Technical Library
  • Technical Library
Technical Library
Documents Embest: SBC6000X Single Board Computer using Atmel’s AT91SAM9261S Microcontroller
  • Author Author: atomar
  • Date Created: 2 May 2013 6:18 AM Date Created
  • Last Updated Last Updated: 24 Oct 2013 7:08 AM
  • Views 2309 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Overview
Embest SBC6000XSBC6000X is an embedded single board computer using Atmel’s AT91SAM9261SAT91SAM9261S microcontroller with low power and high reliability. The board is a compact board with various peripheral interfaces including USB Host/Device, Ethernet, LCD/Touch Screen, Serial ports, Keyboard, Audio, SPI, SD and BUS. It features an extended precise RTC and RS485 with isolation. It’s peripheral interfaces features ESD protection. The board is capable of supporting both Windows CE 6.0 and Linux 2.6.24 OS and Embest provides BSP package, user manual and some other tools and documents to help the users better understand this board.  Microsoft EVC or the provided linux tool chain can be used to speed the development and subsequently your time to market.
The SBC6000XSBC6000X has various industrial Bus interfaces which can work stably between -10℃~70℃  or in any rigorous environment. Some  fields have high requirements for communication, such as industrial field control, intelligent instrument, industrial control terminal and car electronics.
The Atmel’ AT91SAM9261SAT91SAM9261S processor is an ARM926EJ-S based high-performance 32-bit RISC Microcontroller with 16K byte instruction and 16K byte data cache memories; it is pin-to-pin compatible with the AT91SAM9261AT91SAM9261. It has additional 32K Bytes ROM, 16K Bytes SRAM embedded memories and can operate at 210 MIPS with a 190 MHz clock. Its extensive peripheral set includes USB 2.0, External Bus Interface, LCD Controller, Bus Matrix, System Controller, Reset Controller, Shutdown Controller, Clock Generator, Power Management Controller, Advanced Interrupt Controller, Debug Unit, Periodic Interval Timer, Watchdog Timer, Real-Time Timer, Three 32-bit PIO Controllers, Nineteen Peripheral DMA Channels (PDC), Multimedia Card Interface (MCI), Three Synchronous Serial Controllers (SSC), Three Universal Synchronous/Asynchronous Receiver Transmitters (USART), Two Master/Slave Serial Peripheral Interface (SPI), One Three-channel 16-bit Timer/Counters (TC), Two-wire Interface (TWI), IEEE 1149.1 JTAG Boundary Scan.
Ordering Information:
MPNDescription
SBC6000XSBC6000XSBC6000X Single Board Computer
SBC6000X WITH 4.3''LCDSBC6000X WITH 4.3''LCDSBC6000X Single Board Computer with 4.3 inch LCD
SBC6000X WITH 7''LCDSBC6000X Single Board Computer with 7 inch LCD
Key Applications: Home Entertainment, Industrial Automation, Metering, Mobile Electronics
imageMore Embest Development KitsimageMore ARM Developement Kits
imageKnode Development Kits & Platform Roomimageelement14 Knode
Development Tools
Software Development Tools:
IDEAtmel
Atmel Studio 6
ALL ARM
Atmel Studio 6 Integrated Development Environment (IDE) is the integrated development environment (IDE) for developing and debugging Atmel ARMRegistered CortexTm-M and Atmel AVRRegistered microcontroller (MCU) based applications. The Atmel Studio 6 IDE gives you a seamless and easy-to-use environment to write, build and debug your applications written in C/C++ or assembly code. Learn More
IDEARM KeilMDK ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9Tm
The MDK-ARM (Microcontroller Development Kit) is the complete software development environment for ARM7, ARM9, Cortex-M, and Cortex-R4 processor-based devices.  Learn More
RTOSMicrium
Micrium uc/OSIII
ALL ARM
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and subsequent embedded sytem projects. Learn More
RTOSARM KeilKEIL RTXALL ARM
The Keil RTX is a royalty-free, deterministic Real-Time Operating System designed for microcontrollers based on ARM7TmTDMI, ARM9Tm, and CortexTm-M CPU cores. Learn More
RTOSSegger
embOS
ALL ARM
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications. Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsAtmel
AT91SAM-ICEAT91SAM-ICE
SAM3 / SAM7 / SAM9
USB JTAG In-Circuit Emulator for SAM3, SAM7 and SAM9 ARM-based microcontrollers
Emulator / Debugger / ProgrammerARMULINK2ULINK2ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideEmbest: User Guide for SBC6000X Single Board Computer
DatasheetAtmel: Summary of Preliminary Datasheet for AT91SAM9261
DatasheetAtmel: Preliminary datasheet for AT91SAM9261
Application NoteAtmel: Getting Started with the AT91SAM9261 Microcontroller
Design Elements
TypeDescription
LayoutEmbest: Layout file for SBC6000X Single Board Computer (Top View)
Application LibraryAtmel: Software Code for AT91SAM9 LCD Controller
Application LibraryAtmel: Software Code for NAND Flash Support on AT91SAM9 Microcontrollers
Application LibraryAtmel: Software Code for Using SDRAM on AT91SAM9 Microcontrollers
Application LibraryAtmel: Software Code for Using the Serial Peripheral Interface with AT91SAMxx Devices
Back to top
Video
Back to top
Kit Features
Features of SBC6000XSBC6000X Single Board Computer:
Hardware Features:
  • Dimensions: 106.5mm x 94mm
  • Power Supply: +12V
  • Working Temperature: -10~70°C
  • Power Output Interface: +5V and Vin (±5%)
  • Processor: Atmel’ AT91SAM9261SAT91SAM9261S (ARM926EJ-S core with MMU capable of 200MHz operation)
  • 64Mbyte SDRAM (2*16-bit, support up to 128Mbyte)
  • 128Mbyte NAND Flash (support up to 256Mbyte, bootable)
  • 4/8Mbyte Data Flash (Reserved for soldering, bootable, multiplex with SD/MMC interface)
  • 2Kbit EEPROM
  • 10M/100M Ethernet port (DM9000DM9000)
  • Three serial ports (COM0: 3-wire Debug serial port, COM1: 5-wire RS232/TTL serial port, COM2: 5-wire RS232/TTL/RS485 serial port)
  • Two USB2.0 full-speed (12 Mbits/S) Host ports
  • USB2.0 full-speed (12Mbits/S) Device port
  • SPI interface
  • 2*20-pin LCD interface
  • Touch screen (4-channel 12-bit ADC)
  • Audio Input/Output Jacks
  • RTC (battery backed)
  • Buzzer
  • SD card socket
  • LED (CPU working station indicator)
  • Three Buttons (two for user defined, one for Reset)
  • Power switch
  • 4*4 keyboard interface
  • 16 GPIOs (10 from CPU, 6 from extension)
  • BUS interface (with buffer)
  • Supports Linux 2.6 OS and WinCE6.0 OS
Software Features:
OSItemFeatureDescription
LinuxBootVersionu-boot 1.3.4
Boot ModeBoot from NAND Flash or SD card
Download ModeDownload kernel and file system from Ethernet
Update kernelSupport programming kernel image into NandFlash
Update file systemSupport programming Yaffs2 file system into NandFlash
Kernel and driversVersionLinux 2.6.24
File systemSupport ROM/CRAM/EXT2/RAMDISK/YAFFS2/FAT32
DriverSerial, RTC, NET, LCD, Touch Screen, Audio out, SD, USB, Keypad, EEPROM, GPIO, Buzzer
File SystemFormatyaffs2 file system, can be read and written
Network protocol and applicationsTCP/IPComplete TCP/IP protocol
System configuration and service
Network Ping
Ping command, used in checking system
Ifconfig, route, inetd
Used in network configuration and relative service program
Login, sh, echo, discard
Login and other program
Webserver
Use apache-1.3.41
Basic command
Linux command
Cat, chmod, discard, echo, flashwrite, flashfsd, free, genhtml, init, kill, loader, Ls, mkdir, mount, ps, reboot, rm, smanaged, sysconf, yes, insmod, lsmod, rmmod
Graphics libraryGTK2.0+graphics Development libraryAlready ported
WinCEBootVersionEboot (Wince 6.0)
Download ModeDownload image from Ethernet or SAM-BA
KernelVersionWinCE6.0
DriverSerial, RTC, NET, LCD, Touch Screen, Audio out, SD, USB, Keypad, GPIO
Back to top
Kit Contents
1. The Embest SBC6000XSBC6000X supplied with below contents:
  • SBC6000X board
  • Serial cable
  • Ethernet cable
  • USB cable
  • 12V power adapter
  • LCD (optional, including touch screen)
    • Remark: 4.3 inch LCD (resolution: 480*272), 5.6 inch LCD (resolution: 640*480), 7 inch LCD (resolution: 800*480)
Back to top
  • at91sam9261s
  • at91sam9261
  • sbc6000x
  • arm926ej-s
  • sbc6000x_with_4.3''lcd
  • embest
  • dm9000
  • atmel
