EAGLE User Chat (English) how to measure when making packages?
  • Subscribers 189 subscribers
  • Views 594 views
fritzz
fritzz over 14 years ago
I see how to make a symbol since measurements are not critical, but how do I measure the sizes when making a package? If it's .100 spacing on my part, that seems ok, but what about when it isn't a standard size?
I don't see a measuring tool. I am looking for any tips how or a pointer to info to make this easier..
    0 e14 Contributor over 14 years ago in reply to fritzz
    On 6/22/2012 9:28 PM, d r wrote:
    Once I add a measure mark, how do I remove it?
    Is ther really no ruler tool when making packages? Counting little boxes is a bit tiresome.
    There are continuous coordinate readouts in the upper left region of the
    board editor.    These will give you both absolute (relative to the
    origin of the board) and relative (to the last placed marker).    Using
    the relative coordinates will save you from having to count boxes.
    One caveat is that to be the most useful you should have a fairly high
    resolution setting for the alt-grid and use alt-grid when placing the
    marker.   Doing so will allow you to place the marker accurately.
  • fritzz
    0 fritzz over 14 years ago in reply to e14 Contributor
    Is ther really no ruler tool when making packages? Counting little boxes is a bit tiresome, and that measure tool is ok, but not great...
    You can set the grid (help grid) and snap to it. You can do properties
    and set the location and to measure you can look at the numbers on the
    left side or you can set a mark (help mark) for a relative measurement.
