Technical Library
  • Technical Library
Technical Library
Documents Arduino: Arduino Uno based on  Atmel AVR ATmega328 MCU
  • Author Author: sunnyzhuo1
  • Date Created: 9 Aug 2012 6:36 AM Date Created
  • Last Updated Last Updated: 17 Dec 2012 9:09 AM
  • Views 1998 views
Buy NowBuy NowDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Kit Overview
The Arduino Uno is a microcontroller board based on the ATmega328ATmega328. It has 14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs, a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started.
The Uno differs from all preceding boards in that it does not use the FTDI USB-to-serial driver chip. Instead, it features the Atmega16U2 (Atmega8U2 up to version R2) programmed as a USB-to-serial converter.
Revision 2 of the Uno board (A000046A000046) has a resistor pulling the 8U2 HWB line to ground, making it easier to put into DFU mode.
Revision 3 of the board (A000066A000066) has the following new features:
  • 1.0 pinout: added SDA and SCL pins that are near to the AREF pin and two other new pins placed near to the RESET pin, the IOREF that allow the shields to adapt to the voltage provided from the board. In future, shields will be compatible both with the board that use the AVR, which operate with 5V and with the Arduino Due that operate with 3.3V. The second one is a not connected pin, that is reserved for future purposes.
  • Stronger RESET circuit.
  • Atmega16U2 replace the 8U2
Ordering option:
Part NumberDescription
A000046A000046Revision 2 of the Arduino Uno board
A000066A000066Revision 3 of the Arduino Uno board
Key Applications: Building Automation, Industrial Automation.
imageMore Atmel Development KitsimageAtmel Overview
Development Tools
Software Development Tools:
IDEAtmel
Atmel Studio 6
ALL AVR
Atmel Studio 6 Integrated Development Environment (IDE) is the integrated development environment (IDE) for developing and debugging Atmel ARMRegistered CortexTm-M and Atmel AVRRegistered microcontroller (MCU) based applications. The Atmel Studio 6 IDE gives you a seamless and easy-to-use environment to write, build and debug your applications written in C/C++ or assembly code. Learn More
RTOSMicrium
Micrium uc/OSIII
AVR / AVR32
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Learn More
RTOSSegger
embOS
AVR32
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications. Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsAtmel
ATAVRDRAGONATAVRDRAGON
AVR UC3 / AVR XMEGA / megaAVR / tinyAVRAVR Dragon JTAG Debugger Starter Kit for for 8-bit and 32-bit AVR devices
ATAVRONEKITATAVRONEKIT
AVR UC3 / AVR XMEGA / megaAVR / tinyAVRAVR ONE! professional development tool for all Atmel 8-bit and 32-bit AVR devices
ATJTAGICE2ATJTAGICE2
AVR UC3 / AVR XMEGA / megaAVR / tinyAVRAVR JTAGICE mkII mid-range development tool for Atmel 8-bit and 32-bit AVR devices
ATAVRISP2ATAVRISP2
AVR XMEGA / megaAVR / tinyAVRAVRISP mkII Programmer for field upgrades of Atmel 8-bit AVR microcontrollers with ISP or PDI interfaces
Back to top
Technical Documents
Learning Center
TypeDescription
Application NoteAtmel: TV Control Touch Keyboard
Application NoteAtmel: Digital Filters with AVR
Application NoteAtmel: Understanding ADC parameters
Application NoteAtmel: LED Driver Library for 8-bit AVR
Design Elements
TypeDescription
SchematicsArduino: Uno schematic_Rev3
Reference DesignArduino: Uno Reference Design_Rev3
Code SnippetArduino: SCP1000 Barometric Pressure Sensor Display
Code SnippetArduino: Sample Code for Digital Pot Control
Code SnippetArduino: Sample Code for Servo Library
Back to top
Video
Back to top
Kit Features
  • Operating Voltage: 5V
  • Microcontroller: ATmega328ATmega328
  • Input Voltage (recommended): 7-12V
  • Input Voltage (limits): 6-20V
  • Digital I/O Pins:14(of which 6 provide PWM output)
  • Analog Input Pins: 6
  • DC Current per I/O Pin: 40mA
  • DC Current for 3.3V Pin: 50mA
  • Flash Memory: 32KB (ATmega328ATmega328) of which 0.5 KB used by bootloader
  • SRAM: 2KB(ATmega328ATmega328)
  • EEPROM: 1KB(ATmega328ATmega328)
  • Clock Speed: 16MHz
Back to top
Kit Contents
  • Arduino Uno board
  • The ATmega328 on the Arduino Uno comes preburned with a bootloader
Back to top
  • r3
  • atmega328
  • uno
  • atmel
