EAGLE User Chat (English) Can someone please help me make a custom library componant ?
  • Replies 13 replies
  • Views 1233 views
  • custom
  • device
I am not the greatest at building custom componants in eagle . Can someone please make me this componant i need . I am willing to pay if need be . The componant i need is a Sharp PQ12rd21 voltage regulator . It is a to-220.4 package . I need the whole device made which includes the package ,symbol and finished device . Iv tried a few times with no luck and have read several tutorials on making one .
Here is the datasheet for it with dimensions .
http://pdf1.alldatasheet.com/datasheet-pdf/view/43421/SHARP/PQ12RD21.html
If you can make one package with the mounting hole and another with just the pins that would be great .
Thanks in advance .
    I am sure you can do it yourself! One of the most simple tutorials I have ever seen is: http://www.instructables.com/id/How-to-make-a-custom-library-part-in-Eagle-CAD-too/
    If you still will have trouble with this task PM me and I am sure we can come to terms.
    Yes i am commited to the part . Its one of the best regs iv ever used and have several thousand on hand as well as use them on almost everything .
    Hi Chris,
    Are you sure you want to use that part, its seems a bit old? 1996?
    It also is OBSOLETE according to mouser?
    Are you already "Committed" to using this part?
    What I suggest is just start with a 3 pin regulator( in the library , look
    for "TO-220" , and save that part as your device, then just duplicate one
    of the pins/pads in the package,
    Add an extra pin in the symbol for the on/off switch, then connect it.
    If you are not committed to that part, then look for something more
    "POPULAR" and more than likely you will find a suitable part in the
    library,
    Do you need the ON OFF Switch?
    Remember that you don't need an "exact" matching part number, you will just
    need the correct SYMBOL & FOOTPRINT( package ) to make up your device.
    I also suggest to have a go, cause if you don't learn it now , when are you
    going to?
    Dave M
