Technical Library
  • Technical Library
Technical Library
Documents Freescale: DEMO9S08SH32 S08SH Family Demonstration board
  • Author Author: atomar
  • Date Created: 18 Jul 2012 5:41 AM Date Created
  • Last Updated Last Updated: 15 Jan 2013 10:32 AM
  • Views 1010 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Overview:
The DEMO9S08SH32DEMO9S08SH32 is a demonstration board for the MC9S08SH32MC9S08SH32 microcontroller. Application development is quick and easy with the integrated USB-BDM interface, together with CodeWarriorTm Development Studio and software examples.  An optional BDM_PORT port is also provided to allow use of a BDM_PORT cable. Two, 40-pin connectors provide access to all IO signals on the target MCU.
The  DEMO9S08SH32DEMO9S08SH32 board operates in two operating modes: Run Mode, or Debug Mode. Run Mode executes the user application from Power-On or Reset. Debug Mode supports the development and debug of applications.
The  DEMO9S08SH32DEMO9S08SH32 board features an integrated USB-Multilink BDM from P&E Microcomputer Systems. The integrated USB-Multilink BDM supports application development and debugging via background debug mode. All necessary signals are provided by the integrated USB-Multilink BDM. A USB, type B, connector provides connection from the target board to the host PC.
Key Applications: Automotive,Consumer,Industrial,Medical/Health Care,Motor Control
imageFreescale Development KitsimageFreescale Development Tools
Development Tools
Software Development Tools:
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and balance code size with performance requirements. Learn More
RTOSMicriumuC/OS IIIColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Using a commercial real-time kernel such as μC/OS-III provides a solid foundation and framework to the design engineer dealing with the growing complexity of embedded designs.  Learn More
RTOSSeggerembOSColdFire / HC08 / HC12 / ARM / S08 / RS08
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications.  Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsFreescaleUSBMULTILINKBDMEUSBMULTILINKBDMEHC08 / HCS12 / S08 / RS08 / Coldfire V1USB BDM Interface cable for the 68HC(S)12(X) and 68HCS08 and 68RS08 and ColdFire V1
Debuggers, Emulators & JTAG ToolsFreescaleU-MULTILINKU-MULTILINKHC08 / HCS12 / S08 / RS08 / Coldfire / KinetisP&E USB Multilink Universal debug and programming interface for HCS08, HC(S)12(X), ColdFire, Qorivva MPC55xx/56xx, and Kinetis
Debuggers, Emulators & JTAG ToolsFreescaleM68CYCLONEPROEM68CYCLONEPROEHC08 / HCS12 / S08 / RS08 / Coldfire V1Hardware Debug Interface and Stand-Alone Programmer for HC08, HCS08, RS08, ColdFire V1, and HC(S)12(X)
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: DEMO9S08SG32QSG-Quick Start Guide for demoboard DEMO9S08SH32/SG32
User GuideFreescale: DEMO9S08SG32UG-User's Guide for demoboard DEMO9S08SG32
User ManualFreescale: Getting Started with Freescale Development Tools
Product BriefFreescale: 950-00087-CodeWarrior Development Studio for Microcontrollers v6.3 Fact Sheet
Product BriefFreescale: CodeWarrior for Microcontrollers_Fact_Sheet
Product BriefFreescale: Getting Started with Freescale Development Tools Brochure
Product BriefFreescale: SH32FS- Fact Sheet for S08SH16/32
DatasheetFreescale: 950-0087-CodeWarrior Development Studio for Microcontrollers v6.3 Fact Sheet
DatasheetFreescale: CodeWarrior Development Studiofor Microcontrollers V6.3
Selection GuideFreescale: Getting Started with Freescale Development Tools
Solution GuideFreescale: Solutions for consumer and industrial application
Design Elements
TypeDescription
SchematicsFreescale: DEMO9S08SH32SCH - DEMO9S08SH8 Schematic
Back to top
Video
This video is unavailable.
Back to top
Kit Features
The Freescale's  DEMO9S08SH32DEMO9S08SH32 features the following:
  • MC9S08SH32MC9S08SH32, 28 TSSOP
    • 32K Bytes Flash
    • 1K Bytes RAM
    • 512K Bytes EEPROM
    • Internal Oscillator
  • Integrated P&E USB-BDM
  • BDM_PORT header for BDM cable support (not installed)
  • LIN PHY w/ 2, 4-pos Molex connectors
  • MCU_PORT socket headers for access to MCU IO signals
  • On-board +5V regulator
  • Optional Power from USB-BDM or MCU_PORT connector
  • Power Input Selection Jumpers
    • Power input from USB-BDM
    • Power input from on-board regulator
    • Power input from Connector J1
    • Optional Power output through Connector J1
  • User Components Provided
    • 3 Push Switches; 2 User, 1 Reset
    • 7 LED Indicators; 2 User, VDD, USB Power, USB Power Out
    • 5K ohm POTs w /LP Filter
    • Light Sensor w/ LP Filter and Op Amp
  • Jumpers
    • PWR_SEL
    • VX_EN
    • USER_EN
    • COM_SEL
  • Connectors
    • 40-pin MCU I/O Connector
    • 2.0mm Barrel Connector
    • BDM_PORT (not installed)
    • USB Connector
    • DB9 Connector
Back to top
Kit Contents
The Freescale's  DEMO9S08SH32DEMO9S08SH32 Supplied with below contents:
  • DEMO9S08SH32DEMO9S08SH32 Demo board
  • A USB cable
  • A Quick Start Guide sheet
  • User’s manual
  • The CodeWarrior Development Studio
Back to top
  • s08sh32
  • freescale
  • 9s08sh
  • mc9s08sh32
  • demo9s08sh32
  • codewarrior
  • s08sh
