EAGLE User Chat (English) Re: WHY theses DRC errors?
  • Views 565 views
On 1/6/2012 3:21 PM, alah wrote:
  Hi, everybody. I drew my schematic and built my board. It LOOKs very fine even on a print but when I run DRC I get CLEARENCE and OVERLAP errors; WHY?
Oops, now another question; Why can´t we attatch eagle files? Thanks, Alberto.
The clearance errors are determined by what is set in the drc settings
clearance tab. Either it set set too small or traces are too close together.
Overlap is exactly that, two nets are touching. This can happen on some
homemade library parts with unconnected copper (custom pad shape, etc
)on the pads. Double click on the errors on the box and it should become
clear what is happening.
    On 1/6/2012 6:01 PM, alah wrote:
    OK Doug; I knew I had three of these errors on just one pad, so I deleted the trace and observed that there was still a dot of red on the pad. So I moved it and it stretched out of the pad and I knew that is because I use a too fine gridand maybe the mouse moves or  whatever. I rerouted and that solved three errors.
    I still have two and I can´t find an explanation; hope You can:
    I have a TO220V  transistor with three pads in line. The middle and right pads were indicating overlap. The left pad has a left route, the middle pad has a down route and the right pad has a down route, parallel to the middle route. I deleted the right route and the right error was gone but not the middle. Even though my route is completed I can see a tiny line of UNrouted on the pad, which I managed to delete. NO errors now so guess that I´m using TOO fine a grid: 0.1mm. What do You think? Thanks.
    I do not think that the problem is the fineness of the grid because an
    overlap indicates that two (or more) nets are contacting whereas if you
    had missed the pad (it should snap) it would merely be an airwire.
    I suspect stray copper.
    I hope I´m responding to Warren. I doubt it´s that large.It´s only 36 x 42 mm; 1 TO220V, 4 -10 diodes, three caps and 4 V Rs.I´ll try again, Thanks.
    alah wrote:
    ............ Why can´t we attatch eagle
    Likely because they are to large. You need to keep them smaller than about
    46k for them to be accepted and make it to all the nodes that access these
    forums. You should zip them if they are to large.
    Also its nice if you state which version they were generated in
    HTH
    Warren
    news.cadsoft.de
    autodeskguest over 14 years ago
