EAGLE User Chat (English) "electrical" symbol libraries?
  • Subscribers 184 subscribers
  • Views 3710 views
Is anyone aware of any libraries of JIC (or similar) symbols for doing
electrical drawings like contactors, motors, circuit breakers, panel
switches, transformers and the like? I realize that Eagle is a PCB package
and that these things are not really PCB elements, but I can't be the only
one who also uses Eagle for drawing general schematics of things that will
not be made into PCB's.
I more often than not find that my PC layout is only part of the overall
system I an working on, and being able to do the entire schematic, including
panel and cabinet wiring in the same format is most convienent.
I looked in the downloads section, but did not see anything like that,
perhaps I overlooked something. I am using v4.08.
Thanks for any suggestions.
-Al
    -Al
    For cabinet wiring etc. eagle is imho the wrong program. For this kind
    of work look for pro/e, wscad or ecad ie.
    Eagle is to design pcb´s. That means (for me) that connections to the
    "more heavy" equippment end on the pcb in terminals or solder pads.
    Gruß
    Jörn
    Former Member over 17 years ago
    Joern,
      Thank you for taking the time to reply. You are correct, of course, it
    is not really the proper tool for the job. It is just the case that we
    use this only for in-house documentation, and it is easy and convenient
    to have all of the schematics in one format. Since we already have a
    number of full license seats of Eagle, and we are familiar with it, that
    is what we have used, with some "tweaking." It happens that lately we
    are doing somewhat larger stuff and more of it.  We may have outgrown
    this method, I guess.
    Thanks again for the reply.
    Al
    -Al
    Hello Al,
    There is an elektro.zip at
    http://www.cadsoft.de/cgi-bin/download.pl?page=/home/cadsoft/html_public/download.htm.en&dir=eagle/userfiles/libraries
    The tutorial can be found at the eagles doc folder named
    elektro-tutorial.pdf. This is available only in deutsch.
    - Asko
    Joern,
    Al
    I see what you mean. In my earlier days I erected powerplants and
    substations and afaik eagle is quite far away from "knowing" (lbr´s)all
    that stuff like protection equippment etc.
    This would mean you have to start creating libs with that kind of devices.
    The new eagle V5 contains some elektro libs but is far away from what
    one needs. But you could download the free version and "sniff" through
    those libs to get some suggestions.
    I just see that Asko Rupponen has a god suggestion. Maybe that helps.
    Gruß
    Jörn
    Thank you for the suggestion. I'll download that and take a look. My
    skills reading Deutsch are about nil, but maybe I can get something from
    it. One of my sons took a few courses in German a while back. Perhaps
    this is a chance to see how much he learned!
      Thanks for taking the time to reply.
    -Al
    Asko Rupponen wrote:
    Hello Al,
    - Asko
    Thanks again, Joern. We are doing nothing near the size of power plants
    and the like. I will take a look. As I said, we may have outgrown that
    method, it may be time to find some new tools.
    Al
