Ultra96 Hardware Design controller
  • Subscribers 365 subscribers
  • Views 926 views
controller
iwao
iwao over 6 years ago
ON/OFF CONTROLLER"SLG4G42480V" is on board.
I have searched Its datasheet through web, but I cannot find it.
So, please tell me where the datasheet is.
And it seems difficutl to buy.
Can it be replaced with other parts?
best regards, thank you
    michaelkellett over 6 years ago +1
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&ved=2ahUKEwiAkYicn9vnAhWCi1wKHe0dDbQQFjAIegQICRAB&url=ht… All you need to do is Google the part number, 9th hit (to the Ultra 96 documents…
  • bhfletcher
    bhfletcher over 6 years ago +1 verified
    It is a programmable device which we custom designed for Ultra96-V2. Please read this blog for more information. Zynq UltraScale+ PMU and the Ultra96-V2 On/Off Controller You can buy this as a pre-programmed…
    0 michaelkellett over 6 years ago
    All you need to do is Google the part number, 9th hit (to the Ultra 96 documents page) gets you there.
    It's a part made by Dialog Semiconductor but a search on their website does not find it !
    The data sheet is dreadful - actually beyond dreadful.
    This is the complete general description:
    Dialog SLG4G42480 is a low power and small form
    device. The SoC is housed in a 2mm x 2.2mm
    STQFN package which is optimal for using with
    small devices.
    I suggest you don't use it if you are starting a new design. if you need a spare then you'll need to contact Dialog or look on the grey market.
    I think it's a pre-programmed part originally made by Silego and marketed under the Generic name of GreenPAK. Dialog bought Silego but don't seem to making a good job of running it. If you search for GrrenPAK on Dialog's website you'll get further. Farnell list many parts but don't have any stock.
    Good luck.
  • bhfletcher
    0 bhfletcher over 6 years ago
    You can buy this as a pre-programmed part, but the MOQ is 3K. However, you can work with your local Avnet FAE to have proto quantity samples provided to you.
    Bryan
  • iwao
    0 iwao over 6 years ago in reply to bhfletcher
    Thank you for your reply.
    I will try to contact to Avnet.
