Avnet Boards General Serial device not recognized by zedboard
  • Replies 8 replies
  • Subscribers 372 subscribers
  • Views 1322 views
  • zedboardcmty
david131
david131 over 6 years ago
Hello!
I need your help, recently I have installed Ubuntu 18.04 on my zedboard but I cannot make work a serial device connected to the USB OTG port. When I connect a pen drive, wireless keyboard or wireless wifi adapter, everything works well, but when I connect a device which must be seen as a "tty", nothing appears. The device is listed with the command "lsusb" but no UART port appears.
Do I have to configure something? What am I missing?
Thank you very much.
  • drozwood90
    drozwood90 over 6 years ago
    Hi there,
    Shooting in the dark - as we do not support Ubuntu - but are you sure there are drivers installed in your OS?  If it is showing up with LSUSB but the port doesn't appear, sounds like a driver issue to me.
    --Dan
  • david131
    david131 over 6 years ago in reply to drozwood90
    Yes, maybe there is a problem with drivers but for me is extrange that other USB devices work except which have to use the serial port... I downloaded the ubuntu image from here: https://www.digikey.com/eewiki/display/linuxonarm/Zynq-7000#Zynq-7000-Ubuntu18.04LTS
    Thank you!
  • drozwood90
    drozwood90 over 6 years ago in reply to david131
    Hi there,
    Thanks for sharing.  That is really interesting.  This has nothing to do with your solution, but since we have had some dealings with Ubuntu under PYNQ, I'm curious, why are you using Ubuntu vs PetaLinux?  I know we used it because of PYNQ.
    --Dan
  • david131
    Only because I already had some code made in Ubuntu with two libraries, gpgme and libcurl, and I didn't know if the program I made would be compatible with petalinux. So Ubuntu was the obvious choice for me.
  • david131
    So, the only thing I want to do is connect an Arduino to send and receive data through the USB-OTG port, or is there another solution or port to do that?
    Thanks in advance!
  • drozwood90
    Hi there,
    Sounds like there is a driver issue.  If you can't get around the driver over USB, you could in the PetaLinux flow easily add a serial port into the PL and then use that as an actual SERIAL port, not a virtual port over USB.
    However, I can't support Ubuntu, I'm not sure that flow you posted supports this.
    You might have good luck searching the web for others that have tied their Arduino to an Ubuntu PC and leverage that to get this to work?  You mentioned that this shows up in lsusb, so I assume with a driver you'd be all set.
    --Dan
  • david131
    Hi! Thank you for your answer, but finally I need the virtual com port working. If I execute the command "usbserial" it gives the error "command not found". And it seems that in the kernel there are not included the VCP drivers. So how can I compile those drivers?
    If that can be done under petalinux, is there any image with VCP drivers included? Or any tutorial?
    I am new with zedboard and I am a bit lost.
  • drozwood90
    Hi there,
    You'll have better luck with ZedBoard support over at the Digilent forums.
    https://forum.digilentinc.com/forum/
    --Dan
