RIoTboard
  • Single-Board Computers
  • RIoTboard
RIoTboard
Documents RIoTboard BSP Images and Tools Download - Android and Linux
Join RIoTboard to participate - click to join for free!
  • Author Author: pchan
  • Date Created: 5 Aug 2014 3:28 PM Date Created
  • Last Updated Last Updated: 8 Oct 2021 7:52 AM
  • Views 7603 views
  • Comments 33 comments
AndroidLinux
BSP JellyBean v4.3
SDcard Image
Download
Download
BSP Linux Ubuntu v3.0.35
SDcard Image
Download
Download
BSP KitKat v4.4
SDcard Image
Download
Download
BSP Linux Yocto v3.10.17
SDcard Image
Download
Download
Tools
Mfg Tool
Download
Tools
Mfg Tool
Download
  • android
  • download
  • riotboard
  • and
  • tools
  • bsp
  • images
  • linux
  • omeier
    omeier over 12 years ago in reply to radiatortwo +1
    Same problem here, the downloads are dead!
  • Yodinsn
    Yodinsn over 2 years ago in reply to beacon_dave
    Cool! Thank You!
    beacon_dave over 2 years ago in reply to Yodinsn
    Try using HTTPS instead of HTTP e.g.:
    https://downloads.element14.com/downloads/riotboard/Linux/image_SVN2487.zip
  • Yodinsn
    Yodinsn over 2 years ago in reply to radiatortwo
    doesn't work now
  • espozuno
    espozuno over 2 years ago
    I figured out how to get the files. Use chrome as your browser. In the orange box where is says "Download", put your mouse pointer over it till you get the hand, then right click your mouse. You will then get a menu and at the bottom of the menu it says Inspect. Select Inspect, another window will open up next to the main window and you will see a link for the file. Left click the highlighted link and then left click your download icon at the top of the browser window. Select "Keep" and it will download the file. I downloaded all the files this way but I can't get my board running anything. I've tried eMMc loading and I constantly get a failed formatting boot partition using Win32Diskimager. I can get the u-boot splash screen to show up when I run from the SDCard but then the screen goes black.
  • ronakvyas
    ronakvyas over 8 years ago
    Hello every one can any one provide me the steps for compile the image from its source code on ubuntu pc ?thanks.
  • mrpipes3
    mrpipes3 over 8 years ago in reply to mrpipes3
    So I found this website which I think is the manufacture of the RiOTBoard.  Which image do I down load to get the latest version?  Again,  I learned what I know in about the last 40 hours of googleing.  Total NEWB.
    admin
    http://www.embest-tech.com/down.aspx?key=1&typeid=11&fid=t14:11:14&page=3
  • mrpipes3
    Is there a way to upgrade the versions provided here?  I tried both linux an Android and they are older versions of the OS.
    Can you use GooglePlay store on the Android version?  There are some apps I want to download but I can't get GooglePlay working.  I think it is because it is an older version of Android OS.  Or maybe because this version ins rooted?admin RIoTboardRIoTboard BSP Images and Tools Download - Android and LinuxRIoTboard - Android KitKat Build on Ubuntu 12.04.5/14.04.5 LTSRIoTboard Quick Start TutorialsInstalling Google Play Services and Google Play Store on RiotBoard
  • acasmol_1
    acasmol_1 over 9 years ago
    There is a place or a way where I can compile android 5 or 6 for this board. Getting into NXP Comunity, only offers until Android v4.3.1, but I require 5+
    If you have any suggest or idea of how to put Android 5v in this board, thanks a lot.
  • stmorgan
    stmorgan over 9 years ago in reply to af0123
    I just successfully downloaded the image on 14 January 2017 via the above link without issue, so you might try a different download method if one is available (different computer, different ISP, etc.).
  • af0123
    af0123 over 9 years ago in reply to tusharp
    Hi! I am trying to download the image from dropbox but it always aborts at 314 mb. Is there a second source or a newer one? I am searching for a linux with QT support on RIoTBoard...
    Thanks!
