EAGLE User Chat (English) List of common bummers
  • Views 700 views
Just made a major bummer on a prototype, and I thought first, why do I (and
others) do these errors over and over again.. So maybe its time to collect a
list of common bummers. There should be a checklist for common errors, maybe
even included in the DRC box as plain text! (Hey, Ill post that on suggest!)
Here is my recent ones:
1. PCB board thickness when using edge connector. In the heat of picking a
stackup for a 10 layer board, the stackup suggestion from the manufacturer
chose their own thickness (tiny number in a tiny box). Neither we, or any of
the other 3 partners involved in the PCB production ever thought that since
there is an edge connector, the thickness is critical.
2. Part verification. There should be a flag on all components called
"verified", that is set to NO on never manufactured parts. Maybe even a text
field for a "verified" attribute. I know very well that is a common problem.
Either pitch is wrong, pads are wrong size, pin numbering is
mirrored/interleaved or wrong somehow. Recently, I managed to mess up the
pinout of a CF socket. Pin numbering should be interleaved, but I managed to
do them sequential. I also managed to mirror the 4 wire pairs on a ethernet
connector.
Please submit your own bummers (and don't be ashamed, we all do them)
    autodeskguest over 16 years ago in reply to autodeskguest
    Robert Pearce wrote:
    On Thu, 6 May 2010, Gary Gofstein wrote to us saying :
    Wrong hole size for hi power thru hole component leads.
    Using an SOIC18 package for an SOIC18W part
    Although the second time I did this it was because I managed to order
    the wrong parts...
    It could have been worse, here's Henry Ford's bummer:
    http://www.hfmgv.org/exhibits/showroom/1896/receipt.html
    Quote "Ironically, in his enthusiasm Ford neglected to notice that the
    vehicle was too wide for the doors to his Bagley Avenue shop, ..."
    Regards, Joerg
    the wrong parts...
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
    "Morten Leikvoll" <mleikvol@yahoo.nospam> wrote in message
    news:hrtsti$7vf$1@cheetah.cadsoft.de...
    (and others) do these errors over and over again.. So maybe its time to
    collect a list of common bummers. There should be a checklist for common
    errors, maybe even included in the DRC box as plain text! (Hey, Ill post
    that on suggest!)
    of the other 3 partners involved in the PCB production ever thought that
    since there is an edge connector, the thickness is critical.
    text field for a "verified" attribute. I know very well that is a common
    problem. Either pitch is wrong, pads are wrong size, pin numbering is
    to do them sequential. I also managed to mirror the 4 wire pairs on a
    ethernet connector.
    what about an interface in the DRC-check to an user-defineable ULP?
    With this feature, a user would be able to extend the DRC check with
    functionality at his/hers
    own discretion.
    Carsten
    connector.
    Proportional Text in board layers.
    connector.
    Mine was during my first year as an engineer, large super-dense SMT
    boards which was quite a feat in the late 80's. I am not a fan of source
    termination for various reasons, so my board didn't have any. System
    came together, weird reflections on an internal multi-channel RF bus.
    "Why are there no terminators on your board?" ... "I thought you had
    them on yours" ... "No, I was under the assumption they were on yours"
    ... our boss almost exploded.
    Luckily we managed the situation by changing the LC filter values. Whew.
    Regards, Joerg
    "gmail" domain blocked because of excessive spam.
    Use another domain or send PM.
    connector.
    Good ideas Morten.  I like the idea of Verfied check box.  One thing I
    do now if have a verified and unverified library.  I make a part in
    unverified and then copy it to verified once it is produced.  However
    this process is troublesome and time consuming.  Some other way to mark
    a part would be nice.  One method is in the part description.
    Another check that could be added to the list:  Silkscreen overlapping
    with holes or vias.  Some design are complex and I will miss an overlap
    which will ruin the silkscreen.  Maybe there is a way to check for
    collisions already, but I haven't look into it.  If there isn't a way,
    perhaps a way can be created.
    In the CAM system one can build there own jobs and the who, what, where,
    when, and how of a design output.  I like this.  Perhaps some sort of
    similar system can be built in DRC so that one can set workflows and
    levels through the work flows.  For instance, when I am routing a board
    I want to know clearances, but I don't care about text or overlaps just
    yet.  It would be nice to run a "partial" DRC on just the portion that I
    care about.  As the design nears completion I care about the finer details.
