EAGLE User Chat (English) The big NNTP vs HTML forum war collection
  • Replies 16 replies
  • Subscribers 189 subscribers
  • Views 1636 views
For the ones that can't hold it back, here you can put your pro's and con's
and flame as much as you like. And Klaus can happily ignore (or read only)
if he wants:)
PLEASE PROVIDE FACTS BEFORE FLAMES.
Here is my list. I have triedto be neutral here!
NNTP pros:
  • Quick access. Personally I always have my email reader open, and the NNTP
is within the same app.
  • Quick overview. You can see instantly how many posting and a list of
topics
  • Cheap serving. There are lot of free noad servers out there.
  • Fast navigation.
  • Compact view
  • More spam resistant (that does not go for NNTP in general, but cadsoft's
forum has very little of it, if any at all)
  • Lowcost bandwidth
  • Low complexity
  • Several free apps to use it
  • It takes a lot less time to get through all messages than on HTTP.
  • No need to register
NNTP cons:
  • Port access. Some paranoid network administrators block NNTP port access.
  • Not very noob friendly. If you havent used a NNTP reader before, you need
to learn and get used to it.
  • Messages may look "boring" in plain text.
  • Text wrapping and quoting easily get messed up; in general not very
formatting friendly
  • Search unfriendly. All search has to happen on local copy of the message
list.
  • First time access load of all old messages takes a long time (maybe
Cadsoft has a low bandwidth to their servers?)
  • Sometimes need an extra app
HTTP pros:
  • Colors, emoticons, larger attachments (well, that is possible with NNTP
too, but not likely). In theory NNTP can do HTML content, but that is not
likely to happen.
  • Easier to get to
  • Normally doesnt need an extra app; most users already got a browser
installed.
HTTP cons:
  • I normally don't have a browser open at all times, and it takes a few
seconds to load the browser, even if I make a shortcut link to the site.
  • Navigation complexity. I have only see one forum which has a nice way of
navigating, but it only does plain text too.
  • Navigation speed. Moving from one message to the next is slower than NNTP.
  • Currently two custom 'accents' (element14 or eaglecentral) that needs to
be learned. There exist some common web forum formats, but afaik none of
them are used.
  • Higher cost and complexity of serving
  • Spam protection is harder
  • User account normally needed
Ok, thats all I can think of right now. Maybe you have something to add?
    "Morten Leikvoll" wrote:
    >"Olin Lathrop" <eagle@embedinc.com> wrote in message
    >news:i99hb5$afm$1@cheetah.cadsoft.de...
    >> problem can be solved in various ways.  If I were doing it, I'd eliminate
    >> the silly emoticon icons from the web interface and be done with it.  If
    >What is the difference between your ideal way of doing it and a GOOD (maybe
    >vaporware) nntp web interface?
    from Olin's postings, I extract
    • "HTML-like links",
    • inline pictures,
    • larger attachments.
    Maybe I missed something, but I don't expect something important
    beyond this.
    The other things like displaying /italics/ bold underline etc. can
    be done also with a NNTP web interface (if the user wants such
    gadgets).
    Hidden links and inline pictures are also cosmetic, so remains storage
    for large files. That can be an upload area dedicated to the
    discussion groups (I already mentioned the SwitcherCad mailing list).
    Oliver
    Olin Lathrop wrote:
    >Clearly Element-14 has a problem translating emoticons into text, however
    Mainly I meant that the happy.gif picture is not better than three
    ASCII letters ":-)". The stuff around is just another e14 issue.
    But the lack of a thread view (and therefore the unsorted postings
    from e14) is much worse.
    Oliver
    Morten Leikvoll wrote on Fri, 15 October 2010 08:51
    (maybe vaporware) nntp web interface?
    Many, as I have already enumerated above and earlier.
    Oliver Betz wrote on Fri, 15 October 2010 03:34
    (displaying
    http://www.element-14.com/community/4.5.3/images/emoticons/happy.gif)
    is of course much better than a simple ":-)" which can't be understood
    by today's users.
    I know you said you're being cynical, but this kind of comment doesn't
    help.  Let's keep a clear distinction between problems with the existing
    implementation, and issues with the underlying concept.
    that is not a fundamental problem of forum to text interfaces.  This
    you really wanted to keep them, just have each expand to a predefined set
    of characters.
    Again, let's not have the Element-14 bashing (much of it well deserved)
    confuse people into thinking the problems are inherent to web to text
    interfaces (which most of them are not).
    Olin Lathrop wrote:
    >posts are stored and organized as forum posts.  That means the richer
    >meta-information like formatting, in-line images, HTML-like links (you can
    >make clickable words with the actual link text hidden), and a number of
    >other nice features are all preserved in the database.
    >The rich features would be converted to a plain text format on demand by
    >the NNTP interface software.  Most features have obvious enough mappings to
    I see. image
    (displaying
    by today's users.
    For so much benefit, we can also give up correct threading. Not to
    mention well-considered postings.
    </cynical>
    Will June 2010 be as eternal as September 1993? At least it seems to
    be worse.
    SCNR
    Oliver
    Morten Leikvoll wrote on Fri, 08 October 2010 04:01
    need to learn and get used to it.
    >"Olin Lathrop"  replied
    ............Don't understimate this.  Anyone who didn't use newsgroups in
    the 1990s
    simply isn't going to use NNTP.  ........They will also view Farnell as
    stuck in
    the stone age if they don't have a good web forum.
    Wrong! I am a recent adopter of NNTP (only for Cadsoft). I'm a fan and
    prefer it by far over the many and varied web forums for reasons of speed.
    "On the go" web access for mobile devices will see the modern revival  of
    NNTP (or similar). The smart company will repackage its NNTP as a light
    weight mobile service. Out of the stone age in one leap!
    So I see all three avenues coexisting. NNTP and a mobile service (view)
    along with the full experience desktop web site.
    Warren
    Morten Leikvoll Inscribed thus:
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:i8mk94$pqg$1@cheetah.cadsoft.de...
    >> Our server is connected through a 100Mbit/s line - should be fast
    >> enough.
    Hmm.. Do you have any explanation why downloading the full, say
    eagle.userchat.eng takes so long?
    Is it just something in NNTP's nature, or is it just file access of
    several small files that does it?
    Loading headers only is fast, but messages is at the rate of 1-10 pr
    second. Having 5209 messages, this is enough to give up waiting..
    I'm on 50Mbit and here is my tracert:
    Tracing route to cheetah.cadsoft.de
    over a maximum of 30 hops:
      1    <1 ms    <1 ms    <1 ms  10.20.0.1
      2    <1 ms    <1 ms    <1 ms  79.161.3.29.static.lyse.net
      3    <1 ms    <1 ms    <1 ms  209.81-167-101.customer.lyse.net
      4    <1 ms    <1 ms    <1 ms  233.84-234-190.customer.lyse.net
      5    <1 ms    <1 ms    <1 ms  138.213-167-114.customer.lyse.net
      6    14 ms    13 ms    13 ms  118.81-166-123.customer.lyse.net
      7    14 ms    15 ms    14 ms  init7.dix.dk
      8    26 ms    26 ms    26 ms  r1ams1.core.init7.net
      9    32 ms    32 ms    35 ms  r1fra1.core.init7.net
    10    32 ms    32 ms    32 ms  gw-hetzner.init7.net
    11    37 ms    37 ms    37 ms  hos-bb1.juniper2.fs.hetzner.de
    12    37 ms    37 ms    37 ms  hos-tr3.ex3k2.rz10.hetzner.de
    13    39 ms    37 ms    37 ms  cheetah.cadsoft.de
    Trace complete.
    Here is mine FWIW. I'm in the UK.
    traceroute to 188.40.46.46 (188.40.46.46), 30 hops max, 40 byte packets
    using UDP
    1  Lan  17.768 ms   12.271 ms   100.270 ms
    2  * * *
    3  * * *
    4  * * *
    5  * xe-9-2-0.edge3.London1.Level3.net (212.113.15.69)  21.757 ms
    22.860 ms
    6  ae-34-52.ebr2.London1.Level3.net (4.69.139.97)  23.002 ms   23.766
    ms   24.037 ms
    7  ae-45-45.ebr2.Amsterdam1.Level3.net (4.69.143.69)  30.528 ms
    ae-46-46.ebr2.Amsterdam1.Level3.net (4.69.143.73)  31.964 ms
    ae-47-47.ebr2.Amsterdam1.Level3.net (4.69.143.77)  30.667 ms
    8  ae-1-100.ebr1.Amsterdam1.Level3.net (4.69.141.169)  30.620 ms
    29.451 ms   31.002 ms
    9  ae-47-47.ebr2.Dusseldorf1.Level3.net (4.69.143.206)  33.580 ms
    ae-45-45.ebr2.Dusseldorf1.Level3.net (4.69.143.198)  34.502 ms   35.209
    ms
    10  ae-1-100.ebr1.Dusseldorf1.Level3.net (4.69.141.149)  37.921 ms
    42.508 ms   41.281 ms
    11  ae-45-45.ebr2.Frankfurt1.Level3.net (4.69.143.166)  37.459 ms
    ae-46-46.ebr2.Frankfurt1.Level3.net (4.69.143.170)  40.167 ms
    ae-45-45.ebr2.Frankfurt1.Level3.net (4.69.143.166)  36.962 ms
    12  ae-82-82.csw3.Frankfurt1.Level3.net (4.69.140.26)  37.093 ms
    41.820 ms ae-62-62.csw1.Frankfurt1.Level3.net (4.69.140.18)  44.650 ms
    13  ae-1-69.edge3.Frankfurt1.Level3.net (4.68.23.11)  38.717 ms
    ae-3-89.edge3.Frankfurt1.Level3.net (4.68.23.139)  38.018 ms
    ae-2-79.edge3.Frankfurt1.Level3.net (4.68.23.75)  38.350 ms
    14  HETZNER-ONL.edge3.Frankfurt1.Level3.net (212.162.40.206)  36.456 ms
    36.184 ms   35.698 ms
    15  hos-bb1.juniper1.fs.hetzner.de (213.239.240.242)  43.514 ms
    hos-bb1.juniper2.fs.hetzner.de (213.239.240.243)  41.793 ms
    hos-bb1.juniper1.fs.hetzner.de (213.239.240.242)  41.623 ms
    16  hos-tr3.ex3k2.rz10.hetzner.de (213.239.227.195)  41.380 ms
    hos-tr2.ex3k2.rz10.hetzner.de (213.239.227.163)  40.579 ms
    hos-tr4.ex3k2.rz10.hetzner.de (213.239.227.227)  42.186 ms
    end
    Best Regards:
                         Baron.
    Good compilation.
    Threading and efficient user interface are my most important
    arguments.
    >NNTP cons:
    >* Text wrapping and quoting easily get messed up; in general not very
    >formatting friendly
    most forum software makes smart quoting very, very complicated. Ever
    tried to quote several parts separately, and to trim quotes? So this
    is a NNTP con only if someone makes a really web good forum software.
    >HTTP pros:
    >* Colors, emoticons,
    I want to transport facts, not play with fancy emoticons. I found that
    most people don't need long to understand ASCII emoticons. And it's
    typed much faster than selected with the mouse. Well, no problem for
    me if the gateway translates it. BTW: IM clients use ASCII to encode
    emoticons.
    File storage can be separate (IOW an addition) from the discussion
    solution. Look at the SwitcherCad mailing list.
    Oliver
    Oops, sorry for that posting. It was the horrible ctrl+enter thing in
    outlook express....
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:i8n521$fpv$1@cheetah.cadsoft.de...
    news:i8n337$2ua$1@cheetah.cadsoft.de...
    (Catching up here)
    <deleted:too many arguments>
    The BIG con of html after reading you comments is that the perfect html
    interface is vaporware.
    Who wants to pay for the development and testing?
