EAGLE User Chat (English) When is Eagle v8 coming   out?
  • Replies 45 replies
  • Subscribers 184 subscribers
  • Views 4140 views
Justynb
Justynb over 8 years ago
Cadsoft.io is teasing with some features for the new version of Eagle, and
the main page states "It's coming. Soon".
Does anyone have any idea what kind of timescale the "soon" is? Could it be
this week, or next month, or three months?
The features they list sound promising:
  • Interactive router
  • BGA fanout
  • Synchronised reusable design blocks
http://www.eaglecentral.ca :: The original and best browser access to CadSoft EAGLE support forums.  Supported by EAGLE licenses purchased through us :: http://www.eaglelicenses.com
  • Fred27
    Fred27 over 8 years ago +1
    It seems the answer is... now. Autodesk EAGLE PCB Design Software
    autodeskguest over 8 years ago in reply to Joop14 +1
    On 1/17/2017 2:53 PM, Joop wrote: One of the new exciting features: Autodesk & Cadsoft will try again to enforce a "licence management" system that will require you to have an internet connection... They…
  • techsupport
    techsupport over 8 years ago in reply to shabaz +1
    On 01/18/2017 01:14 PM, shabaz wrote: Hi Jorge, What will be the rental (subscription) cost for the 'EAGLE Make' version? To be honest I don't necessarily mind subscription provided that over the long…
  • Joop14
    Joop14 over 8 years ago
    No need to throw out the key files and registration codes.
    Nobody asked for that, they have been working fine.
    What happens when Autodesk pull the plug from their authentication server?
    Quote:
    CadSoft Computer has always, and will always, put the customer
    needs at the focus of everything we do.
    We will see how that is going to work out this time...
  • rachaelp
    rachaelp over 8 years ago in reply to autodeskguest
    Hi Jorge,
    Can you confirm that it will still work on multiple machines? I.e. I
    currently run EAGLE on two Mac's and one Linux PC, as I use different
    machines depending upon where I am and what I am doing. If that ability
    were no longer available that would be an issue for me.
    Best Regards,
    Rachael
  • rachaelp
    Hi Jorge,
    Best Regards,
    Rachael
    autodeskguest over 8 years ago in reply to autodeskguest
    Am 17.01.2017 um 23:18 schrieb Jorge Garcia:
    It is VITAL that you don't sign out. If you sign out and then go
    offline, EAGLE won't have your licensing credentials and you won't be
    able to work.
    That is basically all there is to it. At a minimum you need to be able
    to connect to the internet once every two weeks in order to use EAGLE.
    Bye bye EAGLE. We had a good time the last 20 years, but it's time to
    look for alternatives now...
    They seem to have forgotten this:
    Hi Joop,
    It was nice to chat with you on friday. I'll never forget that fiasco
    with Newark. There were a lot of factors that made that implementation
    unuseable. I've played with this one. Even though I know that any change
    in this area is going to be met with resistance, this implementation is
    probably the least annoying.
    So here are the details:
    - Gone are key files and installation codes. No more having to store
    them or remembering where you put them. Now your EAGLE license will be
    tied to you Autodesk Account. When EAGLE starts up for the first time
    you will have to login to your Autodesk Account and EAGLE will hit the
    Autodesk server to check your entitlement(this is what Autodesk calls
    your license).
    If everything checks out, you'll be greeted with the control panel. If
    you close EAGLE and open it again it will automatically use the
    credentials you supplied previously and just start.
    - EAGLE can work in offline mode for 14 days. The countdown starts from
    the last time EAGLE was able to hit Autodesk servers. So if you go on a
    business trip you don't have to worry about Wifi or anything like that.
    able to work.
    This is the same licensing model Fusion uses and it seems to be working
    pretty good for them.
    Thought it would be useful to spell it out clearly. Let me know if there
    are any questions or if I missed something.
    Best Regards,
    Jorge Garcia
    Time to say goodbye.. after 25 years.
    Joern Paschedag
    Indeed (27 for me).
    I was really hoping that V8 would be a step forward, but this license
    model is an absolute no-go.
    Farewell,
    Tilmann
    Indeed (27 for me).
    Farewell,
    Tilmann
    Indeed (27 for me).
    Farewell,
    Tilmann
    I see no difference to that vehemently shouted down last time.
    I too won't support a product that compels connection to the internet
    beyond initial registration.
    Warren
    ... use NNTP://news.cadsoft.de and a functional news reader like
    Thunderbird!
    ... or http://www.eaglecentral.ca browser access to CadSoft EAGLE
    support forums.
    Indeed (27 for me).
    Farewell,
    Tilmann
    Indeed.
  • Justynb
    Justynb over 8 years ago in reply to autodeskguest
    Jorge Garcia wrote on Tue, 17 January 2017 17:18
    able to work.
    Hi Jorge,
    This is obviously very unwelcome news, but I was expecting it.
    Autodesk will be under immense pressure to make sure this is not
    problematic for any users. In fact I have never, ever used a piece of
    software with this kind of licensing that did not occasionally fail to
    authenticate for some reason (ie due to a OS update rendering the license's
    system verification incompatible).
    I'd be grateful if you could answer two important questions.
    1) Will Eagle still allow you to fully inspect designs in read-only mode
    while completely offline for more than 14 days (or without an Autodesk
    account at all).
    2) Will the file formats for boards, schematics and libraries all still be
    plain (non-obfuscated) XML? This is very important if we are to trust our
    designs to a piece of software that it may not be possible to run at some
    point in the future (due to changes at Autodesk or the ownership of Eagle,
    for example).
    Thanks.
