EAGLE User Chat (English) Help?
  • Replies 19 replies
  • Subscribers 187 subscribers
  • Views 2410 views
Help?
Hi, I am new to this program. I have tried everything and can't figure out
why nothing I do is working.
I need a simple adapter board. I watched videos and everything. I am trying
to simply make a small board that has 42 holes for a m27c160 eprom to fit a
36 hole board.
I have went here http://schematicpal.com/ and downloaded the eprom
M27C801-100B1 it shows two boxes the left red box and the right green
circles in the black box. I can only place the red box in the schematic
when I need the other one to just place the holes for me. When I click on
circles they are not circles but pads, I need holes!
Plus the eprom clearly has 42 legs yet the only Library file you can place
in is missing majority of pins. This blows my mind it's not even accurate?
You go to the board view and magically it shows the entire chip but
completely useless as it will not let you run traces, that has to be done
in the schematic where they don't exist!!!
I have tried drawing circles "holes" manually but when I switch to board
view it does not bring them in? I tried grouping the 42 circles together as
that is what I need for the 27c160 eprom but it does nothing.
I can't believe how difficult this is. I want to order these boards but I
need a gerber file. I could whip this thing out in paint in like 10
minutes, here I have wasted countless hours trying to decipher this program
that will not do anything I want it to.
I think learning a new language would be easier them deciphering this
program.
    autodeskguest over 11 years ago in reply to autodeskguest
    Well it has pads on both sides. I used a "header pin" layout remember.
    Trust me I barely understand what I did. I just dropped the library file
    and sent it out. I actually got some boards in today. I only ordered 10 to
    make sure they will work.
    I need the 1/4" hole as the case it goes into has a 3/16" peg that pushes
    against the main pcb that this will be sitting atop of.
    The only thing I did not do that I have heard mixed feelings about is
    ground the unused pins. I guess I could do that before I order the bulk of
    the load, but I made a test board and ran like 35 wires by hand and just
    bent up the pins to nothing and it works fine, that was months ago I did
    that and it still works fine?
    http://s14.photobucket.com/user/icemanxp300/media/100_1030_zps9sraditr.jpg.html
    Quote:
    M27C801-100B1
    Except for the mounting hole, you need PADS not holes. A pad is a hole with
    copper around it. You cannot connect copper traces to holes. You can only
    connect traces to pads. According the the drill symbols, your mounting hole
    is actually the same diameter as the drill for the pads. To make it 1/4",
    click on "i", then click on the hole. In the dialog box you can edit the
    drill size of the hole. BTW, 1/4" is HUGE. You will then have to re-route
    your board. First, you need to rip-up the traces. Type "RIP *" (without the
    quotes) into the command line. Then route the board.
    I see that there are several pins that aren't connected to anything. All
    CMOS inputs *MUST* be connected to either +V via a resistor (i.e. 10K) or
    directly to ground. CMOS inputs will act erratically (bounce between '0'
    and '1') if left floating (unconnected), and your board will act
    erratically, too. Floating inputs also draw more power. You may be able to
    get away with leaving them float, but then you will have failures in the
    field.
    I sure do hope this is correct. I just ran connections all in schematic. I
    went into net classes and made width .5mm, drill 1mm, and clearance .5mm I
    then ran auto router and this is end result?
    I have that hole on bottom that is suppose to be 1/4" but it doesn't look
    like a 1/4" hole in the green pic. I had only shown layers, pads, holes,
    drills, and vias.
    http://s14.photobucket.com/user/icemanxp300/media/Finished%20board%20%20segments_zpsc3hbnbnn.jpg.html
    I finally got a wire to show I want a cookie! I can not believe this
    program is sooooo anal that it required my net wire to attach to the very
    end of the pin lead it shows in schematic view, unbelievable. Further more
    unless you have the grid size adjusted small enough you can never place the
    wire on the exact end spot that it needs.
    This is absolutely a horrific experience and very poor programming. I took
    some programming courses a bit awhile ago and every time I go to a webpage
    and it ask to input data such as a birthdate and I have to manually click
    each box, that is the same principle here. All it takes is a simple line of
    code so when you enter your data in box a it automatically goes to box b
    for you.
    This program is very picky and not user friendly one bit!
    Thanks lol. At this point it has zero to do with $$, and is more so
    principal now. I generally don't have too many problems learning stuff and
    I can pick stuff up pretty quick, not this. I even took cad in high
    school.
    It is driving me nuts. I watched the tutorial on youtube from Jeremy Blum.
    That helped like crazy, however For the life of me I can't figure out how
    to draw a simple freaking trace from a to b!
    The header pin I upload has 7 spots for holes but in schematic view it is
    one entire structure, you can't define the individual holes or I don't know
    how. I can run wires, net wires, buses, and all in schematic but once I go
    to board view not a single one transfers with the components like he did in
    the video.
    Once in board view it will not let me run any wires as it says that needs
    to be done in schematic, seriously I want to punch the person who wrote
    this damn thing! You can do this but nothing happens and if you don't do
    that you can't do it later.
    On 27/09/2015 18:21, Greg wrote:
    Yes this program sucks! Must have to buy the real version in order for it
    to be a useful program. It's kind of like this website. Their is NO edit
    available anywhere, so you have to make a new post every time.
    Wow I will never ever recommend this program to anyone it is completely
    useless.
    I truly sympathize with you because I've been where you are not long
    ago. I still struggle, but not as much because after a lot of
    frustrations and learning I finally have a general overview and grasp of
    how it all works. That makes it easier to learn more.
    Eagle is (even the free version, which I use as well), like most other
    professional and specialized tools, an advanced application which isn't
    self-explanetory like a web browser, word processor or email program or
    whatever but takes a lot of time and effort to learn.
    I suggest you either hang in there to get an overview and understanding
    of the software by reading web tutorials, tutorial videos on Youtube
    etc. and of course practising yourself, but if you only need to have a
    single PCB done I agree with what others have said: pay someone to get
    the job done, because for that alone I would say the learning curve
    isn't worth it.
    L.
    autodeskguest over 11 years ago in reply to shabaz
    Yes I am going to have to pay someone. Maybe pads was the wrong term to
    use. I am simply talking about the round rings on ever through hole.
    All I want is 42 holes cut w/the copper rings around them that connect to
    traces that will run to the other 36 holes w/rings around those.
    It will be very similar to this board. It will only have 1 eprom connected
    instead of 2 like this board has. The board will be shaped a bit different
    as well. This is however what I need, just different chip and size. But
    that is the boards I will be connecting these to.
    http://s14.photobucket.com/user/icemanxp300/media/adapter_zpsrn66oleo.jpg.html
    shabaz over 11 years ago in reply to autodeskguest
    Hi Greg,
    You could pay someone to do this for you if you're not prepared to do it yourself, or you may be
    better off with alternative software - I don't know what though, because no-one works in this manner
    any more. Adding pads individually went out with the sticky-backed-crepe-paper-on-transparency-film
    methods of the 1970's.
    Somebody (e.g. a student) would probably do it for you in EAGLE for a few hundred dollars - it is probably just an
    evenings work including the time to discuss it.
    Well after watching more videos of this program it appears what I need is
    to "define an electrical connection". Well that option is NOT available in
    my version, it is no where to be found.
    useless.
    This is a waste of my time. I don't think I even did it right last night. I
    need pads around the circles. There is no option to add a pad. This is just
    unreal.
    I added (6) 7 pin headers and 6(6) 6 pin header and those have pads, except
    when you draw a wire from them on the schematic view the wires don't show
    in the board layout.
    I seriously feel like an idiot. I am way better off waiting for someone to
    respond and do this for me.
    You say this program is easy, well it does not seem easy to me. I can't
    even get a trace ran.
