Technical Library
  • Technical Library
Technical Library
Documents Development Kit Line Card - Atmel
  • Author Author: atomar
  • Date Created: 31 May 2012 5:33 AM Date Created
  • Last Updated Last Updated: 27 Mar 2014 1:45 AM
  • Views 1302 views
imageThe Atmel Development boards / Kits provide you with everything you need to start designing with Atmel devices. Select below evaluation boards & kits by product family.
8-bit AVR  |  32-bit AVR  |  SAM3 (Cortex-M3)  |  SAM4 (Cortex-M4)  |  SAMA5 (Cortex-A5) New!  |SAM7 (ARM7)  |  SAM9 (ARM9)  |  8051  |  STK600 & Add-Ons
8-Bit AVRBack to Top
Part NumberCore ArchitectureSilicon FamilyDescription
ATAVRBFLYATAVRBFLYmegaAVRATmega169AVR Butterfly Evaluation Kit Based on ATmega169 LCD Controller
ATAVR128RFA1-EK1ATAVR128RFA1-EK1megaAVRATmega128RFA1ATAVR128RFA1-EK1 Evaluation Kit for ATmega128RFA1 Single-chip 8-bit MCU
ATAVRRZRAVENATAVRRZRAVENmegaAVRATmega1284PV / ATmega3290PVATAVRRZRAVEN 2.4 GHz Evaluation and Starter kit
AT90USBKEYAT90USBKEYmegaAVRAT90USB1287AT90USBKEY Demonstration Board based on the AT90USB1287 Microcontroller
AT90USBKEY2AT90USBKEY2megaAVRAT90USB1287AT90USBKEY Demonstration Board based on the AT90USB1287 Microcontroller
ATAVRMC320ATAVRMC320megaAVRATMEGA32M1ATAVRMC320 Low Voltage Motor Control Kit  for ATmega32M1 Microcontroller
ATDVK90CAN1ATDVK90CAN1megaAVRAT90CAN128ATDVK90CAN1 Development Kit for AT90CAN AVR Microcontrollers
ATMEGA1284P-XPLDATMEGA1284P-XPLDmegaAVRATmega1284PATMEGA1284P-XPLD Xplained Evaluation Kit for ATmega1284P Microcontrollers
ATMEGA256RFR2-XPROATMEGA256RFR2-XPROmegaAVRATmega256RFR2ATMEGA256RFR2-XPRO Xplained Pro Evaluation Kit for ATmega256RFR2 Microcontrollers
ATMEGA256RFR2-XSTKATMEGA256RFR2-XSTKmegaAVRATmega256RFR2ATMEGA256RFR2-XPRO Xplained Pro Evaluation Kit for ATmega256RFR2 Microcontrollers
ATAVRSB200ATAVRSB200Battery Management AVRATmega32HVBATAVRSB200 Battery Management Development Kit for HVB Smart Battery Devices
ATAVRSB201ATAVRSB201Battery Management AVRATmega16HVAATAVRSB201 Battery Management Development Kit for HVA Smart Battery Devices
ATAVRXBNDLXMEGAATxmega128A1ATAVRXBNDL QTouch Xplained Kit Bundle
ATAVRXPLAINATAVRXPLAINXMEGAATxmega128A1ATAVRXPLAIN XMEGA-A1 Xplained Evaluation Kit for ATxmega128A1 Microcontroller
ATXMEGAA3BU-XPLDATXMEGAA3BU-XPLDXMEGAATxmega256ATXMEGAA3BU-XPLD Xplained Evaluation Kit for ATxmega256A3BU Microcontroller
ATXMEGAB1-XPLDATXMEGAB1-XPLDXMEGAATxmega128ATXMEGAB1-XPLD XMEGA-B1 Xplained Evaluation Kit for ATxmega128B1 Microcontroller
ATQT600ATQT600tinyAVR/megaAVR/XMEGAATtiny88 / ATmega324PA / ATxmega128A1ATQT600 Complete Touch Development Kit for Buttons, Sliders, and Wheels
32-bit AVRBack to Top
AT32UC3A3-XPLDAT32UC3A3-XPLDAVR UC3AT32UC3A3AT32UC3A3-XPLD Xplained Evaluation Kit for AVR UC3A3 MCU
AT32UC3L0-XPLDAT32UC3L0-XPLDAVR UC3AT32UC3LAT32UC3L0-XPLD Evaluation Kit for AVR UC3L  picoPower MCU
AT32UC3C-EKAT32UC3C-EKAVR UC3AT32UC3C0512CAT32UC3C-EK Evaluation Kit for AVRRegistered UC3 AT32UC3C0512C MCU
AT32UC3L-EKAT32UC3L-EKAVR UC3AT32UC3L064AT32UC3L-EK Evaluation Kit for AVR UC3 AT32UC3L064 MCU
SAM3 (Cortex-M3)Back to Top
ATSAM3N-EKATSAM3N-EKARM Cortex-M3ATSAM3NATSAM3N-EK Evaluation Kit for ARM Cortex-M3 based SAM3N series MCUs
ATSAM3S-EK2ATSAM3S-EK2ARM Cortex-M3ATSAM3S / ATSAM3SDATSAM3S-EK2 Evaluation Kit for ARM Cortex-M3 based SAM3S and SAM3SD MCUs
ATSAM3U-EKATSAM3U-EKARM Cortex-M3ATSAM3UATSAM3U-EK Evaluation Kit for ARM Cortex-M3 based SAM3U MCUs
ATSAM3X-EKATSAM3X-EKARM Cortex-M3ATSAM3X / ATSAM3AATSAM3X-EK Evaluation Kit for ARM Cortex-M3 based SAM3X and SAM3A MCUs
SAM4 (Cortex-M4)Back to Top
ATSAM4L-XPROATSAM4L-XPROARM Cortex-M4ATSAM4LATSAM4L-XPRO Xplained Pro Evaluation Kit for ARM Cortex-M4 based SAM4L MCU
ATSAM4L-XSTKATSAM4L-XSTKARM Cortex-M4ATSAM4LATSAM4L-XSTK Xplained Pro Starter Kit for ARM Cortex-M4 based SAM4L MCU
ATSAM4S-XPROATSAM4S-XPROARM Cortex-M4ATSAM4SATSAM4S-XPRO Xplained Pro Evaluation Kit for ARM Cortex-M4 based SAM4S MCU
ATSAM4S-XSTKATSAM4S-XSTKARM Cortex-M4ATSAM4SATSAM4S-XPRO Xplained Pro Starter Kit for ARM Cortex-M4 based SAM4S MCU
ATSAM4S-EK2ATSAM4S-EK2ARM Cortex-M4ATSAM4SATSAM4S-EK2 Evaluation Kit for ARM Cortex-M4 based SAM4S MCU
SAMA5D3 (Cortex-A5)Back to Top
ATSAMA5D3-XPLDATSAMA5D3-XPLD    New!ARM Cortex-A5SAMA5D3ATSAMA5D3-XPLD Xplained Kit for SAMA5D3 ARMRegistered CortexRegistered-A5 Processor
ATSAMA5D31-EKATSAMA5D31-EKARM Cortex-A5SAMA5D3SAMA5D3 Series Evaluation Kits for Atmel SAMA5D31/3/4/5 ARM-based Embedded MPU
ATSAMA5D33-EKATSAMA5D33-EKARM Cortex-A5SAMA5D3SAMA5D3 Series Evaluation Kits for Atmel SAMA5D31/3/4/5 ARM-based Embedded MPU
ATSAMA5D34-EKATSAMA5D34-EKARM Cortex-A5SAMA5D3SAMA5D3 Series Evaluation Kits for Atmel SAMA5D31/3/4/5 ARM-based Embedded MPU
ATSAMA5D35-EKATSAMA5D35-EKARM Cortex-A5SAMA5D3SAMA5D3 Series Evaluation Kits for Atmel SAMA5D31/3/4/5 ARM-based Embedded MPU
SAM7 (ARM7)Back to Top
AT91SAM7SE-EKAT91SAM7SE-EKARM7ATSAM7SEAT91SAM7SE-EK Evaluation Kit for the SAM7SE MCU
AT91SAM7X-EKAT91SAM7X-EKARM7ATSAM7XAT91SAM7X-EK Evaluation Board for the AT91SAM7X and AT91SAM7XC MCUs
AT91SAM7S-EKAT91SAM7S-EKARM7SAM7S16AT91SAM7S-EK Evaluation Kit for ARM Based AT91SAM7S Family
SAM9 (ARM9) Back to Top
AT91SAM9260-EKAT91SAM9260-EKARM9ATSAM9260AT91SAM9260-EK Evaluation Board for the SAM9260 MCU
AT91SAM9G20-EKAT91SAM9G20-EKARM9ATSAM9G20AT91SAM9G20-EK Evaluation Board for the SAM9G20 MCU
AT91SAM9M10-G45-EKAT91SAM9M10-G45-EKARM9ATSAM9G45 / ATSAM9M10AT91SAM9M10-G45-EK ARM926-based eMPU Evaluation Kit
AT91SAM9XE-EKAT91SAM9XE-EKARM9ATSAM9XEAT91SAM9XE-EK Evaluation Board for ARM based SAM9XE Microcontrollers
8051Back to Top
AT89STK-11AT89STK-118051AT89AT89STK-11 Starter Kit for ISP-standard Flash C51 microcontrolers
STK600 & Add-OnsBack to Top
Part NumberCore ArchitectureDescription
ATSTK600ATSTK600AVRATSTK600 Starter kit for the 8-bit and 32-bit AVR MCUs
ATSTK600-RC01ATSTK600-RC01tinyAVRRouting card for the 20-pin tinyAVR in DIP Socket
ATSTK600-RC02ATSTK600-RC02tinyAVRRouting Card for 8-pin tinyAVR in DIP Socket
ATSTK600-RC04ATSTK600-RC04megaAVRRouting Card for megaAVR40-pin DIP Socket
ATSTK600-RC05ATSTK600-RC05megaAVRRouting Card for megaAVR 44-pin DIP Socket
ATSTK600-RC06ATSTK600-RC06megaAVRRouting Card for megaAVR 28-pin DIP Socket
ATSTK600-RC08ATSTK600-RC08tinyAVRRouting Card for tinyAVR 20-pin DIP Socket
ATSTK600-RC09ATSTK600-RC09megaAVRRouting Card for megaAVR 64-pin TQFP Socket
ATSTK600-RC10ATSTK600-RC10megaAVRRouting Card for megaAVR 64-pin TQFP Socket
ATSTK600-RC11ATSTK600-RC11megaAVRRouting Card for megaAVR 100-pin TQFP Socket
ATSTK600-RC12ATSTK600-RC12tinyAVRRouting Card for tinyAVR 14-pin DIP Socket
ATSTK600-RC13ATSTK600-RC13XMEGARouting Card for AVR XMEGA 100-pin TQFP Socket
ATSTK600-RC14ATSTK600-RC14XMEGARouting Card for 64-pin XMEGA in TQFP Socket
ATSTK600-RC15ATSTK600-RC15XMEGARouting Card for XMEGA 44-pin TQFP Socket
ATSTK600-RC17ATSTK600-RC17megaAVRRouting Card for megaAVR 64-pin TQFP Socket
ATSTK600-RC18ATSTK600-RC18megaAVRRouting Card for megaAVR 100-pin TQFP Socket
ATSTK600-RC19ATSTK600-RC19AVR (PWM)Routing Card for AVR PWM Series 24/32-pin SOIC Socket
ATSTK600-RC20ATSTK600-RC20megaAVRRouting Card for megaAVR 32-pin TQFP Socket
ATSTK600-RC21ATSTK600-RC21AVR UC3Routing Card for AVR UC3 B0 Series 64-pin TQFP Socket
ATSTK600-RC22ATSTK600-RC22megaAVRRouting Card for megaAVR 32-pin TQFP Socket
ATSTK600-RC23ATSTK600-RC23tinyAVRRouting Card for tinyAVR 20-pin SOIC Socket
ATSTK600-RC24ATSTK600-RC24megaAVRRouting Card for megaAVR 44-pin TSSOP Socket
ATSTK600-RC25ATSTK600-RC25megaAVRRouting Card for megaAVR 44-pin TQFP Socket
ATSTK600-RC26ATSTK600-RC26AVR (PWM)Routing Card for AVR PWM Series 20-pin SOIC Socket
ATSTK600-RC27ATSTK600-RC27AVR UC3Routing Card for Atmel AVR UC3 B1 Series 48-pin TQFP and QFN Socket
ATSTK600-RC28ATSTK600-RC28AVR UC3Routing Card for Atmel AVR UC3 A1 Series 100-pin TQFP Socket
ATSTK600-RC29ATSTK600-RC29megaAVRRouting Card for megaAVR 32-pin TQFP Socket
ATSTK600-RC30ATSTK600-RC30megaAVRRouting Card for megaAVR 44-pin TQFP Socket
ATSTK600-RC31ATSTK600-RC31megaAVRRouting Card for megaAVR 44-pin TQFP Socket
ATSTK600-RC32ATSTK600-RC32AVR UC3Routing Card for AVR UC3 A3 Series 144-pin TQFP Socket
ATSTK600-RC33ATSTK600-RC33AVR UC3Routing Card for AVR UC3 A0 Series 144-pin TQFP Socket
ATSTK600-RC34ATSTK600-RC34AVR UC3Routing Card for AVR UC3 L0 Series 48-pin TQFP Socket
ATSTK600-RC36ATSTK600-RC36AVR UC3Routing Card for AVR UC3 C0 Series 144-pin DIP Socket
ATSTK600-RC38ATSTK600-RC38AVR UC3Routing Card for AVR UC3 C1 Series 100-pin TQFP Socket
ATSTK600-RC40ATSTK600-RC40AVR UC3Routing Card for AVR UC3 C2 Series 64-pin DIP Socket
ATSTK600-RC42ATSTK600-RC42tinyAVRRouting Card for tinyAVR 14-pin DIP Socket
ATSTK600-RC44ATSTK600-RC44tinyAVRRouting Card for tinyAVR 20-pin SOIC Socket
ATSTK600-RC45ATSTK600-RC45megaAVRRouting Card for megaAVR 32-pin Socket
ATSTK600-RC46ATSTK600-RC46tinyAVRRouting Card for tinyAVR 14-pin DIP Socket
ATSTK600-RC47ATSTK600-RC47AVR UC3Routing Card for 64-pin AVR UC3 L3U Series in TQFP Socket
ATSTK600-RC48ATSTK600-RC48AVR UC3Routing Card for 64-pin AVR UC3 D3 Series in TQFP Socket
ATSTK600-RC50ATSTK600-RC50XMEGARouting Card for XMEGA 100-pin TQFP Socket
ATSTK600-RC51ATSTK600-RC51XMEGARouting Card for 64-pin XMEGA in TQFP Socket
ATSTK600-RC55ATSTK600-RC55XMEGARouting Card for XMEGA 44-pin TQFP Socket
ATSTK600-SC01ATSTK600-SC01AVRGeneric STK600 Socket Card for Devices in DIP Package up to 40-pin
ATSTK600-SC02ATSTK600-SC02AVRGeneric STK600 Socket Card for Devices in 64-pins TQF Package
ATSTK600-SC03ATSTK600-SC03AVRGeneric STK600 Socket Card for Devices in 100-pin TQFP Package
ATSTK600-SC06ATSTK600-SC06AVRGeneric STK600 Socket Card for Devices in 44-pin TQFP Package
ATSTK600-SC10ATSTK600-SC10AVRGeneric STK600 Socket Card for Devices in 32-pin TQFP Package
ATSTK600-SC11ATSTK600-SC11AVRGeneric STK600 Socket Card for SOIC14/20/24/32 Wide Devices
ATSTK600-SC13ATSTK600-SC13AVRGeneric STK600 Socket Card for Devices in 44-pin TSSOP Package
ATSTK600-SC14ATSTK600-SC14AVRGeneric STK600 Socket Card for Devices in 64-pin TQFP Package
ATSTK600-SC16ATSTK600-SC16AVRGeneric STK600 Socket Card for Devices in 48-pin TQFP Package
ATSTK600-SC19ATSTK600-SC19AVRGeneric STK600 Socket Card for Devices in 144-pin TQFP Package
ATSTK600-ATTINY10ATSTK600-ATTINY10tinyAVRPart specific MCU Card for Selected tinyAVR Devices
ATSTK600-TINYX3UATSTK600-TINYX3UtinyAVRSocket Card for ATtinyX3U MCU
ATSTK600-LCD160ATSTK600-LCD160megaAVR / XMEGALCD Expansion Module for megaAVR / XMEGA Devices
