EAGLE User Chat (English) How connect grab point of a component to the GND
  • Replies 10 replies
  • Subscribers 187 subscribers
  • Views 2573 views
  • eagle
  • connect
  • gnd
salomonreinach
salomonreinach over 7 years ago
Hi all,
I can't find how I can connect the grab point of a component (for example an micro USB port) to the GND. Does anyone know how I could do that ?
I'm using eagle 8.3.2.
Thank you for your time image
  • geralds
    0 geralds over 7 years ago in reply to salomonreinach
    Yes, I thought this as well.
    Thanks for the clarification.
    Best Regards
    Gerald
  • salomonreinach
    0 salomonreinach over 7 years ago in reply to geralds
    Yes I didn't know the correct word for this, but I meant the point to attach the component on the board.
  • geralds
    0 geralds over 7 years ago in reply to autodeskguest
    Firstly I also thought this. But here it seems there is not a translation issue.
    Grab point - "Haltepunkt" (German, the translator translates this word correctly) does exist, as the margin,
    respective the center point of the device for picking up this device.
    And so if I understand him right, he means this center point.
    Shielding - "Abschirmung" (German), the translator translates this word correctly as well.
    Hopefully I understood it well.
    Best Regards
    Gerald
    0 autodeskguest over 7 years ago
    On 21.01.2019 09:51, Rémy Silinski wrote:
    Hi all,
    Im wondering if there is a translation issue here.. "Grab point" could
    be the shield, the electrical point of the connector that gets touched,
    or connects first.
    I prefer routing shield separately from ground both to avoid spikes and
    ESD from the environment to go through my electronics, but this is a
    topic on its own. The solution depends on how the apparatus gets
    connected to the world.. or not.
    Hi all,
    or connects first.
  • geralds
    You're welcome, my pleasure.
    If your question has been answered well, I would be happy if you sign my comment as "answered".
    Best Regards
    Gerald
  • salomonreinach
    Thank you for this explanation ! image
  • geralds
    Yes, that's was I said. Just a pad or via can be connected to a power or signal.
    A virtual point is impossibel. It is virtual, not real; it's a marking point.
    You've just placed a pad on this place where the grab point was.
    A grab point will be used e.g. for placing the parts on the pcb with an placing automate.
    So this issue is that must placed (drawn) the grab points on an separate layer (PCB-editor) in Eagle.
    You can than switch on/off this layer if you like to use it.
    In PCB-editor just generate a new layer called grab point; layers over 100 are free to use.
    Or two layers, one for the top side, one for the bottom side.
    Normally the layers 21 (tplace) and 22 (bplace) are used for placing the parts on the pcb.
    This is default.
    But you can generate such layers for special placement, e.g. placement variants or for special mechanical behavior.
    Tip: In Eagle you will find a ULP file that generates data-sets for placements automates.
    Best Regards
    Gerald
  • salomonreinach
    Hi Gerald,
    Thank you for your answer, it was a recommendation of a manufacturer. They asked me to connect the holes to the GND.
    I found the solution to replace the holes with pads, then it should be connected with the ratsnet.
  • geralds
    "grab point" ? - connecting to an electrical connection?
    You can only connect electrical components to a signal or power connection.
    There are normally Pins, Vias, Wires.
    All other components are just graphically drawn.
    And they are must drawn in their given layer.
    Please read the manual also the tutorial manual as well.
    You will find what is an electrical or a mechanical component, or a virtual "component" as well.
    A grab point i a virtual "component" (devise), like the margin point as well.
    Gerald
