EAGLE User Chat (English) Polygon Dimension spacing
  • Subscribers 187 subscribers
  • Views 2216 views
'Nother n00b question!
How do you increase the distance a polygon gets 'ratsnested' from the
dimension.  Even if the isolate is set to 10 mil, it separates itself
much more than that from the outside of the board.
Like this: http://etharooni.polorix.net/dimensionpolygonthing.png
Thanks.
    Thanks.
    Take a look at the Design Rules' Distance tab, Copper/Dimansion value.
    Thanks!  That's what I was looking for!
  • Richard_H
    Richard_H over 17 years ago
    Thanks.
    Richard Hammerl
    Thanks.
    Your polygon is too far inside the dimension, so there is actually no
    distance. Just place it outside the dimension, then eagle can calculate
    the distance.Don't mix things up. Distance is between copper and
    dimension, isolate is between conducting parts.
    Here's a better example:
    http://etharooni.polorix.net/polygondistance2.png
    Thanks.
    No.  I don't think so... The polygon was way outside the dimension
    layer.  Only when it's ratsnested did it get very far away from the
    dimension layer.  It's just annoying having to increase the size of the
    board so that the polygon can merge together behind a pad or something.
    What do you mean "Distance is between copper and dimension?"  I think I
    may be missing something vital.
    Thanks, though.
    Thanks.
    Gruß / regards
    Jörn
