EAGLE User Chat (English) Is it worth persevering?
  • Replies 10 replies
  • Subscribers 178 subscribers
  • Views 671 views
I'm tearing my hair out trying to get to grips with Eagle. I'm not sure if
it's me, but I find almost everything about it counter-intuitive.
I plan to make a couple of boards each year, for my own use. I'd happily pay
a reasonable sum for a more intuitive package, but I like the fact that
Eagle files are widely used.
Is it worth persevering, or is there something out there that is reasonably
priced, and will read Eagle files?
Nigel M
I'm discussing apples, so don't suggest bananas
    From reading your posts, it appears to me that you try to use such a
    complex and specialized software package without even having had a look
    at the manual and/or tutorial.
    That way, I fear you will find all CAD packages to be non-intuitive.
    From my experience, EAGLE is the (by far) most efficient and
    user-friendly PCB layout CAD at least in the "affordable" price range.
    There are packages which are much more expensive but a pain to work
    with... However, you have to learn (and understand) how it works, and
    how it's operated.
    Take the time to (literally!) work through the tutorial, also have a
    look at the manual and the available help (older posts in these
    newsgroups, beginner's tutotials in the web, FAQ at the CadSoft
    website). Use the HELP function extensively. Dig into the UI and the
    conecpts of EAGLE and do some test layouts (just for learning) before
    you start real work.
    Tilmann
    look at the manual
    I have printed the tutorial and the manual, and have read both from cover to
    cover, twice. Neither make sense to me.
    I have attempted to work through the tutorial, although the discrepancies
    and poor choice of conventions make this more difficult than it should be.
    I should point out that I have taught computer studies at university level.
    cover, twice.
    Good
    Let it rest for a while take it easy, try things, and you might get it.
    Yes different programs are different "cultures" to learn
    I failed my math course but i understand Eagle and a few other things... image
    "Nigel Molesworth" <reply@thegroup.email.invalid> wrote in message
    news:3065i45rmqefn0mg0m1jc3dt14uqsbmke5@4ax.com...
    pay
    reasonably
    Nigel M
    Hi, Nigel
    Bottom line is I'd certainly say "Yes, Eagle is the very best tool for
    making PCB's that you currently can find at an affordable price." Hands
    down, it's a fact.
    That said, Eagle does present its own and unique high learning curve. But so
    does any complex computer program. For example, MS Office is composed of
    many interacting modules (Word, Access Power Point, etc.) and each of them
    are themselves very complex and user modifiable. To really be proficient
    with all the offered abilities of MS Office, or Eagle for that matter, takes
    a large commitment in time and willingness to learn how to do all the things
    a program is capable of. Until true AI comes along, there is no such thing
    as "just use it". Because learning is confusing, there are classes to take
    for learning how to use complex programs. Eagle is no exception, I think it
    was in the Eagle userchat group that I just saw a recently posted message
    where a class is being held in Canada by an Eagle dealer. But my experiences
    with taking classes, such as for dBase, left me with much desired because
    classes don't offer much individual training. I found that learning what I
    need to know about any complex computer program was best performed by just
    jumping in and learning how to get the results expected and, when necessary,
    asking specific questions in forums, such as this one that this message is
    posted to.
    I'm from the pre Windows 3.1 days so the way Eagle goes about doing things
    seems pretty obvious to me to be the way old programs were written before
    Windows redefined certain functionalities. To me, it seems that the
    underlying "engine" of Eagle is very old (but still very good at what it
    does) and predates Windows itself and that's seems to be why things seem
    counter intuitive when it comes to performing certain actions. For example,
    the purpose of "copy" as used in Eagle is not the same as what it means when
    using the same named function in Windows. But before Windows came along, how
    Eagle does it now was exactly how it was done with most programs back in
    those days. Since I date from back then the knowledge helped me, but I do
    understand that a new user of Eagle will find the methodologies of just
    using the program counter intuitive to the way it is done with programs that
    are designed from the ground up to use Windows methods of doing things.
    Then, of course, one must learn about the PCB industry itself because Eagle
    is a tool that allows one to create files that industry needs to physically
    create what is designed by using Eagle (or any other PCB related tool). The
    old saying "garbage in, garbage out" applies because Eagle only does, with
    user modifiable rules, exactly what you tell it to do. The physical PCB
    industry has practical constraints on things such as the minimum width of
    traces, pads, distance between pads and traces and board edges, and so on &
    on, and not every board production house does things the same way. FT (feed
    though) parts are old technology and perhaps the very easiest to design for
    using Eagle. But SMD (surface mount device) is a different animal, you have
    to understand what paste (aka cream) and "stop" and other terms, many of
    which have "aka" terms too, mean to the industry. Eagle allows you to define
    such things, but you have to know what they mean and so you have to take the
    time to learn. If you're designing with RF (radio frequency) in mind, more
    industry rules apply!
    There's an even older saying: All good things come in time. That's what it's
    going to take for the new PCB designer regardless of what program is used to
    design with. Eagle is worth the effort, and it is cost effective.
    And I'm saying all of the above as a relatively new user of any PCB deign
    software whatsoever.
    sure if
    happily pay
    reasonably
    Nigel M
    Hi, Nigel
    down, it's a fact.
    But so does any complex computer program. For example, MS Office is
    composed of many interacting modules (Word, Access Power Point, etc.)
    and each of them are themselves very complex and user modifiable. To
    really be proficient with all the offered abilities of MS Office, or
    Eagle for that matter, takes a large commitment in time and willingness
    to learn how to do all the things a program is capable of. Until true AI
    comes along, there is no such thing as "just use it". Because learning
    is confusing, there are classes to take for learning how to use complex
    programs. Eagle is no exception, I think it was in the Eagle userchat
    group that I just saw a recently posted message where a class is being
    held in Canada by an Eagle dealer. But my experiences with taking
    classes, such as for dBase, left me with much desired because classes
    don't offer much individual training. I found that learning what I need
    necessary, asking specific questions in forums, such as this one that
    this message is posted to.
    things seems pretty obvious to me to be the way old programs were
    written before Windows redefined certain functionalities. To me, it
    seems that the underlying "engine" of Eagle is very old (but still very
    good at what it does) and predates Windows itself and that's seems to be
    why things seem counter intuitive when it comes to performing certain
    actions. For example, the purpose of "copy" as used in Eagle is not the
    same as what it means when using the same named function in Windows. But
    before Windows came along, how Eagle does it now was exactly how it was
    done with most programs back in those days. Since I date from back then
    the knowledge helped me, but I do understand that a new user of Eagle
    will find the methodologies of just using the program counter intuitive
    to the way it is done with programs that are designed from the ground up
    Eagle is a tool that allows one to create files that industry needs to
    physically create what is designed by using Eagle (or any other PCB
    related tool). The old saying "garbage in, garbage out" applies because
    Eagle only does, with user modifiable rules, exactly what you tell it to
    do. The physical PCB industry has practical constraints on things such
    as the minimum width of traces, pads, distance between pads and traces
    and board edges, and so on & on, and not every board production house
    does things the same way. FT (feed though) parts are old technology and
    perhaps the very easiest to design for using Eagle. But SMD (surface
    mount device) is a different animal, you have to understand what paste
    (aka cream) and "stop" and other terms, many of which have "aka" terms
    too, mean to the industry. Eagle allows you to define such things, but
    you have to know what they mean and so you have to take the time to
    it's going to take for the new PCB designer regardless of what program
    is used to design with. Eagle is worth the effort, and it is cost
    effective.
    deign software whatsoever.
    have a look at the tutorials here. http://www.tangentsoft.net/elec/movies/
    Thank you. I found these yesterday, but it's good to get an endorsement.
    I think I understand a bit more now, and it seems the weirdness comes from
    its Linux roots. This said, it really needs an update to current practice.
    Perhaps if I turn off the sound it would be less annoying!
    I like to be able to choose from very different products.
    That applies to all business segments, and life image
    If some way of diong things hing does not suit you, try another
    practice.  That would be hard if all products were alike.  People are
    different.
    I also found a bunch of nice Eagle tutorials here:
    http://www.instructables.com/id/Draw-Electronic-Schematics-with-CadSoft-EAGLE/
  • RICHARDBOWN
    RICHARDBOWN over 17 years ago in reply to autodeskguest
    Hi
    Nigel it took me about a week to get to grips with Eagle, OK I may have
    an advantage that I come from that "weird " software background linux.
    You have to remember Eagles roots and think tutonically, when you do
    this you will find it much easier to understand.
    I suspect due to your educational background you are trying proceed by
    jumping stages. If you work through it step by step in a purely logical
    way you will find it alll  will make sense..
    I hope that makes sense,  no way am I knocking the Germans or their products
    BR
    Richard
    On Fri, 21 Nov 2008 08:45:46 +0000, "Richard.Bown"
    It all makes sense now, see this post:
    Message-ID: <k6ufi45ah6jgmh2u16np9nj3nbd1fl8bon@4ax.com>
