Software Application Development standalone OS  reference design problem
  • Replies 7 replies
  • Subscribers 364 subscribers
  • Views 763 views
triacs
triacs over 9 years ago
I am trying to run the Zynq standalone OS embedded reference design on my MMP 7z045 eval board. In the Version 1 Aug 2015 instructions titled "Avnet Zynq Mini Module Plus Embedded Design", in section 7.3 Running the Memory Test, after I do the Run As > launch on Hardware GDB, I get SDK Application launcher window that says "Launch Failed, Binary not found. I followed all the instructions up to this point as written. Don't know what the problem is.
  • jafoste4
    0 jafoste4 over 9 years ago
    Hi Triacs,
    Take a look at this post https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Xilinx-SDK-error/td-p/441406
    Typically when you get that error message it is refering to it not seeing you Bitsteam file. Just to double check you had the blue Done Led on when you went to run the application on your board correct.(See step 7.1) That is the step we program your bit file into your FPGA. Also look at the post above and try going through their trouble shooting suggestions.
    --Josh
  • triacs
    0 triacs over 9 years ago in reply to jafoste4
    The bit file was being loaded correctly, it showed me percentages, and then purple done LED went on.  I then tried opening SDK and repeating section 7.2 Setting up the Run configurations, but I could not click on apply after setting the initialization file (which already pointed to the correct ps7_init.tcl file), cause the apply button was greyed out.
  • jafoste4
    Hi Triacs,
    Just to double check, you are using Vivado 2015.2 and SDK 2015.2 correct? And when you say your apply was already greyed out are you also indicating that your initialization file was already set to "\zynq_mmp_embedded_design\embedded_design.sdk\zynq_design_1_wrapper_hw_platform_1\ps7_init.tcl"
    Also for sanity check your boot configurations (SW5) is set to JTAG Boot correct "00000"?
    Also try using the System Debugger, do so by following these steps.
    1.Program the bit file into your FPGA(section 7.1) and make sure the Blue led is on.
    2. Right click on your application then go Run as --> Run on hardware(System Debugger)
    let me know if your application runs or if you still have the same error.
    --Josh
  • triacs
    I am running Vivado 2015.4. When I opened it it asked me if I wanted to upgrade the project, and I said yes. Yes, my init file already pointed to the correct path. (From previous running the project I assume). I'll try the System Debugger as you suggest.
  • jafoste4
    Hi Triacs,
    Please try using Vivado/SDK 2015.2, I have a feeling that will solve your issue. The documentation/project are targeted for 2015.2. Vivado/SDK tend to change ever so slightly from version release to version release. Things update and tend to break older designs. This is why we try to have multiple version release for each reference design/tutorial we offer.
    --Josh
  • triacs
    I'll download 2015.2, but first I wanted to try the last thing you suggested. I right clicked on zynq_mmp_mem_test, and selected run as Launch on Hardware (system debugger).
    In the SDK window I got
    15:23:42 **** Incremental Build of configuration Debug for project zynq_mmp_mem_test ****
    make all
    make: Nothing to be done for `all'.
    15:23:42 Build Finished (took 128ms)
    Then it said Selected debug session already exists, Do you want to relauch the application. I said ok. Then about 10 seconds later:
    Voila, it worked. I got a message on my realterm that said memory test passed.
    To see what would happen if I repeated what the instructions said "Run As > Launch on Hardware (GDB)", even that works now. What do you think was causing my original problem?
  • jafoste4
    Hi Triacs,
    I am not sure. Maybe it was an issue with the configurations or a SDK bug, or even a JTAG connection issue? I am glad your issue appears to be resolved now.
    --Josh
