Single-Board Computers
  • Single-Board Computers
Forum PLC PROGRAMMING CHIPS
  • Answers 2 answers
  • Subscribers 59 subscribers
  • Views 1737 views
  • plc micro chips
xheat862
xheat862 over 8 years ago
Hi
I am a developer of gas fired appliances
i am looking for help to write some programming on PLC chips
Is there anyone who could do this for me
  • jomoenginer
    jomoenginer over 8 years ago in reply to Robert Peter Oakes +2 suggested
    There are PLC on Chip options such as the Intel/Altera SoC offering. https://www.altera.com/solutions/industry/industrial/applications/automation/plc.html or the Divelbiss chips with on-board EZ LADDER…
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago +1 suggested
    typically PLC's are not just a chip, there a SBC (Small Board with many chips including a microcontroller given that, An Arduino or something would be a good place to start. once you have a design, the…
    0 Robert Peter Oakes over 8 years ago
    given that, An Arduino or something would be a good place to start. once you have a design, the circuit can be "Hardened" to make it suitable for commercial use and also simplified as many parts on an Arduino will not be needed.
    To help more than this, I would need to know more about what this control (PLC) is going to be expected to so, are there displays, keypads, other IO, temperature sensors or other sensors etc etc.
  • jomoenginer
    0 jomoenginer over 8 years ago in reply to Robert Peter Oakes
    or the Divelbiss chips with on-board EZ LADDERRegistered kernel
    https://www.divelbiss.com/Products/CatFamDetails.asp?ProdCatID=2&ProdFamID=2
    More information from Tim would be very helpful though.
  • xheat862
    0 xheat862 over 8 years ago in reply to Robert Peter Oakes
    Hi Peter Oakes
    What is a Arduino
    The appliance is a gas heater, its components which need to be controlled are below
    240 volt pre heat element
    240 volt fan
    240 volt pressure switch
    240 volt gas valve
    K-Type thermal couple
    a remote thermo stat will be used to switch the appliance on/off/low fire / hire fire
    all the above need to work to a particular timed sequence and the thermal couple needs to monitor temperature
    The boards i have seen which can carry out similar operations are a PCB with a logic chip on, with my very limited knowledge is the chip the brain which makes all the components work in sequence ? this would be the part which i need?
  • xheat862
    0 xheat862 over 8 years ago in reply to xheat862
    Hi
    The boards attached are from a gas fired appliance which i am trying to replicate, they have a logic chip on them which i can not get access to so i need to re write the program
    Is there somebody who can write logic program
