EAGLE User Chat (English) Layers in Standard (Hobbyist) Edition
  • Replies 10 replies
  • Views 1421 views
  • 4_layer
  • layers
garylaoffice
garylaoffice over 11 years ago
I cannot manage to enable or select Route2, Route3, Route14 or Route15. My "About" shows I have the Standard Edition. It is my understanding that this version allows 6 signal layers, yet I can access only Top and Bottom.
Anyone know how I can enable the four inner layers?
  • garylaoffice
    garylaoffice over 11 years ago in reply to autodeskguest
    I fixed it myself by digging into the XML file.
    The group function and cut-to-clipboard need to be streamlined.
    Often clicking on objects with the anticipation that the currently-selected part will be affected by the currently-selected operation often yields no action. For example: move. Clicking on an object and dragging usually fixes the object to the mouse and the move is performed. But very often it only highlights the object.
    The library manager needs to be completely rewritten. It's a disaster.
    I will agree that most CAD/PCB programs are grossly over-priced. However, when I use the library manager in Eagle, I desperately wish I was using my over-priced tools.
    autodeskguest over 11 years ago in reply to garylaoffice
    Gary La prodded the keyboard
    Here's a perfect example. Suddenly, the product crashes. Then when I
    try to reload it and open the same schematic, it displays:
    "Loading C:/School/Projects/PCB/eagle/anadig.sch ...
    Warning(s):
    line 11443: invalid value '' for attribute 'name' in tag <net>
    Error:
    line 11452, column 6: invalid/missing attribute 'name' in tag <net>"
    It has no mechanism to get past this. So that's the end of that
    schematic, I guess. Very unprofessional. No excuse for this type of
    behavior. A pro would've fixed the file with a placeholder or
    temporary tag so that the work could be recovered. Or at the very
    least, prompted the user to enter a value. Or opened the schematic
    but deleted the part associated with the fault. Or about 10 other
    things. But not this product -- end of schematic.
    http://www.element14.com/community/message/134934
    What a plonker !
    Best Regards:
                           Baron.
    Am 16.12.2014 um 09:49 schrieb Rob Pearce:
    behavior. A pro would've fixed the file with a placeholder or temporary
    tag so that the work could be recovered. Or at the very least, prompted
    the user to enter a value. Or opened the schematic but deleted the part
    associated with the fault. Or about 10 other things. But not this
    Your faith in this mystical "pro" astonishes me. I've used Microsoft
    tools! And Orcad, and Matlab/Simulink, and all those other very
    expensive professional tools. None of them do any better at this than
    Eagle - most worse.
    You can accuse me of temper tantrums all you like - without the
    slightest justification, since you were the first to throw one - but it
    makes no difference to the fact that the holy grail you seem to expect
    from over-priced software does not exist in the real world. In my many
    years of using computer software the one thing I have absolutely found
    is that
         You DON'T get what you pay for
    You want a program that allows a recovery mechanism for a corrupted file
    (which clearly is what you had)? Use one with a plain text format
    (Eagle's is now XML, which isn't perfect but...) and/or open source.
    Yes, that's right, the most likely programs to survive bad files are the
    FREE ones!
    Bob, Morten and others imho you should stop the discussion.
    You are just feeding a troll.
    Joern Paschedag
    Eagle - most worse.
    is that
    FREE ones!
    "Gary La"  skrev i nyhetsmeldingen:
    623453155.21418692381419.JavaMail.jive@flmspu-csapp-02.premierfarnell.com
    Here's a perfect example. Suddenly, the product crashes. Then when I try
    OK, you want to keep this professional, so let's not rant about a user
    interface that you dont care to spend time learning. You will upset a lot of
    the old stayers by claiming Eagle is crap.
    Believe me, Eagle is very powerful for its use and a lot of value for the
    money. Besides, the support you get (for free!) is beyond comparison. Eagle
    is not perfect but you will love it if you care to learn it. You will get a
    kickstart if you learn its history since the command line days. It has kept
    its command line backbone, but added GUI ways to execute the commands. It's
    not a fully windows-accent gui environment, but rather multi platform, as
    Eagle runs on both Linux, Mac and Windows.
    The error you quote is obviously a bug or some corrupted project. I'm sure
    it can be fixed, and Im even sure someone at Cadsoft will offer you to
    repair it, and it surely won't cost you a yearly service agreement fee. A
    volunteer on this forum community may even offer to fix it for you if your
    approach is a bit friendlier.
  • garylaoffice
    garylaoffice over 11 years ago in reply to garylaoffice
    Here's a perfect example. Suddenly, the product crashes. Then when I try to reload it and open the same schematic, it displays:
    Warning(s):
    Error:
    It has no mechanism to get past this. So that's the end of that schematic, I guess. Very unprofessional. No excuse for this type of behavior. A pro would've fixed the file with a placeholder or temporary tag so that the work could be recovered. Or at the very least, prompted the user to enter a value. Or opened the schematic but deleted the part associated with the fault. Or about 10 other things. But not this product -- end of schematic.
  • garylaoffice
    Your temper-tantrum only proves my point. Written by non-pros as I suspected.
    Luckily, I only got this to help some local kids build their school project and I don't actually need to rely on this.
    On 15/12/14 21:36, Gary La wrote:
    Frankly, this is among the very worst PCB programs I've ever worked with
    over the past 20 years. Absolutely horrible.
    If you really feel that, then you're at liberty to bugger off to your
    preferred one.
    Obviously, instead of re-writing between versions they must cut and
    paste from prior versions.
    Only idiots reinvent the wheel every time.
    Either that or they can't be bothered with
    studying the prior art. This results in a non-intuitive, disjointed,
    inconsistent interface.
    No, it results in a consistent, flexible, intuitive and powerful
    interface for those who can be bothered to learn it. The so-called
    "prior art" is mostly unusably crap and every time Cadsoft bend to the
    irrational clamour of unreasonable people demanding "more Windows-like"
    the result is a mistake. Fortunately, Cadsoft usually allow users to
    revert to the better, original version.
    The "help" is a complete waste of time. It states the obvious but with
    as few lines as possible.
    The help in Eagle is a million times better than the help in most
    applications. It's one of the best I've ever encountered. Largely
    because, unlike ALL the rest, it doesn't just state the bleeding obvious.
    I am looking forward to moving some new customers off this disaster and
    onto my real PCB design program. It costs a lot more, but it's well
    worth it compared to this unbelievably bad program.
    Woah... hang on...
       onto MY real PCB design program
    So you're actually a vendor of an over-priced competitor tool? Spreading
    offensive FUD in a misguided malicious smear campaign as part of your
    marketing policy? Is that what you're telling us?
    If so, you can definitely "£$" off!
  • garylaoffice
    Thank you. I finally figured that out.
    Frankly, this is among the very worst PCB programs I've ever worked with over the past 20 years. Absolutely horrible.
    Obviously, instead of re-writing between versions they must cut and paste from prior versions. Either that or they can't be bothered with studying the prior art. This results in a non-intuitive, disjointed, inconsistent interface.
    The "help" is a complete waste of time. It states the obvious but with as few lines as possible.
    I am looking forward to moving some new customers off this disaster and onto my real PCB design program. It costs a lot more, but it's well worth it compared to this unbelievably bad program.
    Bottom.
    Hi Gary,
    I hope you're doing well. To enable the extra layers, go into the DRC>
    Layers Tab and then adjust the setup equation for the additional layers.
    Simplest example for six layers would be:
    (1231415*16)
    hth,
    Jorge Garcia
