Dev Tools
Dev Tools
Forum PIC18LF67K40: Debug mode
  • Answers 3 answers
  • Subscribers 82 subscribers
  • Views 1513 views
angelj
angelj over 7 years ago
Does the PIC18LF67K40 work only in onchip integrated debug mode or can also in incircuit serial programming via two pins?
  • clem57
    clem57 over 7 years ago +1
    I hate fanciness where technical writing should be done Good job koudelad
  • koudelad
    0 koudelad over 7 years ago
    I am not sure, whether I fully understood your question. However, if you connect target PIC via 5 pins: Vdd, Vss, -MCLR/Vpp, ICSPDAT and ICSPCLK to a programmer/debugger (like PICkit, ICD etc.), you will be able both program and debug the PIC.
    David
  • clem57
    0 clem57 over 7 years ago
    Have you seen https://www.microchip.com/wwwproducts/en/PIC18F67K40  click tab for documents. Much info there.
  • angelj
    0 angelj over 7 years ago
    @David Koudela and BB-Sphere (Clem),
    In the datasheet of PIC18LF67K40(page 4), three features are listed under the section "Programming/Debug Features"
    1.In-Circuit Serial ProgrammingTm (ICSPTm) via Two Pins
    2. In-Circuit Debug (ICD) with Three Breakpoints via Two Pins
    3. Debug Integrated On-Chip
    But in the next page(5), it is mentioned as "I" under the column "Debug" of Table 1.The legend corresponding to I says "Debugging Methods: (I) – Integrated on Chip"
    So my question is whether this particular PIC has only ' Debug Integrated On-Chip" feature. Orelse, we can do debug using debugger like PICit3.
    Link for datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/PIC18(L)F67K40%20Data%20Sheet%2040001841D.pdf
  • koudelad
    0 koudelad over 7 years ago in reply to angelj
    The datasheet list the points you mentioned, but I am afraid it is just "marketing".
    In order to support debugging, the PIC has an on chip circuitry.  Have a look at page 811 of the datasheet, it lists the possible compilers, simulators, programmers and debugger. PICkit3 or newer (please note there is a PICkit4) will work just fine. Or ICD3 (there is also ICD4 which should be OK). You will need to connect the five pins mentioned in my previous post.
    David
  • clem57
