EAGLE User Chat (English) Script / easy way to delete this pesky OC_NEWARK, OC_FARNELL, MF, MPN... attributes in default libs?
  • Views 1202 views
is there any simple way of removing these pesky default attributes from
the stock libraries that got introduced most likely for this Farnell
shop integration stuff ?
They mess up my BOM with my user defined attributes and for unknown
reasons one cannot delete them from the instance on the schematic and
board (why? I don't see the point?) but has to delete them from each
single part in each affected library...
Markus
    autodeskguest over 13 years ago in reply to autodeskguest
    On 18.06.2013 17:28, Eric Stevens wrote:
    This works in Linux, and OSX I'd assume. For windows you'll need Cygwin or MSYS to use it.
    Just tested with the GIT BASH command line from the windows msys git I
    use for version control. Seems to work like a charm. image
    Thanks a lot!
    Markus
    #!/bin/bash
    BAKDIR=lbr_bak
    if [ ! -e "$BAKDIR" ]; then
       mkdir -v $BAKDIR
    fi
    OLDIFS=$IFS
    IFS=$(echo -en "\n\b")
    lbr_files=( $(ls *.lbr) )
    for file in "${lbr_files[@]}"; do
         echo -e "Processing $ ..."
         cp -p "$file" "$BAKDIR/$file"
         sed -r 's^<attr.(MF|MPN|OC_FARNELL|OC_NEWARK)./>~g' "$BAKDIR/$file" > "$file"
    done
    IFS=$OLDIFS
    I have a look into that. Seems a good solution.
    Markus
    On 06/18/2013 07:37 AM, Markus Rudolf wrote:
    Markus
    #!/bin/bash
    BAKDIR=lbr_bak
      mkdir -v $BAKDIR
    fi
    OLDIFS=$IFS
    done
    IFS=$OLDIFS
    My suggestion: Consider Cadsoft libs as starting point, check and
    modify the parts you want to use before transferring it to your own
    lib.
    Otherwise you can get rid of the attributes by simply removing them,
    any search and replace tool should do the job. The V6 libs are text
    (XML).
    Oliver
    Oliver Betz, Munich
    despammed.com is broken, use Reply-To:
    autodeskguest over 13 years ago in reply to dukepro
    On 18.06.2013 14:03, Chuck Huber wrote:
    Markus,
    The easiest way I can think of right off hand is to modify your bom.ulp
    and filter these attributes out.
         - Chuck
    Yeah but I guess this will be curing the symptoms, not eliminating the
    root cause.
    Markus
  • dukepro
    dukepro over 13 years ago
    Markus,
        - Chuck
    from the stock libraries that got introduced most likely for this
    Farnell shop integration stuff ?
    Markus
