right ....I've been informed I'm one of the 5 winners. I would be interested in knowing who the other winners are?
  • skruglewicz
    skruglewicz over 4 years ago in reply to dychen
    Thank you for your quick response. I know your all swamped with activities on the community. This was a super informative whish list.
  • dychen
    dychen over 4 years ago in reply to skruglewicz
    Yes, winners selected...I will be reaching out to everyone this week.  We got a lot of great responses...thanks to everyone for posting!
  • skruglewicz
    hello dychen
    Just interested to know the status of this Wishlist? have the winners been selected? I never received any notification and I have all my notification for this document ON as far as I can tell.
    skruglewicz
  • colporteur
    colporteur over 4 years ago in reply to redcharly
    I visited your candle link and would like to compare your design with the others I am using. I like your tier approach to the LEDs.
    The link contains overview details I require more information. Would you be willing to share the schematic and code for the design?
  • redcharly
    redcharly over 4 years ago
    One of the most beautiful projects I've done is the one I published some time ago, Candle in the wind .
    It was important to me as it came from a conversation with my 4 year old son about the flames and their "seeming alive".
    In the blog there is a video with the results obtained.
    Among the sensors that we can easily connect to an Arduino, I would like to mention the heart rate and Blood Oxygen sensor which, since the advent of Covid, have become very popular in our homes.
    I proposed it to my students and they were very impressed with how it works.
  • me_Cris
    me_Cris over 4 years ago
    I think educational expansion boards are welcome, such as those for Arduino Uno or Mega that contain multiple hardware components (push buttons, different sensors, displays and so on). There are also many projects on the internet with CNC machines, so quite a few shields of this kind are used. I would mention three more shields, one that contains 24V relays, a Wi-Fi module model with ESP8266, and a DC motor driver with L298p and buzzer. In the end, it all depends on the complexity of the project we are proposing and what we as users can afford.
    https://www.optimusdigital.ro/en/arduino-shields/3756-4-relay-shield-for-arduino.html
    https://www.optimusdigital.ro/en/brushed-motor-drivers/788-shield-driver-de-motoare-dual-l298p-smd-cu-buzzer.html
    https://www.optimusdigital.ro/en/arduino-shields/4360-shield-wifi-pentru-arduino-cu-esp8266.html
  • skruglewicz
    I’ll try to answer the following questions posed for the Arduino Wishlist giveaway. There are a lot of nice Accessories listed in this document. Some I knew about and some are new and are now on my Arduino Wish list. I have several Arduino MCU’s but do not own an UNO. I would love to add this to my collection and be able to experiment with it.
    In answer to the First question “What are some of the coolest things you've built with Arduino?”
    I was lucky enough to get supplied with 3 Arduino MCU’s (2x MKR WAN 1300 and 1x Nano 33 IoT ) and  some really cool accessories for two element14   Design Challenges  that I competed in. I also purchased some accessories directly from Arduino USA. The Challenges are  Just Encase & Design For A Cause 2021
    Both of these challenges were very cool, but if I had to pick one, I’d say that the Just Encase 5 blog series was the coolest.
    The design uses 3 pieces to report environment information up to the cloud. A Lora Collector, a Lora Receiver and the Arduino IOT Cloud.
    • The 1st Lora WAN Collector
      • This circuit contained a temperature sensor and an OLED display connected to the MKR WAN 1300, to record the temperature in the room. The data is sent to the second MKR WAN 1300 Lora receiver described below.
      •  image
    • The second collector LoRa WAN collector
      • This circuit  contains a MKR WAN 1300 attached to an MKR Connector Carrier. Some of the Groove Kit sensors (LCD display, Temperature, Dust and Water,) are attached to record weather conditions. The data is sent to the second MKR WAN 1300 Lora receiver described below.
      •  image
    • The LoRa receiver/Cloud Uploader
      • This Receiver utilizes the other MKR WAN 1300 to receiver data from the sending MKR WAN 1300. The data received is sent over a serial line to the Nano 33 IOT .. The data is sent via a Wi-Fi connection up the The Arduino cloud..
      • image
    I had a blast working with LoRa WAN tech for this Design Challenge and I utilized all three MCUs. Here is a link to my Introduction blog, If anyone is interested.  Blog#1 My Idea (Case Enclosure Reliability Monitor)
    I also had neat accessories like these to play with.
    • Seeed Studio Grove Starter Kit
    • Adafruit 642 Digital Temperature Sensor
    • Adafruit 412 Servo Motor
    • I purchased these additional accessories for my project
    • 2 LoRa antennas  Dipole Pentaband Waterproof Antenna from the Arduino
      • image
    • and a Arduino MKR Connector Carrier
      • image
    For the second challenge, "Design For A Cause 2021", I was supplied with the Arduino Nano 33 IoT MCU, which I also used in the Just Encase design challenge. I came up with idea of using the Nano 33 IoT to design and Implement a Heart Beats Per Minute reading device.  Here is a link to my Introduction blog, If anyone is interested. BLOG# 1 - Beats Per Minute Nano - INTRODUCTION. Here is a video of the project in operation
    In answer to the Second question “Tell us what we missed!“
    • A few accessories that were not mentioned are
    • Arduino MKR Connector Carrier
      • image
    • Arduino Opla Kit
      • image
    • Arduino Student Kit Code: AKX00025  /  Barcode: 76300492026
      • image
    • Arduino MKR ETH Shield
      • image
    • Arduino MKR CAN Shield
      • image
    • Arduino MKR 485 Shield
      • image
    • Arduino MKR Motor Carrier
      • image
    And finally to the Last question “What are some of the things you'd recommend for working with Arduino?”
    • I’ve used the Arduino IDE which I’m sure everybody has.
      • image
    • I’ve also used the Arduino IoT cloud, with much success. If you haven’t tried it yet, I highly recommend it
      • image
    • For development, I’ve also used Microsoft Visual Code
      • image  Download Visual Studio Code - Mac, Linux, Windows
    • along with the PlatformIO. IDE
      • image
      • GET IT HERE
      • This environment runs both on Windows and Linux. I also like to use it on my Raspberry Pi’s. If you have not used it yet for Arduino, you should give it a try. It’s a Professional collaborative platform for embedded development.. Really nice.
    This concludes my answers to the question asked to qualify for the Arduino Wishlist Giveaway. I Hope I qualify for the prize of an Arduino UNO R3.
    Cheers Everyone.
    Stephen Kruglewicz
  • Kreekplayz
    Kreekplayz over 4 years ago
    Ans - 1: I built with ardiuno ' A Sensor Train ' for avoiding train accident.
    Ans -2 : Ardiuno should have a tiny camera for making a spy rattle camera. image
  • Kreekplayz
    Ans -2 : Ardiuno should have a tiny camera with motion tube for making a spy rattle camera.
