Single-Board Computers
  • Single-Board Computers
Forum SBC CPU Throughput
  • Replies 88 replies
  • Subscribers 63 subscribers
  • Views 11282 views
  • cubieboard
  • olinuxino
  • sabrelite
  • bbb
  • BeagleBone
  • rpi
SBC CPU Throughput
morgaine
morgaine over 13 years ago
I notice that people are doing some initial benchmarking of BBB and other boards on the RPF forum.  Results roughly as expected I guess:
Using just a simple
time echo "scale=2000;4*a(1)" | bc -l
as a lightweight benchmark, I see these numbers reported (smaller Time is better):
[table now updated with extra datapoints reported in current thread below]
Submitter
Time (s)
Board
SoC
Clock (MHz)
O/S
shuckle26.488Raspberry Pi BBCM2835700Raspbian 3.1.9
morgaine25.719Raspberry Pi BBCM2835700Raspbian 3.1.9+ #272
shuckle25.009Raspberry Pi BBCM2835700Raspbian 3.2.27
trn24.280Raspberry Pi BBCM2835700Raspbian ?
morgaine22.456Raspberry Pi BBCM2835800Raspbian 3.1.9+ #272
morgaine21.256Raspberry Pi BBCM2835800Raspbian 3.6.11+ #545, new firmware only
selsinork21.0MinnowboardAtom E640T1000Angstrom minnow-2013.07.10.img
shuckle17.0Raspberry Pi BBCM28351000Raspbian ?
morgaine16.153BB (white)AM3359720Angstrom v2012.01-core 3.2.5+, user-gov
selsinork15.850A20-OLinuXino-MICROA20912Debian 7.0, 3.4.67+
selsinork15.328CubieboardA20912Ubuntu/Debian 7.1
pluggy14.510BBBAM33591000Debian
morgaine14.153BBBAM33591000Debian 7.0, 3.8.13-bone20, perf-gov
selsinork13.927A10-OLinuXino-LIMEA101000Debian 7.0, 3.4.67+
Heydt13.159CubieboardA101000?
selsinork12.8Sabre-litei.MX61000Debian armhf
selsinork12.752CubieboardA20912Ubuntu/Debian 7.1 + Angstrom bc
selsinork12.090BBBAM33591000Angstrom dmnd-gov
pluggy11.923BBBAM33591000Angstrom
selsinork11.86BBBAM33591000Angstrom perf-gov
selsinork9.7Sabre-litei.MX61000Debian armhf + Angstrom bc
selsinork9.606Sabre-litei.MX61000LFS 3.12, gcc-4.8.2, glibc-2.18
As usual, take benchmarks with a truckload of salt, and evaluate with a suitable mixture of suspicion, snoring, and mirth. Use the numbers wisely, and don't draw inappropriate conclusions. image
Morgaine.
    e14 Contributor over 13 years ago in reply to gdstew +2
    floating point doesn't get you 2000 digits.
  • morgaine
    morgaine over 13 years ago in reply to gdstew +1
    Data is always good, and sharing it is also good. The warnings are to help people avoid unwarranted conclusions. And when used properly, synthetic and other artificial benchmarks can be very valuable,…
    e14 Contributor over 13 years ago in reply to gdstew +1
    > and don't understand why you think it is a good idea to keep it in the loop so you can benchmark it. Come on. It's not that complicated. Johnny wanted to know how fast his new computer was. He decided…
  • gdstew
    gdstew over 13 years ago in reply to e14 Contributor
    1) it is trivially easy to run, nothing to download, nothing to compile,
        so you can easily get results from lots of people, allowing you to
        see how consistent the results are, and they seem to be pretty consistent.
    I was totally unaware that triviality in any form was considered a good trait for a benchmark. Doesn't make sense to me though.
    2)  it is not subject to personal differences in what compiler was used
        to compile it, or what optimization levels or other compiler switches
        were used, although it will exhibit such differences between distros.
    Absolutely no way to know this at all. The programs run in the "benchmark" were almost certainly compiled using different versions of GCC with differing levels of optimization
    built in and with unknown compile swithes used (most are probably the same, some depend on the CPU) when the OS was built.
    3)  it doesn't rely on computing the same value over and over in a loop.
         Benchmarks that do that can be overly sensitive to compiler loop
         optimizations, and to just-in-time code-generation techniques.
    That is why good synthetic benchmarks consist of many programs. The level of loop optimization available is a good thing to know as is knowing if using
    JIT is something you can do if you prefer to use it (see first statement).
    4)  It has a pretty-well understood area of application, integer compute bound.
        Obviously you wouldn't use it to measure floating-point performance, or
        gpu performance, or I/O performance, etc.
    I think all those other things are actually good things to benchmark too since they can all affect applications.
    5)  It uses data that is large enough to show the benefit of large data caches,
         similar to typical user applications.
    Although in the real world this will probably be the exception, not the rule. Yes big caches are good, but using a benchmark
    that it executes (or executes mostly) in cache or keeps (most of) its data in cache skews the results too. Something I believe
    you mentioned earlier as not being desirable.
    6)  It takes about the right amount of time to run--not so short that the time to
         load the benchmark matters, or that the accuracy of the clock matters,
         and not so long that you can't easily run it several times to see that the
         results are consistent.
    OK. Not really what I consider to be in the top 10 on my list of desirable benchmark traits and pretty much in direct opposition
    of getting useful results. The phrase that comes to mind is quick and dirty. Personnaly I don't want to wait a real long time for
    results either so I prefer to be able to choose what I need to check and how many iterations they run for resonably repeatable
    results.
    > The level of loop optimization available is a good thing to know ...
    No, its not.
    In order to have a benchmark that runs long enough to get decent timings, many benchmarks
    put a loop around the code they want to test, on the theory that it will take N times longer
    to execute a loop N times than it would to do it once.  That theory is just plain wrong
    because any decent compiler will hoist as much code as possible outside the loop where
    it's only done once.   In some cases, the entire contents of the loop can be done only once.
    So you think you're measuring the time it takes to do some computation, but you're really not.
    It's tempting to think that it doesn't matter, because a compiler that does good loop optimizations
    is better than one that doesn't.  Which may be true to some extent.  But the problem is that
    your application most likely doesn't repeatedly do the same calculation over and over in a loop,
    so your application won't see the same speedup as your synthetic benchmark.
  • gdstew
    gdstew over 13 years ago in reply to morgaine
    The interpretation that people give to good data is an entirely different matter, and my cautions were the usual advice about taking perfectly good numbers and making wholly incorrect conclusions about them.
    How can you provide a useful interpretation of data that in your own words you should "take (benchmarks) with a truckload of salt, and evaluate with a suitable mixture of suspicion, snoring, and mirth.". I mean really,
    if this is your idea of normal cautions for data I'd like to see your idea a real bona-fide warning.
    AFAWK the numbers are totally accurate.
    But not really useful for the real world (see previous responses) which is the point you keep dancing around.
    Even you have agreed with that,
    I agree with what you said, but not that the data in this "benchmark" is good in the sense that a useful interpretation of much of anything is possible using it. Which is
    again the point you keep dancing around. It is far too simplistic a benchmark to provide that.
    so you're really just looking for a fight as usual.
    Something I've seen you do on numerous occasions yourself.
    > As to the benchmark itself, no single line program line can be considered as a valuable synthetic benchmark of anything.
    You obviously have no clue what this benchmark does.  It isn't a "single line program" at all.
    Invoking the program takes a single line, and that is a good thing.
    There's a very important difference between the command to invoke a program
    and the program itself.
  • gdstew
    Yes it is good to know where and how much the loops have been inlined, otherwise bad interpretaions of the
    results are probable. So I guess that you should know what you are doing to get good results.
    That theory is just plain wrong because any decent compiler will hoist as much code as possible outside the loop where
    In most decent compilers the level of inlining avaialable is also usually selectable using one or more compile time directives or
    by the compiler itself mainly (but not exclusively) due to code size limitations.
  • morgaine
    A rational person can provide a useful interpretation by using ordinary engineering knowledge and commonsense.
    I refer you to coder27's post about the data confirming that execution times are proportional to clock rates for a given architecture, and likewise confirming that there is a significant improvement from ARM11 to Cortex-A8 for a given clock rate.  These are helpful observations in that they confirm what is expected, and if the numbers had indicated something entirely different then we would have some very serious issues to investigate.
    See previous section.  It is you who chose to dance around and ignore the useful and helpful interpretations of this data explained well in coder27's post, and instead dived in here directly at me without provocation nor valid reason.
    I have consistently stated that good data is useful when used appropriately, but unhelpful when used inappropriately.  I clearly said "Results roughly as expected" in my opening post which points to the data being useful, and then I gave the usual cautions about using benchmark data wrongly to reach inappropriate conclusions.
    Nobody here has made any inappropriate conclusions from this data, so whatever are you arguing about?
    Morgaine.
    shabaz over 13 years ago in reply to e14 Contributor
    As far as I know, some open source* and possibly some commercial benchmarks do a similar computation as part of a CPU intensiveness test (at least for single cored processors). Probably, for an embedded app where we may not be interested in say, file I/O, or multimedia extensions or multi-cored results, then it does have some value.
    *Source: OSmark
    > Yes it is good to know where and how much the loops have been inlined, otherwise bad interpretaions of the results are probable.
    Let me spell it out for you.  I said nothing about inlining.   Inlining is something that applies
    to subprograms, and reduces the call/return overhead.  It doesn't apply to loops at all,
    although there is an optimization called loop unrolling that is similar to subprogram inlining.
    The loop optimization I referred to is called loop invariant code hoisting.  It involves moving
    code from inside the loop to outside (before) the loop, where it is only done once instead
    of N times.  This optimization prevents you from knowing how long the code takes to run that you
    were intending to measure.   And it is very significant that this Pi benchmark isn't susceptible
    to this optimization.
  • gdstew
    Yes actually I do know that it runs as an interpreted program in the bash shell and executes echo to send a math equation to execute and executes the external compiled program (bc) to compute pi to 2000 digits
    and time and how long it takes to do so. So you are mainly testing floating point performance. While this is not really simplistic (not really complicated either), it is not a really useful for much of anything other
    than a FP benchmark either.
