EAGLE User Chat (English) Copying symbols
  • Subscribers 177 subscribers
  • Views 453 views
Copying symbols
Dear Eagle user group
I tried to find some information on this but couldn't, so please excuse me
if this has been answered before.
I'd like to copy / paste a symbol (under a new name) in my own 'special
devices' library in order to modify it. However, I can't find any way of
making such a copy - is this possible?
Thanks!
Richard
    On Thu, 9 Apr 2009 17:47:48 +0100, "Richard Hince"
    There may be an easy way, but I only know of a convoluted way.  Make a
    brand new library (Temp.lbr, for example).  Drag a device containing
    the symbol you want to the new library.  Edit the new library and
    rename the Device and the Symbol.  Delete all the packages from that
    device.  Now you have a Device that has a Symbol and no packages.  Now
    edit your Special Devices library and drag the (renamed) device to
    your library.  Once you get it there, delete the device.  Now you have
    a renamed Symbol, ready for you to modify it.  It was important that
    you renamed the device too so that it would not over-write the device
    with the same name in your good library.  Now you can delete Temp.lbr.
    Robert Scott
    Real-Time Specialties
    Ypsilanti, Michigan
    Richard Hince wrote on Thu, 09 April 2009 12:47
    me
    Hi Richard, yes there is a way to do this.
    Go to source library
    Open source symbol
    turn on all layers
    group everything
    choose cut command and apply to group
    open destination library
    create or open destination symbol
    choose paste
    left click to place
    Note:  the point where your right click to cut will be the origin when the
    pasting happens, so choose wisely.
    Cheers,
    James.
    email:  sales2009@eaglecentral.ca
    fax:    888.701.8097
    web:    http://www.eaglecentral.ca
    Online EAGLE Dealer for US and Canada
    EAGLE Design Experts
    EAGLE Enterprise Toolkit
    Thank you James and Robert - both suggestions work fine. Shame there isn't a
    'copy symbol' (and package for that matter) but maybe there's a good reason
    why not.
    "James Morrison" <james@eaglecentral.ca> wrote in message
    news:grlm8k$8f0$1@cheetah.cadsoft.de...
    me
    Open source symbol
    turn on all layers
    group everything
    choose paste
    left click to place
    Cheers,
    James.
    fax:    888.701.8097
    Thanks!
    Richard
    Whatever you do, do it in your own libraries!
    Open a library or create new and KEEP OPEN.
    In control panel / libraries pick a device with the wanted symbol.
    Right klick it, choose 'copy to library' in the opening dialog.
    Save the new lib and close it. That's all.
    If you really want the symbol only, the fastest way to get rid of the
    other 'garbage' is to export the new library as a .scr, open it with a
    text editor, scratch the unwanted things and import the new file.scr
    into a new lbr.
    Gruß / regards
    Jörn
