Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Connection Issues with the Azure Sphere MT3620 Starter Kit
  • Answers 2 answers
  • Subscribers 52 subscribers
  • Views 21038 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
  • azure sphere starter kit
miyiky
miyiky over 7 years ago
I have recently received an Azure Sphere MT3620 starter kit and have been going through the steps to get it started. However I soon had an issue where, when performing a lot of different operations I would get the message:
"error: The device is not responding. The device may be unresponsive if it is applying an Azure Sphere operating system update; please retry in a few minutes"
I checked the OS using "azsphere device show-ota-status" and it confirmed that the device has the latest OS (version 19.07). I then tried restarting the PC in case that was part of the issue and upon restarting I encountered a new problem. I can no longer connect to the board via the TAP adapter. Specifically the adapter will connect momentarily and then disconnect again, repeating this process continuously. I have tried reinstalling the SDK and following all steps in the troubleshooting guide but to no avail.
I would greatly appreciate any input on this issue
  • bwilless
    bwilless over 7 years ago in reply to miyiky +2 suggested
    Michael, I'm sorry your having issue with your device staying connected to your PC. Have you tried to look at the solutions for this issue posted on the MSDN Sphere forum? https://social.msdn.microsoft…
  • rimakus
    rimakus over 7 years ago +1 suggested
    Michael, Can you advise if you have Cisco Anyconnect VPN software installed on you computer. I am unable to use Azure Sphere SDK as it is incompatible with it. If you don't have Cisco Anyconnect installed…
  • rimakus
    0 rimakus over 7 years ago
    Michael,
    If you don't have Cisco Anyconnect installed maybe this msdn thread will help in your case:
    https://social.msdn.microsoft.com/Forums/azure/en-US/8b19e10b-4d88-4de0-a805-e0eeff6d88bc/azure-sphere-device-communication-service?forum=azuresphere
  • peterfenn
    0 peterfenn over 7 years ago in reply to rimakus
    As the previous post pointed-out, there is a known issue with Cisco AnyConnect VPN taking over the TAP V9 virtual ethernet network adaptor that's used by Azure Sphere.
    If this your issue, you will need to disable Cisco AnyConnect while using the interface with Azure Sphere. (This will likely be resolved in a future releas of Azure Sphere SDK)
  • miyiky
    0 miyiky over 7 years ago in reply to peterfenn
    I have managed to get the device to be recognised again however I now have returned to the issue of not responding:
    azsphere device prep-debug
    Getting device capability configuration for application development.
    Downloading device capability configuration for device ID 'F0BBF9435F8D47E253534FEC6A018EAC073F7EEDDE303D1E1D9FAAEFBFF3CA147166EACD8B7CFB8BA0A0BAE228D4A7382FDA92404E53C94825B63F5F85CF86E7'.
    Successfully downloaded device capability configuration.
    Successfully wrote device capability configuration file 'C:\Users\mmcdo\AppData\Local\Temp\tmpFA61.tmp'.
    Setting device group ID 'cd037ae5-27ca-4a13-9e3b-2a9d87f9d7bd' for device with ID 'F0BBF9435F8D47E253534FEC6A018EAC073F7EEDDE303D1E1D9FAAEFBFF3CA147166EACD8B7CFB8BA0A0BAE228D4A7382FDA92404E53C94825B63F5F85CF86E7'.
    Successfully disabled over-the-air updates.
    Enabling application development capability on attached device.
    Applying device capability configuration to device.
    Successfully applied device capability configuration to device.
    The device is rebooting.
    Installing debugging server to device.
    Deploying 'C:\Program Files (x86)\Microsoft Azure Sphere SDK\DebugTools\gdbserver.imagepackage' to the attached device.
    error: The device is not responding. The device may be unresponsive if it is applying an Azure Sphere operating system update; please retry in a few minutes.
    error: Command failed in 00:01:41.4440840.
  • bwilless
    0 bwilless over 7 years ago in reply to miyiky
    Michael,
    https://social.msdn.microsoft.com/Forums/en-US/home?forum=azuresphere
