EAGLE User Chat (English) ripup and prefs for autorouter
  • Replies 7 replies
  • Views 840 views
Hi everybody, eagle-6.1 free newbie here.  Eagle newbie, never used it till
now.  Very old hand at electronics, 60+ years working in both design and
repair.
I have designed a 9 part, double sided board, 3 of the parts are
opto-interruptors but I find that the router wants to put connections to it
on the top side of the board.  I am feeding this to pcb2gcode and milling
the board on a small mill running what used to be emc but which we were
forced to rename to LinuxCNC a few weeks back.
My problem is that I cannot plate thru the component holes, so by the time
I run a piece of 30 gage kynar wire thru the hole and solder the top, the
solder prevents the opto device from sitting down on the board so it can be
bolted down.
That means that I need to specify to the auto router somehow, that those 5
terminals on each of the 3 devices need to be wired from the bottom without
exception.  The 3 resistors and 3 diodes can be soldered top and bottom as
they are accessible to my soldering iron from both sides. Small vias aren't
a problem as long as they aren't under these devices.
Perhaps an outline of a verboten area in the Tkeepout layer?  Likely there
are several ways to skin this long lived cat and I'm thinking out loud.
Is there some way, perhaps even in that parts library description, to tell
the autorouter that this part can only be connected to on the bottom,
solder side of the board?  Perhaps by nuking the via outline in layer 1,
leaving only the leads through hole?
Or some similar workaround that would do the same thing by removing the top
layer from the autorouters "I can use this" mapping?
Thanks, Gene
Cheers, Gene
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
    That's probably very true.  This old fart is sort of fond of the printed
    word, probably to my detriment.
    That said, I did manage to edit the library for this opto part and changed
    the shape, size & orientation of its connector pads, updated from the
    library,then fiddled about with ripup and some of the vars in autorouter &
    managed to hit a setting that used the resistor and diode legs for all the
    required thru via's.  This is almost ideal as that will give me a decent
    amount of copper to touch with my iron, which in turn should reduce the
    bridging problems.
    What would really be nice is the ability to trim out a .010" or .012" wide
    gap from just the side of a via that causes a too close error.  These
    things with legs on .050 centers are a PIMA!  But this one should build a
    heck of a lot easier than the first one did.
    Now, when the shop warms up again, I can carve out a slot wheel for this
    encoder with longer slots so I can actually hit the A/B slots with 2 of the
    opto's, and the Z slot about 40 thou outside of the A/B circle and get a
    working encoder once the opto's are bent around a few thou for good
    quadrature of the A/B signals.  If the next wheel fits, the next board s/b
    easy to setup.
    Progress, I think. image
    Thanks Warren.
    Cheers, Gene
    Gene Heskett wrote:
    Chastisement duly noted.  I have a copy of the printed manual,
    courtesy Ed Nisely, who likes the war stories I can tell from a 65
    year lifetime of chasing electrons around.
    However much of the language/options available in the autorouter docs
    starting on about page 188 of that tome, may as well be written in
    swahili as I've been speaking, and trying to write in english for 77
    years, or simply aren't mentioned either at all, and relatively
    little in the way of actual effects on the results. But I may have
    just found most of it.  The problem?  Those items shown in the
    autorouter config screen are all prefaced with a lower case character
    in this manual that I presume is a family marker, but is not shown on
    the screen.  Another foible I just learned. image
    Not a chastisement at all. Simply wished to efficiently point you in the
    right direction.
    As you said you are a newbie and have at hand a printed manual the following
    may be knew knowledge.
    A PDF version of a manual and tutorial can be found in the DOC folder of
    your installation
    Searching the PDF if far more efficient when finding information.
    Raw, straight to the point information,  can be found in the HELP on each
    editor window.
    If you used version4 or earlier previously, it had poor HELP
    The HELP in v5 and v6 is very much better. Once you have 'tuned in' to the
    conventions and foibles of Eagle you can find the answers.
    What is missing is more advanced  case studies that walk you through
    particular methodologies.
    I recommend you get to grips with understanding the interaction of the
    autorouter with net classes and the Design Ruler Checker settings.
    Way back in one of the forums here there was a good explanation on costs in
    the autorouter and optimization. Maybe worth a search.
    Hope this helps
    Warren
    news.cadsoft.de
    Chastisement duly noted.  I have a copy of the printed manual, courtesy Ed
    Nisely, who likes the war stories I can tell from a 65 year lifetime of
    starting on about page 188 of that tome, may as well be written in swahili
    as I've been speaking, and trying to write in english for 77 years, or
    simply aren't mentioned either at all, and relatively little in the way of
    actual effects on the results. But I may have just found most of it.  The
    problem?  Those items shown in the autorouter config screen are all
    prefaced with a lower case character in this manual that I presume is a
    family marker, but is not shown on the screen.  Another foible I just
    learned. image
    I'll get there eventually, or fall over trying. image Diabetics don't have
    much of a warranty image
    Thanks Warren.
    Cheers, Gene
    Gene Heskett wrote:
    Thanks Warren, I figured there had to be a way.
    Next question: Is there also a global ripup everything & I just can't
    find it?  Right now it takes about 15 minutes of one segment at a
    time ripup's to start from scratch if I want to make sure I got them
    all.
    Key into the command line
    RIPUP;
    Note the semicolon at the end.
    It will then confirm  you want to rip up all the routed signals.
    You can just rip up particular signals as well.
    Check HELP/Ripup
    Look under 'Editor Commands'
    All the best.
    Warren
    news.cadsoft.de
    Next question: Is there also a global ripup everything&  I just can't find
    it?  Right now it takes about 15 minutes of one segment at a time ripup's
    to start from scratch if I want to make sure I got them all.
    Thanks again, I will do that when I'm next awake.  Its about signoff time
    for tonight.
    Group the whole board then ripup should do it. I you rip up the air wire
    after the segment is ripped up it will delete more or all of the
    remaining segments of that net.
    Since you are just starting spend some time in the on line help and find
    a tutorial. If you know the proper search terms almost ever question you
    will have has been answered several times except for new changes in
    version 6.
    Paul R.
    Next question: Is there also a global ripup everything & I just can't find
    for tonight.
    Cheers, Gene
    it till now.  Very old hand at electronics, 60+ years working in both
    design and repair.
    to it on the top side of the board.  I am feeding this to pcb2gcode
    and milling the board on a small mill running what used to be emc but
    which we were forced to rename to LinuxCNC a few weeks back.
    time I run a piece of 30 gage kynar wire thru the hole and solder the
    top, the solder prevents the opto device from sitting down on the
    board so it can be bolted down.
    those 5 terminals on each of the 3 devices need to be wired from the
    bottom without exception.  The 3 resistors and 3 diodes can be
    soldered top and bottom as they are accessible to my soldering iron
    from both sides. Small vias aren't a problem as long as they aren't
    there are several ways to skin this long lived cat and I'm thinking
    out loud.
    tell the autorouter that this part can only be connected to on the
    bottom, solder side of the board?  Perhaps by nuking the via outline
    in layer 1, leaving only the leads through hole?
    the top layer from the autorouters "I can use this" mapping?
    Thanks, Gene
    Cheers, Gene
    Hi Gene
    You could place a rectangle on the tRestrict layer over your
    opto-interruptors. The autorouter will then not use that area to connect to
    the TPH pads.on the top layer and so be forced to the bottom layer.
    vRestrict is used in a similar fashion to prevent vias in an area.
    Additionally  bRestrict is for areas on the bottom of the board.
    You can add these restricted areas to your library parts if you want this on
    all future boards
    Warren
    news.cadsoft.de
