ZedBoard Hardware Design Ubuntu 12.04 to 14.04
  • Subscribers 359 subscribers
  • Views 706 views
Is it possible to upgrade the Xillinux to the ubuntu 14.04, because the version I am using is the ubuntu 12.04.
When I try to upgrade it is show: "No new release found"
It is because I wants to connect my zedboard with a dongle wifi, and it isn't working. The drivers are installed, but it is not working. Can someone help me?
Thanks in advance.
    Upgrading Xillinux to another Ubuntu installation isn't possible, because it's not a "native" Ubuntu version -- some crucial adaptions will be deleted during an upgrade.
    You were lucky to be refused: Others who attempted the same thing got their installation messed up.
    As for the dysfunctional dongle -- more information is needed: Are there any clues in /var/log/syslog? Please copy-paste the response to a dongle insertion, at least. What is the nature of the problem?
       Eli
    good
    Dear Eli,
    Here is the log:
    [    1.524745] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 82, base_baud = 3124999) is a xuartps
    [    1.528357] console [ttyPS0] enabled, bootconsole disabled
    [    1.534514] xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to e0864000
    [    1.556835] brd: module loaded
    [    1.565388] loop: module loaded
    [    1.575562] xqspips e000d000.ps7-qspi: master is unqueued, this is deprecated
    [    1.583082] m25p80 spi0.0: found s25fl256s1, expected n25q128
    [    1.588962] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
    [    1.593884] 5 ofpart partitions found on MTD device spi0.0
    [    1.599303] Creating 5 MTD partitions on "spi0.0":
    [    1.604169] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    [    1.611155] 0x000000100000-0x000000600000 : "qspi-linux"
    [    1.617587] 0x000000600000-0x000000620000 : "qspi-device-tree"
    [    1.624536] 0x000000620000-0x000000c00000 : "qspi-rootfs"
    [    1.631006] 0x000000c00000-0x000001000000 : "qspi-bitstream"
    [    1.637789] xqspips e000d000.ps7-qspi: at 0xE000D000 mapped to 0xE0866000, irq=51
    [    1.647706] libphy: Fixed MDIO Bus: probed
    [    1.653585] libphy: XEMACPS mii bus: probed
    [    1.658544] xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
    [    1.666617] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.673216] ehci-pci: EHCI PCI platform driver
    [    1.678192] ULPI transceiver vendor/product ID 0x0451/0x1507
    [    1.683796] Found TI TUSB1210 ULPI transceiver.
    [    1.688293] ULPI integrity check: passed.
    [    1.692533] xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
    [    1.699316] xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
    [    1.733673] xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
    [    1.753654] xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
    [    1.760566] hub 1-0:1.0: USB hub found
    [    1.764289] hub 1-0:1.0: 1 port detected
    [    1.768786] usbcore: registered new interface driver usb-storage
    [    1.775625] mousedev: PS/2 mouse device common for all mice
    [    1.781689] i2c /dev entries driver
    [    1.785947] IR NEC protocol handler initialized
    [    1.790389] IR RC5(x) protocol handler initialized
    [    1.795200] IR RC6 protocol handler initialized
    [    1.799660] IR JVC protocol handler initialized
    [    1.804232] IR Sony protocol handler initialized
    [    1.808784] IR RC5 (streamzap) protocol handler initialized
    [    1.814351] IR SANYO protocol handler initialized
    [    1.819033] IR MCE Keyboard/mouse protocol handler initialized
    [    1.825742] xadcps f8007100.ps7-xadc: enabled:tyestreference:texternal
    [    1.832765] zynq-edac f8006000.ps7-ddrc: ecc not enabled
    [    1.838349] sdhci: Secure Digital Host Controller Interface driver
    [    1.844469] sdhci: Copyright(c) Pierre Ossman
    [    1.848782] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.854570] mmc0: no vqmmc regulator found
    [    1.858588] mmc0: no vmmc regulator found
    [    1.862588] mmc0: Invalid maximum block size, assuming 512 bytes
    [    1.903655] mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
    [    1.916852] usbcore: registered new interface driver usbhid
    [    1.922363] usbhid: USB HID core driver
    [    1.929073] pmodoled-gpio-spi [zed_oled] SPI Probing
    [    1.987576] mmc0: new high speed SDHC card at address aaaa
    [    1.993364] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
    [    1.999170]  mmcblk0: p1 p2
    [    2.083682] usb 1-1: new high-speed USB device number 2 using xusbps-ehci
    [    2.109487] no UART detected at 0x1
    [    2.114150] TCP: cubic registered
    [    2.117394] NET: Registered protocol family 15
    [    2.121873] Key type dns_resolver registered
    [    2.126334] Registering SWP/SWPB emulation handler
    [    2.131808] registered taskstats version 1
    [    2.136250] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
    [    2.146001] ALSA device list:
    [    2.148894]   No soundcards found.
    [    2.163290] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [    2.172045] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
    [    2.195104] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.203122] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.214734] devtmpfs: mounted
    [    2.217886] Freeing unused kernel memory: 196K (c0642000 - c0673000)
    [    2.236687] hub 1-1:1.0: USB hub found
    [    2.240742] hub 1-1:1.0: 4 ports detected
    [    2.524007] usb 1-1.3: new high-speed USB device number 3 using xusbps-ehci
    [    2.714154] usb 1-1.4: new low-speed USB device number 4 using xusbps-ehci
    [    2.846773] input: RCMCU 2.4GHz receiver as /devices/amba.0/e0002000.ps7-usb/xusbps-ehci.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input0
    [    2.859122] hid-generic 0003:0C45:7000.0001: input: USB HID v1.11 Keyboard [RCMCU 2.4GHz receiver] on usb-xusbps-ehci.0-1.4/input0
    [    2.878163] input: RCMCU 2.4GHz receiver as /devices/amba.0/e0002000.ps7-usb/xusbps-ehci.0/usb1/1-1/1-1.4/1-1.4:1.1/input/input1
    [    2.890900] hid-generic 0003:0C45:7000.0002: input: USB HID v1.11 Mouse [RCMCU 2.4GHz receiver] on usb-xusbps-ehci.0-1.4/input1
    [    3.348459] udevd[801]: starting version 175
    [    4.084861] lp: driver loaded but no devices found
    [    4.154479] xillybus_core: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.384660] xillybus_of: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.436989] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437008] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437026] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437044] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437100] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437100] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437118] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437137] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437155] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437173] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437192] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437210] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437229] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437247] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437266] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437284] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437432] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437450] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437468] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437468] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437487] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.437505] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.437524] xillybus_of 50000000.xillybus: Lost sync with interrupt messages. Stopping.
    [    4.514238] ppdev: user-space parallel port driver
    [    4.533721] xillybus_of 50000000.xillybus: No response from FPGA. Aborting.
    [    4.677861] NET: Registered protocol family 10
    [    4.897130] ------------[ cut here ]------------
    [    4.897295] WARNING: CPU: 0 PID: 1258 at net/wireless/reg.c:423 regulatory_init+0x90/0x130 [cfg80211]()
    [    4.897295] db.txt is empty, you should update it...
    [    4.897314] Modules linked in: cfg80211(+) rfkill ipv6 xillybus_of(C) xillybus_lite_of ppdev xillybus_core(C) uio_pdrv_genirq lp uio parport
    [    4.897369] CPU: 0 PID: 1258 Comm: modprobe Tainted: G         C   3.12.0-xillinux-1.3 #1
    [    4.897406] [<c00143d8>] (unwind_backtrace+0x0/0xe0) from [<c0010ba8>] (show_stack+0x10/0x14)
    [    4.897443] [<c0010ba8>] (show_stack+0x10/0x14) from [<c045bdd8>] (dump_stack+0x84/0xcc)
    [    4.897461] [<c045bdd8>] (dump_stack+0x84/0xcc) from [<c0020c88>] (warn_slowpath_common+0x60/0x80)
    [    4.897498] [<c0020c88>] (warn_slowpath_common+0x60/0x80) from [<c0020d28>] (warn_slowpath_fmt+0x2c/0x3c)
    [    4.897609] [<c0020d28>] (warn_slowpath_fmt+0x2c/0x3c) from [<bf0d4160>] (regulatory_init+0x90/0x130 [cfg80211])
    [    4.897756] [<bf0d4160>] (regulatory_init+0x90/0x130 [cfg80211]) from [<bf0d4054>] (cfg80211_init+0x54/0xd0 [cfg80211])
    [    4.897848] [<bf0d4054>] (cfg80211_init+0x54/0xd0 [cfg80211]) from [<c000876c>] (do_one_initcall+0x98/0x13c)
    [    4.897885] [<c000876c>] (do_one_initcall+0x98/0x13c) from [<c0069500>] (load_module+0x194c/0x1bf0)
    [    4.897904] [<c0069500>] (load_module+0x194c/0x1bf0) from [<c006986c>] (SyS_init_module+0xc8/0xcc)
    [    4.897922] [<c006986c>] (SyS_init_module+0xc8/0xcc) from [<c000db60>] (ret_fast_syscall+0x0/0x30)
    [    4.897941] ---[ end trace dfe3d6338b56472b ]---
    [    4.897996] cfg80211: Calling CRDA to update world regulatory domain
    [    5.104565] rtl8192cu: Chip version 0x10
    [    5.276666] rtl8192cu: MAC address: e8:4e:06:11:56:d4
    [    5.276703] rtl8192cu: Board Type 0
    [    5.277164] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
    [    5.277182] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
    [    5.277201] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277219] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
    [    5.277219] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277238] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
    [    5.277256] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277256] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
    [    5.277274] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277293] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
    [    5.277293] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277311] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
    [    5.277311] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277330] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
    [    5.277348] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277367] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
    [    5.277385] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277385] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
    [    5.277404] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277422] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
    [    5.277422] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277440] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
    [    5.277440] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.277459] cfg80211: Disabling freq 2467 MHz as custom regd has no rule that fits it
    [    5.277477] cfg80211: Disabling freq 2472 MHz as custom regd has no rule that fits it
    [    5.277477] cfg80211: Disabling freq 2484 MHz as custom regd has no rule that fits it
    [    5.277569] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
    [    5.281348] usbcore: registered new interface driver rtl8192cu
    [    5.346856] rtlwifi: Firmware rtlwifi/rtl8192cufw.bin not available
    [    5.455090] cfg80211: World regulatory domain updated:
    [    5.455108] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [    5.455126] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.455126] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [    5.455145] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [    5.455145] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.455163] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.731166] NET: Registered protocol family 17
    [    5.793098] init_stage2: failsafe main process (1308) killed by TERM signal
    [    6.198256] init_stage2: atd main process (1402) terminated with status 1
    [    6.198422] init_stage2: atd main process ended, respawning
    [    8.537205] init_stage2: xillinux-sound main process (804) terminated with status 1
    My problem is how configure the wireless? Can I connect to wireless? How I do that?
    Thanks very much for every help. Apologise, but I am newer in this.
    best regards,
    Eduardo
    I correct the firmware like you said in another post. Here is the new log:
    [    1.565517] loop: module loaded
    [    1.575783] xqspips e000d000.ps7-qspi: master is unqueued, this is deprecated
    [    1.583341] m25p80 spi0.0: found s25fl256s1, expected n25q128
    [    1.589128] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
    [    1.594363] 5 ofpart partitions found on MTD device spi0.0
    [    1.599764] Creating 5 MTD partitions on "spi0.0":
    [    1.604593] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
    [    1.611597] 0x000000100000-0x000000600000 : "qspi-linux"
    [    1.618011] 0x000000600000-0x000000620000 : "qspi-device-tree"
    [    1.624923] 0x000000620000-0x000000c00000 : "qspi-rootfs"
    [    1.631393] 0x000000c00000-0x000001000000 : "qspi-bitstream"
    [    1.638213] xqspips e000d000.ps7-qspi: at 0xE000D000 mapped to 0xE0866000, irq=51
    [    1.648074] libphy: Fixed MDIO Bus: probed
    [    1.654046] libphy: XEMACPS mii bus: probed
    [    1.658931] xemacps e000b000.ps7-ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
    [    1.667096] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.673842] ehci-pci: EHCI PCI platform driver
    [    1.678616] ULPI transceiver vendor/product ID 0x0451/0x1507
    [    1.684312] Found TI TUSB1210 ULPI transceiver.
    [    1.688772] ULPI integrity check: passed.
    [    1.693012] xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
    [    1.699832] xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
    [    1.743442] xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
    [    1.763423] xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
    [    1.770353] hub 1-0:1.0: USB hub found
    [    1.774077] hub 1-0:1.0: 1 port detected
    [    1.778611] usbcore: registered new interface driver usb-storage
    [    1.785394] mousedev: PS/2 mouse device common for all mice
    [    1.791458] i2c /dev entries driver
    [    1.795734] IR NEC protocol handler initialized
    [    1.800176] IR RC5(x) protocol handler initialized
    [    1.804987] IR RC6 protocol handler initialized
    [    1.809466] IR JVC protocol handler initialized
    [    1.814019] IR Sony protocol handler initialized
    [    1.818572] IR RC5 (streamzap) protocol handler initialized
    [    1.824157] IR SANYO protocol handler initialized
    [    1.828820] IR MCE Keyboard/mouse protocol handler initialized
    [    1.835529] xadcps f8007100.ps7-xadc: enabled:tyestreference:texternal
    [    1.842534] zynq-edac f8006000.ps7-ddrc: ecc not enabled
    [    1.848118] sdhci: Secure Digital Host Controller Interface driver
    [    1.854238] sdhci: Copyright(c) Pierre Ossman
    [    1.858551] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.864357] mmc0: no vqmmc regulator found
    [    1.868375] mmc0: no vmmc regulator found
    [    1.872357] mmc0: Invalid maximum block size, assuming 512 bytes
    [    1.913442] mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
    [    1.926640] usbcore: registered new interface driver usbhid
    [    1.932151] usbhid: USB HID core driver
    [    1.940888] pmodoled-gpio-spi [zed_oled] SPI Probing
    [    1.987079] mmc0: new high speed SDHC card at address aaaa
    [    1.992885] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
    [    1.998654]  mmcblk0: p1 p2
    [    2.093451] usb 1-1: new high-speed USB device number 2 using xusbps-ehci
    [    2.119274] no UART detected at 0x1
    [    2.123974] TCP: cubic registered
    [    2.127218] NET: Registered protocol family 15
    [    2.131697] Key type dns_resolver registered
    [    2.136158] Registering SWP/SWPB emulation handler
    [    2.141632] registered taskstats version 1
    [    2.146093] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
    [    2.156267] ALSA device list:
    [    2.159143]   No soundcards found.
    [    2.166129] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [    2.174865] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
    [    2.204726] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.212762] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [    2.224632] devtmpfs: mounted
    [    2.227784] Freeing unused kernel memory: 196K (c0642000 - c0673000)
    [    2.266492] hub 1-1:1.0: USB hub found
    [    2.270657] hub 1-1:1.0: 4 ports detected
    [    2.553775] usb 1-1.3: new high-speed USB device number 3 using xusbps-ehci
    [    2.743921] usb 1-1.4: new low-speed USB device number 4 using xusbps-ehci
    [    2.866661] input: RCMCU 2.4GHz receiver as /devices/amba.0/e0002000.ps7-usb/xusbps-ehci.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input0
    [    2.879748] hid-generic 0003:0C45:7000.0001: input: USB HID v1.11 Keyboard [RCMCU 2.4GHz receiver] on usb-xusbps-ehci.0-1.4/input0
    [    2.902162] input: RCMCU 2.4GHz receiver as /devices/amba.0/e0002000.ps7-usb/xusbps-ehci.0/usb1/1-1/1-1.4/1-1.4:1.1/input/input1
    [    2.918050] hid-generic 0003:0C45:7000.0002: input: USB HID v1.11 Mouse [RCMCU 2.4GHz receiver] on usb-xusbps-ehci.0-1.4/input1
    [    3.407645] udevd[809]: starting version 175
    [    4.145706] lp: driver loaded but no devices found
    [    4.280942] xillybus_core: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.313641] xillybus_of: module is from the staging directory, the quality is unknown, you have been warned.
    [    4.324848] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324866] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.324885] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324885] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.324903] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324903] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.324922] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324940] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.324940] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324958] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.324958] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324977] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.324995] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.324995] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.325014] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.325014] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.325032] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.325032] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.325051] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.325069] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.325069] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0000000
    [    4.325088] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.325088] xillybus_of 50000000.xillybus: Lost sync with interrupt messages. Stopping.
    [    4.328811] ppdev: user-space parallel port driver
    [    4.423497] xillybus_of 50000000.xillybus: No response from FPGA. Aborting.
    [    4.509299] NET: Registered protocol family 10
    [    4.891194] ------------[ cut here ]------------
    [    4.891323] WARNING: CPU: 1 PID: 1233 at net/wireless/reg.c:423 regulatory_init+0x90/0x130 [cfg80211]()
    [    4.891360] db.txt is empty, you should update it...
    [    4.891360] Modules linked in: cfg80211(+) rfkill ipv6 xillybus_of(C) xillybus_core(C) ppdev xillybus_lite_of uio_pdrv_genirq uio lp parport
    [    4.891397] CPU: 1 PID: 1233 Comm: modprobe Tainted: G         C   3.12.0-xillinux-1.3 #1
    [    4.891453] [<c00143d8>] (unwind_backtrace+0x0/0xe0) from [<c0010ba8>] (show_stack+0x10/0x14)
    [    4.891489] [<c0010ba8>] (show_stack+0x10/0x14) from [<c045bdd8>] (dump_stack+0x84/0xcc)
    [    4.891508] [<c045bdd8>] (dump_stack+0x84/0xcc) from [<c0020c88>] (warn_slowpath_common+0x60/0x80)
    [    4.891526] [<c0020c88>] (warn_slowpath_common+0x60/0x80) from [<c0020d28>] (warn_slowpath_fmt+0x2c/0x3c)
    [    4.891637] [<c0020d28>] (warn_slowpath_fmt+0x2c/0x3c) from [<bf0d4160>] (regulatory_init+0x90/0x130 [cfg80211])
    [    4.891803] [<bf0d4160>] (regulatory_init+0x90/0x130 [cfg80211]) from [<bf0d4054>] (cfg80211_init+0x54/0xd0 [cfg80211])
    [    4.891876] [<bf0d4054>] (cfg80211_init+0x54/0xd0 [cfg80211]) from [<c000876c>] (do_one_initcall+0x98/0x13c)
    [    4.891913] [<c000876c>] (do_one_initcall+0x98/0x13c) from [<c0069500>] (load_module+0x194c/0x1bf0)
    [    4.891932] [<c0069500>] (load_module+0x194c/0x1bf0) from [<c006986c>] (SyS_init_module+0xc8/0xcc)
    [    4.891932] [<c006986c>] (SyS_init_module+0xc8/0xcc) from [<c000db60>] (ret_fast_syscall+0x0/0x30)
    [    4.891950] ---[ end trace a6b234e394a8456b ]---
    [    4.892577] cfg80211: Calling CRDA to update world regulatory domain
    [    5.118094] rtl8192cu: Chip version 0x10
    [    5.144895] cfg80211: World regulatory domain updated:
    [    5.144913] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [    5.144932] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.144932] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [    5.144950] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [    5.144950] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.144968] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.274805] rtl8192cu: MAC address: e8:4e:06:11:56:d4
    [    5.274841] rtl8192cu: Board Type 0
    [    5.275173] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
    [    5.275192] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
    [    5.275192] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275210] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
    [    5.275229] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275229] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
    [    5.275247] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275247] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
    [    5.275265] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275265] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
    [    5.275284] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275284] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
    [    5.275302] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275302] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
    [    5.275321] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275321] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
    [    5.275339] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275358] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
    [    5.275358] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275376] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
    [    5.275376] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275394] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
    [    5.275394] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.275413] cfg80211: Disabling freq 2467 MHz as custom regd has no rule that fits it
    [    5.275413] cfg80211: Disabling freq 2472 MHz as custom regd has no rule that fits it
    [    5.275431] cfg80211: Disabling freq 2484 MHz as custom regd has no rule that fits it
    [    5.275505] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
    [    5.284168] usbcore: registered new interface driver rtl8192cu
    [    5.291209] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
    [    5.460453] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
    [    5.500580] rtlwifi: wireless switch is on
    [    5.527675] rtl8192cu: MAC auto ON okay!
    [    5.585073] rtl8192cu: Tx queue select: 0x05
    [    6.141448] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [    6.279855] NET: Registered protocol family 17
    [    6.317401] init_stage2: failsafe main process (1311) killed by TERM signal
    [    6.742926] init_stage2: atd main process (1421) terminated with status 1
    [    6.743074] init_stage2: atd main process ended, respawning
    [    8.437008] init_stage2: xillinux-sound main process (805) terminated with status 1
    I need to install some application to the wifi work? How can I do to search the network and connect?
    OK, now we have something to work with.
    First of all, something is seriously wrong with the Xillybus IP core on your system. If you know why this is (changed clock frequencies, AXI bus topology etc), fine, but if not, there's something fishy going on, and it's worth attention.
    Now to the Wifi dongle: It seems like it loaded OK. Could you please supply the output of the following commands?
    ifconfig
    iw list
    iw reg get
       Eli
    It is working the dongle, here is the log:
    [    4.902641] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0050000
    [    4.902641] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.902659] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0050000
    [    4.902659] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.902678] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0050000
    [    4.902678] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.902696] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0050000
    [    4.902696] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.902715] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0050000
    [    4.902733] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.902733] xillybus_of 50000000.xillybus: Malformed message (skipping): opcode=176, channel=030, dir=1, bufno=000, data=0050000
    [    4.902751] xillybus_of 50000000.xillybus: Sending a NACK on counter 0 (instead of b) on entry 0
    [    4.902751] xillybus_of 50000000.xillybus: Lost sync with interrupt messages. Stopping.
    [    4.994286] xillybus_of 50000000.xillybus: No response from FPGA. Aborting.
    [    5.417967] NET: Registered protocol family 10
    [    5.466610] ------------[ cut here ]------------
    [    5.466776] WARNING: CPU: 1 PID: 1239 at net/wireless/reg.c:423 regulatory_init+0x90/0x130 [cfg80211]()
    [    5.466776] db.txt is empty, you should update it...
    [    5.466776] Modules linked in: cfg80211(+) rfkill ipv6 xillybus_of(C) xillybus_core(C) xillybus_lite_of ppdev uio_pdrv_genirq uio lp parport
    [    5.466831] CPU: 1 PID: 1239 Comm: modprobe Tainted: G         C   3.12.0-xillinux-1.3 #1
    [    5.466886] [<c00143d8>] (unwind_backtrace+0x0/0xe0) from [<c0010ba8>] (show_stack+0x10/0x14)
    [    5.466923] [<c0010ba8>] (show_stack+0x10/0x14) from [<c045bdd8>] (dump_stack+0x84/0xcc)
    [    5.466960] [<c045bdd8>] (dump_stack+0x84/0xcc) from [<c0020c88>] (warn_slowpath_common+0x60/0x80)
    [    5.466978] [<c0020c88>] (warn_slowpath_common+0x60/0x80) from [<c0020d28>] (warn_slowpath_fmt+0x2c/0x3c)
    [    5.467089] [<c0020d28>] (warn_slowpath_fmt+0x2c/0x3c) from [<bf0d4160>] (regulatory_init+0x90/0x130 [cfg80211])
    [    5.467236] [<bf0d4160>] (regulatory_init+0x90/0x130 [cfg80211]) from [<bf0d4054>] (cfg80211_init+0x54/0xd0 [cfg80211])
    [    5.467328] [<bf0d4054>] (cfg80211_init+0x54/0xd0 [cfg80211]) from [<c000876c>] (do_one_initcall+0x98/0x13c)
    [    5.467365] [<c000876c>] (do_one_initcall+0x98/0x13c) from [<c0069500>] (load_module+0x194c/0x1bf0)
    [    5.467384] [<c0069500>] (load_module+0x194c/0x1bf0) from [<c006986c>] (SyS_init_module+0xc8/0xcc)
    [    5.467402] [<c006986c>] (SyS_init_module+0xc8/0xcc) from [<c000db60>] (ret_fast_syscall+0x0/0x30)
    [    5.467421] ---[ end trace dc1d1dacce24acb7 ]---
    [    5.467476] cfg80211: Calling CRDA to update world regulatory domain
    [    5.654728] rtl8192cu: Chip version 0x10
    [    5.804711] rtl8192cu: MAC address: e8:4e:06:11:56:d4
    [    5.804748] rtl8192cu: Board Type 0
    [    5.805337] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1
    [    5.805374] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
    [    5.805374] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805393] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
    [    5.805411] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805411] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
    [    5.805430] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805430] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
    [    5.805448] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805448] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
    [    5.805466] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805466] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
    [    5.805485] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805485] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
    [    5.805503] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805522] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
    [    5.805522] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805540] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
    [    5.805540] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805559] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
    [    5.805559] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805577] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
    [    5.805577] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
    [    5.805596] cfg80211: Disabling freq 2467 MHz as custom regd has no rule that fits it
    [    5.805596] cfg80211: Disabling freq 2472 MHz as custom regd has no rule that fits it
    [    5.805614] cfg80211: Disabling freq 2484 MHz as custom regd has no rule that fits it
    [    5.806830] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
    [    5.811678] usbcore: registered new interface driver rtl8192cu
    [    5.838921] cfg80211: World regulatory domain updated:
    [    5.838958] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [    5.838958] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.838976] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [    5.838995] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [    5.838995] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.839013] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [    5.866772] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
    [    6.034302] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
    [    6.082336] rtlwifi: wireless switch is on
    [    6.221443] rtl8192cu: MAC auto ON okay!
    [    6.272353] rtl8192cu: Tx queue select: 0x05
    [    6.276353] init_stage2: failsafe main process (1288) killed by TERM signal
    [    6.803236] init_stage2: atd main process (1393) terminated with status 1
    [    6.803365] init_stage2: atd main process ended, respawning
    [    6.815991] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    [    7.056973] NET: Registered protocol family 17
    [    9.026136] init_stage2: xillinux-sound main process (806) terminated with status 1
    [    9.447127] wlan0: authenticate with 00:26:5b:8f:07:49
    [    9.476784] wlan0: send auth to 00:26:5b:8f:07:49 (try 1/3)
    [    9.490295] wlan0: authenticated
    [    9.494368] wlan0: associate with 00:26:5b:8f:07:49 (try 1/3)
    [    9.508930] wlan0: RX AssocResp from 00:26:5b:8f:07:49 (capab=0xc21 status=0 aid=2)
    [    9.509114] wlan0: associated
    [    9.510662] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   55.231931] wlan0: deauthenticating from 00:26:5b:8f:07:49 by local choice (reason=3)
    [   55.277182] cfg80211: All devices are disconnected, going to restore regulatory settings
    [   55.277201] cfg80211: Restoring regulatory settings
    [   55.277219] cfg80211: Kicking the queue
    [   55.277238] cfg80211: Calling CRDA to update world regulatory domain
    [   55.319982] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
    [   55.320000] cfg80211: World regulatory domain updated:
    [   55.320019] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [   55.320037] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   55.320037] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [   55.320055] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [   55.320055] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   55.320074] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   58.472545] wlan0: authenticate with 00:26:5b:f7:b2:d9
    [   58.531214] wlan0: direct probe to 00:26:5b:f7:b2:d9 (try 1/3)
    [   58.734281] wlan0: send auth to 00:26:5b:f7:b2:d9 (try 2/3)
    [   58.736088] wlan0: authenticated
    [   58.744364] wlan0: associate with 00:26:5b:f7:b2:d9 (try 1/3)
    [   58.757064] wlan0: RX AssocResp from 00:26:5b:f7:b2:d9 (capab=0xc21 status=0 aid=1)
    [   58.757285] wlan0: associated
    [  104.228374] wlan0: deauthenticating from 00:26:5b:f7:b2:d9 by local choice (reason=3)
    [  104.254732] cfg80211: All devices are disconnected, going to restore regulatory settings
    [  104.254750] cfg80211: Restoring regulatory settings
    [  104.254769] cfg80211: Kicking the queue
    [  104.254787] cfg80211: Calling CRDA to update world regulatory domain
    [  104.286103] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
    [  104.286122] cfg80211: World regulatory domain updated:
    [  104.286122] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [  104.286140] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  104.286159] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [  104.286159] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [  104.286177] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  104.286177] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  108.007686] wlan0: authenticate with 00:26:5b:f7:b2:d9
    [  108.068217] wlan0: send auth to 00:26:5b:f7:b2:d9 (try 1/3)
    [  108.090206] wlan0: authenticated
    [  108.094335] wlan0: associate with 00:26:5b:f7:b2:d9 (try 1/3)
    [  108.109339] wlan0: RX AssocResp from 00:26:5b:f7:b2:d9 (capab=0xc21 status=0 aid=1)
    [  108.109505] wlan0: associated
    [  153.226752] wlan0: deauthenticating from 00:26:5b:f7:b2:d9 by local choice (reason=3)
    [  153.246235] cfg80211: All devices are disconnected, going to restore regulatory settings
    [  153.246253] cfg80211: Restoring regulatory settings
    [  153.246271] cfg80211: Kicking the queue
    [  153.246290] cfg80211: Calling CRDA to update world regulatory domain
    [  153.281385] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
    [  153.281403] cfg80211: World regulatory domain updated:
    [  153.281403] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [  153.281422] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  153.281440] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [  153.281440] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [  153.281458] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  153.281458] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  157.066097] wlan0: authenticate with bc:14:01:a1:bb:d9
    [  157.115624] wlan0: send auth to bc:14:01:a1:bb:d9 (try 1/3)
    [  157.117707] wlan0: authenticated
    [  157.124416] wlan0: associate with bc:14:01:a1:bb:d9 (try 1/3)
    [  157.153926] wlan0: RX AssocResp from bc:14:01:a1:bb:d9 (capab=0xc21 status=0 aid=2)
    [  157.154092] wlan0: associated
    [  202.235581] wlan0: deauthenticating from bc:14:01:a1:bb:d9 by local choice (reason=3)
    [  202.278896] cfg80211: All devices are disconnected, going to restore regulatory settings
    [  202.278933] cfg80211: Restoring regulatory settings
    [  202.278952] cfg80211: Kicking the queue
    [  202.278952] cfg80211: Calling CRDA to update world regulatory domain
    [  202.328811] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
    [  202.328829] cfg80211: World regulatory domain updated:
    [  202.328829] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [  202.328848] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  202.328866] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [  202.328866] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [  202.328884] cfg80211:   (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  202.328884] cfg80211:   (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [  502.966582] wlan0: authenticate with 00:26:5b:f7:b2:d9
    [  502.991686] wlan0: send auth to 00:26:5b:f7:b2:d9 (try 1/3)
    [  502.994230] wlan0: authenticated
    [  503.004275] wlan0: associate with 00:26:5b:f7:b2:d9 (try 1/3)
    [  503.056844] wlan0: RX AssocResp from 00:26:5b:f7:b2:d9 (capab=0xc21 status=0 aid=1)
    [  503.057047] wlan0: associated
    [  971.724604] usb 1-1.2: new high-speed USB device number 5 using xusbps-ehci
    [  971.841040] usb-storage 1-1.2:1.0: USB Mass Storage device detected
    [  971.841243] scsi0 : usb-storage 1-1.2:1.0
    [  972.834939] scsi 0:0:0:0: Direct-Access              USB Flash Disk   5.00 PQ: 0 ANSI: 2
    [  972.836911] sd 0:0:0:0: [sda] 3889152 512-byte logical blocks: (1.99 GB/1.85 GiB)
    [  972.837059] sd 0:0:0:0: Attached scsi generic sg0 type 0
    [  972.837519] sd 0:0:0:0: [sda] Write Protect is off
    [  972.837538] sd 0:0:0:0: [sda] Mode Sense: 0b 00 00 08
    [  972.838164] sd 0:0:0:0: [sda] No Caching mode page found
    [  972.847989] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [  972.861131] sd 0:0:0:0: [sda] No Caching mode page found
    [  972.866403] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [  972.873149]  sda: sda1
    [  972.877886] sd 0:0:0:0: [sda] No Caching mode page found
    [  972.883120] sd 0:0:0:0: [sda] Assuming drive cache: write through
    [  972.890309] sd 0:0:0:0: [sda] Attached SCSI removable disk
    I don't know why Xillybs IP core is wrong, can you help me with that?
    Thanks for all support and help.
