EAGLE User Chat (English) Anyone else having errors with version 6?
  • Subscribers 187 subscribers
  • Views 467 views
autodeskguest over 14 years ago
There are a few obvious bugs in version 6:
Schematic editor loading with a grid of 0.1", no matter how many times you tell it you want 0.05".
Parts not dropping where you let them go, i.e. jumping a grid place over.
Random connecting / not connecting when you drop a part on the end of a net.
But the biggest is the random changing of other nets that are not intended to be changed. If I have one page of nets called "DIGIN_0" through to "DIGIN_15", and I copy this to another page and rename the nets to "DIGIN_16" through to "DIGIN_31", then all looks good. I like the feature of "Just change this segment" - it's simple and useful.
When you re-open Eagle though, the two schematic pages have the same net names, i.e. both pages have nets "DIGIN_16" through "DIGIN_31".
The PCB however has the correct netlist information, so Eagle reports an error.
Specifically:
Error:
line 7777, column 9: redefinition of name 'DIGIN_16' in tag
This has happened three times now, each time I have lost a day and a half's work by re-entering data. Recovering saved backups only delays the problem until you re-open Eagle to be welcomed with the same message.
Having paid over £1200 for a three-seat license, I feel a little annoyed.
Can I go back to Version 5 with my new license?
    Just a small note regarding 'jumping' parts.
    It seems to be related to where the part is picked up from, relative to the origin.
    i.e. If, when you copy a resistor your mouse isn't within one grid of the origin cross, then when you place the resistor it jumps by that offset.
    Thanks for the tips guys, there is a green dot but I just double-click on the board filename and then confirm I'd like to open the schematic too. I've always done this so I didn't realise there would be a difference with version 6.
    I'll edit the startup script too - thanks - most of the parts in the supplied libraries are 0.05" pitch (and indeed if you press the 'default' button on the grid setup that's what you get).
    Robert describes the jumping of schematic parts far more precisely than I could - that is exactly what happens.
    I'll send files once the PCB has been sent for manufacture, I do have copies but I'm a bit nervous about opening corrupt files with similar filenames to a live project.
    Thanks again for your help.
    PS I have just moved a library that my project referenced (intending to update to the new path in Eagle once open) and when I started Eagle I got the windows message "Eagle.exe has stopped working...." Again, I'll send files to support.
    On Mon, 05 Mar 2012 17:49:17 -0500, Jorge Garcia
    Specifically:
    Error:
    line 7777, column 9: redefinition of name 'DIGIN_16' in tag<signal>
    Hi Mike,
    You should setup you're default grid in the eagle.scr, this script is
    run every time you run any of EAGLE's editors. It's an excellent way to
    setup defaults. That said I would not deviate too much from 0.1" since
    all of EAGLE's default libraries are made to that grid and you might
    have trouble connecting to components.
    The other problem you're experiencing is more interesting. Please send
    test files as well as a procedure to recreate the issue to
    support@cadsoftusa.com for analysis, that way the developers can get on
    to fixing it if it turns out to be a legitimate bug.
    hth,
    Jorge Garcia
    Cadsoft Support
    I would like to confirm Mike Evans report about version 6.  I also see
    random jumping of parts that are being placed, especially after being
    copied from somewhere else with the copy tool.  I cannot send any test
    files because the bug is not repeatable.  It just happens about 1 out
    of 20 times I copy a part.  It also happens when I place an object
    from a library.  I don't believe I have seen the problem when moving a
    part.  The "jump" is usually one grid point away from where I let up
    on the mouse button.  It is not just me jerking the mouse as I let up
    on the button.  My workaround is just to be very observant and correct
    these jumps with an adjustment move after it happens.  There is no
    special kind of part that needs to be involved.  I have seen it happen
    with simple resistors.  This happens only is the schematic editor, not
    the board editor.  And I am normally placing a part so that some pin
    of the part attaches to a net.  The jump, when it occurs, normally
    results in the part not making the desire connection.  I don't know if
    random placements suffer the jump probem when no connection is
    possible.  It could be because I have never seen the jump except when
    I am trying to make a connection.
    As for using a grid other than 0.1", I normally using a grid of 0.025"
    all the time.  And it starts up that way for me.  It could be that
    Mike is not "opening" the project, just opening the board.  Mike, do
    you see a green dot next to the project name when you open it?
    Robert Scott
    Ypsilanti, Michigan
    Specifically:
    Error:
    Hi Mike,
    hth,
    Jorge Garcia
    Cadsoft Support
