Single-Board Computers
  • Single-Board Computers
Forum BBB CE Certificate
  • Subscribers 59 subscribers
  • Views 1201 views
  • bbb
BBB CE Certificate
How/Where can I ge the BBB CE & FCC certificate?
  • bwelsby
    0 bwelsby over 10 years ago
    You may find what you are looking for here Beagleboard:BeagleBoneBlack - eLinux.org
    0 e14 Contributor over 10 years ago in reply to bwelsby
    Thanks. Brian.
    There is only for the test report. I want the CE/FCC certificate. Do you have the info?
  • bwelsby
    0 bwelsby over 10 years ago in reply to e14 Contributor
    No sorry that's all the info I know about.
  • knikft
    0 knikft over 10 years ago in reply to e14 Contributor
    CE certification binded to manufacturing. The CE certificate bind to each instance of product. If E14 order BBB from an other company then it is need new certificate.
    The newest boards has CE mark on paper box, but on the board just "PB free" mark.
    If you put BBB to order then you get detailed window. There you found "Law and environment protection" window. In this window you found RoHS certificate issued by E14. This is not CE certicficate, but it is the highest garde which can issued without assistance of manufacturer. It is required to sale and use within EU.
    Brian,
    just a suggestion regarding how links are handled (or mishandled) here:
    Someone reading this and looking at the link might think you were linking to the entire BBB wiki,
    suggesting that maybe if the OP read all the way through, he might (or might not) find what he was looking for.
    But you were actually a lot more helpful than that.  Your link goes directly to the section on Regulatory Compliance Documents:
    using a URL fragment link:
         http://elinux.org/Beagleboard:BeagleBoneBlack#Regulatory_Compliance_Documents
    But unfortunately, E14 strips the fragment (part starting with #) when it displays links.
    If you want the reader to see that you are being helpful, you can prevent fragment stripping
    by toggling into the html editor (using the <html> option on the menu bar),
    pasting the link, then toggling back.
    That's how I made the unstripped link above.
