Single-Board Computers
  • Single-Board Computers
Forum How to change dtsi(eg:maaxboard-extended-gpio.dtsi)  to make M41T93 spi rtc work in maaxboard yocto zeus branch?
  • Replies 8 replies
  • Subscribers 58 subscribers
  • Views 2731 views
gonewtinwind
gonewtinwind over 5 years ago
Hi Josh,
I use maaxboard board (not mini, not nano)
the M41T93 spi rtc works well in kernel 4.14(yocto sumo branch) , I showed here before: Enable the SPI port on MaaxBoard?
but
I need to add M41T93 spi rtc chip in yocto zeus branch(kernel 5.4),but I find the maaxboard-extended-gpio.dtsi  is different with maaxboard-nano-extended-gpio.dtsi.
the maaxboard-extended-gpio.dtsi file still keeps the gpio for  old settings , I thought the zeus did not support maaxboard now, so I need to modify it similar to  maaxboard-nano-extended-gpio.dtsi.
so I change the ecspi part as the below  patch file(see attached file,001-spi-real-time-M41T93.patch, I change kernel config,I can find the /dev/rtc0, I removed snvs_rtc),but unfortunately the spi rtc still not work!
How to change the dtsi in kerenel 5.4? I think maaxboard nano work well, I just follow it to modify maaxboard .dtsi file  similiarly . the spi rtc should work.
Thank you very much.
my full patch file:
diff -Naur ori/arch/arm64/boot/dts/freescale/imx8mq.dtsi patches/arch/arm64/boot/dts/freescale/imx8mq.dtsi
--- ori/arch/arm64/boot/dts/freescale/imx8mq.dtsi       2021-04-15 12:55:28.039009295 -0400
+++ patches/arch/arm64/boot/dts/freescale/imx8mq.dtsi   2021-04-15 16:33:48.243133485 -0400
@@ -591,15 +591,6 @@
                                compatible = "fsl,sec-v4.0-mon", "syscon", "simple-mfd";
                                reg = <0x30370000 0x10000>;
-                               snvs_rtc: snvs-rtc-lp{
-                                       compatible = "fsl,sec-v4.0-mon-rtc-lp";
-                                       regmap =<&snvs>;
-                                       offset = <0x34>;
-                                       interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>,
-                                               <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
-                                       clocks = <&clk IMX8MQ_CLK_SNVS_ROOT>;
-                                       clock-names = "snvs-rtc";
                                snvs_pwrkey: snvs-powerkey {
                                        compatible = "fsl,sec-v4.0-pwrkey";
@@ -832,7 +823,7 @@
                                clocks = <&clk IMX8MQ_CLK_ECSPI1_ROOT>,
                                         <&clk IMX8MQ_CLK_ECSPI1_ROOT>;
                                clock-names = "ipg", "per";
-                               status = "disabled";
+                               status = "enabled";
                        ecspi2: spi@30830000 {
diff -Naur ori/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi patches/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
--- ori/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi      2021-04-08 14:58:09.820015901 -0400
+++ patches/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi  2021-04-19 13:57:18.993139208 -0400
@@ -37,10 +37,15 @@
                pinctrl_ecspi1: ecspi1grp {
                                fsl,pins = <
-                               MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9               0x16
-                               MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI    0x16
-                               MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO    0x16
-                               MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK    0x1816
+                               MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI    0x82
+                               MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO    0x82
+                               MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK    0x82
+               pinctrl_ecspi1_cs: ecspi1cs {
+                       fsl,pins = <
+                               MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9               0x40000
@@ -90,10 +95,19 @@
&ecspi1{
        fsl,spi-num-chipselects = < 1 >;
-       cs-gpios = <&gpio5 13 0 > ;
+       cs-gpios = <&gpio5 9 0 > ;
        pinctrl-names = "default";
-       pinctrl-0 = <&pinctrl_ecspi1 >;
+       pinctrl-0 = <&pinctrl_ecspi1 &pinctrl_ecspi1_cs>;
        status = "okay";
+       #address-cells=<1>;
+       #size-cells=<0>;
+       rtc@0x00{
+       #address-cellss=<1>;
+       #size-cells=<1>;
+       compatible = "rtc-m41t93";
+       spi-max-frequency = <5000000>;
+       reg = <0>;
&i2c2 {
        73,1          Bot
001-spi-real-time-M41T93.txt.zip
  • gonewtinwind
    maaxboard login: root
    Password:
    Last login: Wed Apr  7 13:21:56 UTC 2021 on tty7
    root@maaxboard:~# hwclock -r
    [   71.287904] rtc rtc0: __rtc_set_alarm: err=-22
    hwclock: select() to /dev/rtc0 to wait for clock tick timed out
    root@maaxboard:~# dmesg | grep rtc
    [    1.707508] rtc-m41t93 spi0.0: registered as rtc0
    [    3.165010] rtc-m41t93 spi0.0: hctosys: unable to read the hardware clock
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to gonewtinwind
    I think there are some errors in dtb source code,but I can not find where it is.
    any help?
  • jafoste4
    jafoste4 over 5 years ago in reply to gonewtinwind
    Hi peter,
    I am looking into this. Will hopefully have an answer for you tomorrow.
    Josh
  • gonewtinwind
    gonewtinwind over 5 years ago in reply to jafoste4
    Thank you. I think the issue maybe at there: (tested,still not work)
    I cat  ./imx8mq-zii-ultra-rmb3.dts.
    it is:
    &iomuxc {
      fsl,pins = <
      MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9 0x19
    I am trying to fix it.
    sorry, I tried, but still not work.
    the patch file:
    +++ patches/arch/arm64/boot/dts/freescale/imx8mq.dtsi   2021-04-22 17:38:26.638367400 -0400
    -                                       regmap =<&snvs>;
    -                                       offset = <0x34>;
    @@ -832,7 +823,7 @@
    +++ patches/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi  2021-04-22 18:02:45.309302120 -0400
    @@ -37,10 +37,10 @@
                                    fsl,pins = <
    +                               MX8MQ_IOMUXC_ECSPI1_SS0_GPIO5_IO9               0x19
    @@ -89,11 +89,17 @@
    &ecspi1{
    -       fsl,spi-num-chipselects = < 1 >;
    -       pinctrl-names = "default";
    -       status = "okay";
    +        fsl,spi-num-chipselects = < 1 >;
    +        pinctrl-names = "default";
    +        pinctrl-0 = <&pinctrl_ecspi1 >;
    +        status = "okay";
    +        rtc@0x00{
    +                reg = <0>;
    &i2c2 {
        69,1          Bot
        1,1           Top
  • jafoste4
    Hi Peter,
    I am having an issue uploading a diff file to E14, I will email it to you directly. This diff that we made based on the latest linux source code(commit: 49174803839815089d7c6c42631e415260778b4f at branch: maaxboard_5.4.24_2.1.0 ) according to your needs. Unfortunatly we don’t have such a SPI RTC device to try, please give it a try and let me know.
    Josh
  • gonewtinwind
    it still not work. I think the pin value settings are wrong. or spi deep driver not work.
    my patch:
    +++ patches/arch/arm64/boot/dts/freescale/imx8mq.dtsi 2021-04-26 10:04:51.780796943 -0400
    @@ -832,7 +832,7 @@
    +++ patches/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi 2021-04-26 10:08:59.210155738 -0400
    @@ -37,10 +37,10 @@
      fsl,pins = <
    @@ -89,13 +89,24 @@
    &ecspi1{
    - status = "okay";
    +        cs-gpios = <&gpio5 9 GPIO_ACTIVE_HIGH >;
    +        status = "okay";
    +       #address-cells = <1>;
    +       #size-cells = <0>;
    +        rtc@0{
    +                reg = <0>;
    +&snvs_rtc {
    +       status = "disabled";
    &i2c2 {
      clock-frequency = <400000>;
  • gonewtinwind
    Maybe  I need to remove line :   fsl,spi-num-chipselects = < 1 >;   let me test
    sorry, not work!
    tomorrow I will use the scope to test the signals
  • gonewtinwind
    Hi Joshua,
    your updated patch works well!
    Thank you sooo much.
    please see the following files for people who need:
    diff --git a/arch/arm64/boot/dts/freescale/imx8mq.dtsi b/arch/arm64/boot/dts/freescale/imx8mq.dtsi
    index 5943d2ed653d..239271911429 100755
    --- a/arch/arm64/boot/dts/freescale/imx8mq.dtsi
    +++ b/arch/arm64/boot/dts/freescale/imx8mq.dtsi
    @@ -826,7 +826,7 @@
      ecspi1: spi@30820000 {
      #size-cells = <0>;
    - compatible = "fsl,imx8mq-ecspi", "fsl,imx6ul-ecspi";
    + compatible = "fsl,imx8mq-ecspi", "fsl,imx51-ecspi";
      reg = <0x30820000 0x10000>;
      interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
    @@ -838,7 +838,7 @@
      #size-cells = <0>;
      reg = <0x30830000 0x10000>;
      interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
      clocks = <&clk IMX8MQ_CLK_ECSPI2_ROOT>,
    @@ -850,7 +850,7 @@
      ecspi3: spi@30840000 {
      #size-cells = <0>;
      reg = <0x30840000 0x10000>;
      interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
      clocks = <&clk IMX8MQ_CLK_ECSPI3_ROOT>,
    diff --git a/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi b/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
    index 25c84d58bf74..61202110b358 100755
    --- a/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
    +++ b/arch/arm64/boot/dts/freescale/maaxboard-extended-gpio.dtsi
    @@ -37,10 +37,10 @@
      fsl,pins = <
    + MX8MQ_IOMUXC_ECSPI1_MOSI_ECSPI1_MOSI 0x19
    + MX8MQ_IOMUXC_ECSPI1_MISO_ECSPI1_MISO 0x19
    + MX8MQ_IOMUXC_ECSPI1_SCLK_ECSPI1_SCLK 0x19
    @@ -89,11 +89,23 @@
    &ecspi1{
    + pinctrl-0 = <&pinctrl_ecspi1>;
    + fsl,spi-num-chipselects = <1>;
    + cs-gpios = <&gpio5 9 GPIO_ACTIVE_HIGH>;
      status = "okay";
    + rtc@0 {
    + reg = <0>;
    + spi-max-frequency = <2000000>;
    +&snvs_rtc {
    &i2c2 {
    diff --git a/arch/arm64/configs/maaxboard_defconfig b/arch/arm64/configs/maaxboard_defconfig
    index a89ebacf02f7..0a796e196774 100755
    --- a/arch/arm64/configs/maaxboard_defconfig
    +++ b/arch/arm64/configs/maaxboard_defconfig
    @@ -659,6 +659,7 @@ CONFIG_EDAC=y
    CONFIG_EDAC_GHES=y
    CONFIG_EDAC_SYNOPSYS=y
    CONFIG_RTC_CLASS=y
    +CONFIG_RTC_DRV_M41T93=y
    CONFIG_RTC_DRV_DS1307=y
    CONFIG_RTC_DRV_MAX77686=y
    CONFIG_RTC_DRV_RK808=m
    diff --git a/drivers/dma/imx-sdma.c b/drivers/dma/imx-sdma.c
    index 09ae4282ad56..a145004f649b 100644
    --- a/drivers/dma/imx-sdma.c
    +++ b/drivers/dma/imx-sdma.c
    @@ -639,7 +639,6 @@ static struct sdma_driver_data sdma_imx8mq = {
      .num_events = 48,
      .script_addrs = &sdma_script_imx7d,
      .check_ratio = 1,
    - .ecspi_fixed = true,
    static struct sdma_driver_data sdma_imx8mp = {
    diff --git a/drivers/spi/spi-fsl-lpspi.c b/drivers/spi/spi-fsl-lpspi.c
    index 39870bc38e40..f608f89f45cd 100644
    --- a/drivers/spi/spi-fsl-lpspi.c
    +++ b/drivers/spi/spi-fsl-lpspi.c
    @@ -888,12 +888,6 @@ static int fsl_lpspi_probe(struct platform_device *pdev)
      controller->bus_num = pdev->id;
      controller->slave_abort = fsl_lpspi_slave_abort;
    - ret = devm_spi_register_controller(&pdev->dev, controller);
    - if (ret < 0) {
    - dev_err(&pdev->dev, "spi_register_controller error.\n");
    - goto out_controller_put;
      if (!fsl_lpspi->is_slave) {
      controller->cs_gpios = devm_kzalloc(&controller->dev,
      sizeof(int) * controller->num_chipselect, GFP_KERNEL);
    @@ -901,6 +895,11 @@ static int fsl_lpspi_probe(struct platform_device *pdev)
      for (i = 0; i < controller->num_chipselect; i++) {
      int cs_gpio = of_get_named_gpio(np, "cs-gpios", i);
    + if (cs_gpio == -EPROBE_DEFER) {
    + ret = -EPROBE_DEFER;
    + goto out_controller_put;
      if (!gpio_is_valid(cs_gpio) && lpspi_platform_info)
      cs_gpio = lpspi_platform_info->chipselect[i];
    @@ -971,13 +970,30 @@ static int fsl_lpspi_probe(struct platform_device *pdev)
      ret = fsl_lpspi_dma_init(&pdev->dev, fsl_lpspi, controller);
      if (ret == -EPROBE_DEFER)
    + goto err_disable_runtime_pm;
      if (ret < 0)
      dev_err(&pdev->dev, "dma setup error %d, use pio\n", ret);
    + else
    + /* disable LPSPI module IRQ when enable DMA mode successfully,
    + * to prevent the unexpected LPSPI module IRQ events*/
    + disable_irq(irq);
    + ret = devm_spi_register_controller(&pdev->dev, controller);
    + if (ret < 0) {
    + dev_err(&pdev->dev, "spi_register_controller error.\n");
    + pm_runtime_mark_last_busy(fsl_lpspi->dev);
    + pm_runtime_put_autosuspend(fsl_lpspi->dev);
      return 0;
    +err_disable_runtime_pm:
    + pm_runtime_dont_use_autosuspend(fsl_lpspi->dev);
    + pm_runtime_put_sync(fsl_lpspi->dev);
    + pm_runtime_disable(fsl_lpspi->dev);
    out_controller_put:
      spi_controller_put(controller);
    diff --git a/drivers/spi/spi-imx.c b/drivers/spi/spi-imx.c
    index 91e32291c44e..0128e33eb5bc 100644
    --- a/drivers/spi/spi-imx.c
    +++ b/drivers/spi/spi-imx.c
    @@ -1775,8 +1775,13 @@ static int spi_imx_probe(struct platform_device *pdev)
      /* Request GPIO CS lines, if any */
      if (!spi_imx->slave_mode && master->cs_gpios) {
      for (i = 0; i < master->num_chipselect; i++) {
    - if (!gpio_is_valid(master->cs_gpios[i]))
    + if (!gpio_is_valid(master->cs_gpios[i])) {
    + if (master->cs_gpios[i] == -EPROBE_DEFER) {
    + goto out_spi_bitbang;
      continue;
      ret = devm_gpio_request(&pdev->dev,
      master->cs_gpios[i],
