Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Communicate Between Two High-Level Applications
  • Answers 3 answers
  • Subscribers 52 subscribers
  • Views 838 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
alexwulff
alexwulff over 7 years ago
Hi Everyone,
I'm working on a use case that requires two high-level applications to run simultaneously. I have confirmed that I can do this utilizing the "partner application" functionality. However, in my use case I require that each application can communicate with the other. How should this best be accomplished? It looks like only real-time apps and high-level apps have direct communication supported, and I don't have access to stdin/stdout, sockets, or other means of doing this in a POSIX-y way. It also appears that shared mutable memory access isn't supported.
Thanks for your help!
  • peterfenn
    0 peterfenn over 7 years ago
    Alex
    I recommend that this level of question be posted to the Microsoft-hosted MSDN Azure Sphere support forrum at:
    https://social.msdn.microsoft.com/Forums/en-US/home?forum=azuresphere
    The following documentation pages also provide further insights into application development on Azure Sphere
    https://docs.microsoft.com/en-us/azure-sphere/product-overview/what-is-azure-sphere
    https://docs.microsoft.com/en-us/azure-sphere/app-development/applications-overview
    -Peter
  • clem57
    0 clem57 over 7 years ago
    alexwulff How do you plan to run both apps on the same A7 core? Or maybe what is the need? If on the same A7, use memory to move messages from one to the other...
  • alexwulff
    0 alexwulff over 7 years ago in reply to clem57
    Apps can be listed as "partner applications" such that they will not replace another app on the A7 that's listed as a partner app (see this documentation). What do you mean by "use memory"? I was under the impression that separate applications have their own virtual memory address space to enforce process isolation. Additionally, an application cannot share mutable flash storage with another app.
  • clem57
    0 clem57 over 7 years ago in reply to alexwulff
    alexwulff  -> Read/write (mutable) storage, which persists when a device reboots. For information about mutable storage, see Using storage on Azure Sphere. This is one type of sharable memory.
    Clem
