Azure Sphere Starter Kit
  • Azure Sphere Starter Kit
Forum Azure Sphere Contest Server -> Wi-Fi not configured
  • Replies 13 replies
  • Answers 12 answers
  • Subscribers 55 subscribers
  • Views 1579 views
  • azure sphere kit
  • azurespherech
  • azure sphere
  • azuresphkt
  • azure sphere starter kit
wizardatlarge
wizardatlarge over 7 years ago
Trying to do the daily "Azure Sphere Starter Kit Sync with Contest Server" thingie
  • When I click on "Read Device", Device IP is "Wi-Fi not configured"
    • ==> the response:
      • "Device ID" is valid
      • "Device MAC" is valid
      • "Device IP" Wi-Fi not configured
  • If I enter the following at the command prompt:
    • azsphere device wifi show-status
    • ==> the response:
SSID(for my eyes only)
Configuration stateenabled
Connection state: connected
Security state  : psk
Frequency       : 2437
Mode            : station
Key management  : WPA2-PSK
WPA State       : COMPLETED
IP Address      : 192.168.1.111
MAC Address     (for my eyese only)
Because "Wi-Fi not configured", when I tap the "Send to Server" button, an error message pops up with "deviceIP":"Wi-Fi not configured","error":"0"
So, what is going on with the app? The app is not seeing that the device is provisioned on the network and thus not allowing me to log-in for that daily clicks.
How am I supposed to log 15 days if the app is not working like it is supoosed to?
  • kmikemoo
    kmikemoo over 7 years ago +4 suggested
    As Clem stated, reconnecting to the wifi can sometimes take a bit of time. I use a PAUSE statement instead. Edit the sk_check.bat. ... azsphere device restart echo. PAUSE <--- add this or put the delay…
  • clem57
    clem57 over 7 years ago +3 suggested
    What happens if you eject USB and re-plug it back in? For me the WiFi reconnected. Also I modified the bat file to put in a 5 second Pause command. Seems like scanning the WiFi in my neighbourhood takes…
  • evanroode
    evanroode over 7 years ago +3 suggested
    I'm getting that popup and no wifi listed as well, but I'm getting counts anyway.
  • clem57
    0 clem57 over 7 years ago
    What happens if you eject USB and re-plug it back in? For me the WiFi reconnected. Also I modified the bat file to put in a 5 second Pause command. Seems like scanning the WiFi in my neighbourhood takes long time since many address near by.
  • kmikemoo
    0 kmikemoo over 7 years ago
    echo.
    PAUSE    <--- add this or put the delay here.
    I used free hotel wifi this week to check in and it took about 7-8 seconds to reconnect.  My 5 second delay wasn't giving me enough time.
  • clem57
    0 clem57 over 7 years ago in reply to clem57
    I did a test under a VM, and the plug and re-plug does something to Azure Sphere allowing the WiFi to reconnect properly. Seems like if you leave it in for awhile (time not know?), it drops the WiFi.
    Clem
  • evanroode
    0 evanroode over 7 years ago
  • jabourke
    0 jabourke over 7 years ago
    I was having the same issue; I edited the sk_check.bat to add the timeout that's been suggested and that resolved the WiFi issue for check-in, but after sending my info to the server I'm still showing the same count.
    ...is there a delay on the count...?
  • jabourke
    0 jabourke over 7 years ago in reply to jabourke
    OK - nevermind. For some reason the map was stuck showing 9/2, now it's showing 9/3 with the updated count. Must've kept a cached version...
    The timeout in the .bat worked for me, for the "WiFi not configured" error related to registration.
  • sanyaade
    0 sanyaade over 7 years ago in reply to jabourke
    I have same issue getting reply from Azure cloud server.
    I am not getting server confirmation for today having ping the azure server several times today. This is unusual.  It looks like the Azure Cloud is down. I hope not being affected by hurricane Dorian
    Anyone having same issue?
    God blesses!!!
    Best regards,
    Sanyaade
  • danzima
    0 danzima over 7 years ago in reply to sanyaade
    peterfenn
    Hi Peter, can you see the above comments?
  • kmikemoo
    0 kmikemoo over 7 years ago in reply to sanyaade
    You are right!  I didn't get the email.  However, the Server appears to be receiving because it counted my login from earlier this morning.
  • clem57
    Yesterday during the day (2-5 CST), I had much troubles contacting the cloud to build a tenant. After that, it worked. Have not tried today...
